05-22-2020, 11:11 PM | #1 |
Dana 44 differential cover torque specs
Can anyone tell me where I can find the torque specs for the differential cover front axle? Is there a book that gives all the torque specs for the drive train? Mine is a 66 Chevy 1/2 ton. Thanks in advance
05-23-2020, 12:08 AM | #2 |
Re: Dana 44 differential cover torque specs
I think i torqued mine to 25ft/lbs. spec wasnt in my manual, so i just googled it and iirc, most guys were saying around 22- 30 ft lbs.
05-23-2020, 06:11 AM | #3 | |
as important as proper torque, make sure to remove any high spots on housing and cover, paying extra attention to bottom edges, so parts sit nice n flat for lower chances of leaks.. you can also place a small led flashlight inside the diff while dry fitting the cover to look for leak paths..
the permatex I mentioned below works good on tight clearances like these if gasket is not used.. if an rtv is preferred, this is good stuff Permatex® Gear Oil RTV Gasket Maker and if you have trouble keeping the residual gear oil from running down the lower flange lip, jack up the vehicle so that end is high and oil runs in instead of out.. clean both surfaces with brakleen so sealant bonds tight.. and make sure any sealant recommended cure times are followed carefully before allowing and oil contact.. gear oil is sneaky.. good luck! Quote:
I started out with nothing - and I still have most of it |
05-23-2020, 08:41 AM | #4 | |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
05-23-2020, 12:09 PM | #5 |
Thanks for some really good info. I have bought the Lubelocker gaskets, only because I didn't know about the sealant mentioned above. Lubelocker gasket with the proper torque spec should hopefully work. Thanks, Mike
05-24-2020, 08:52 AM | #6 |
Heard nothing but good things about the lubelocker gaskets. Absolutely hate using rtv on covers cause of mess and time it takes to wait for it to "skin" before putting back cover and fill with oil. I have a few leakers and plan to use them also
