Old 05-27-2020, 04:37 PM   #1
kglowacky
rubber boot on steering shaft
does anyone know if someone sells a replacement rubber boot on the steering shaft between the steering box and column? it fits inside the bell cup looking connector to the column. Thanks
kglowacky is offline   Reply With Quote
Old 05-28-2020, 03:07 PM   #2
kglowacky
Re: rubber boot on steering shaft
no one?????? I need one badly
Old 05-28-2020, 03:28 PM   #3
Pontiac1976
Pontiac1976's Avatar
Not yet for the GM Trucks you have to get a good used one or a new old stock. as they make the GM 67-88 car boot.> Witch is smaller out side diameter then the GM Trucks 73-90. I hoping that In Line Tube will start make them.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-28-2020, 10:27 PM   #4
mongocanfly
mongocanfly's Avatar
Are you referring to the boot that fits over the DD slip joint shaft?..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-29-2020, 08:06 AM   #5
kglowacky
yes
Old 05-29-2020, 08:44 AM   #6
mongocanfly
borgenson sells it..heres the email reply I got from them...
The part # is BOOT-7-X but the order can only be placed over the phone for that part. So call us anytime you are ready.
Regards,
Josh Barber
Borgeson Universal Co., Inc.
9 Krieger Drive
Travelers Rest, SC 29690
Tel. 860-482-8283
Fax 864-610-2628
Josh@Borgeson.com
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-31-2020, 05:57 PM   #7
kglowacky
thanks will do in the morning
Old 06-05-2020, 08:38 AM   #8
Pontiac1976
Wow that nice to hear. When you get would be nice to hear what it cost how it fits pic before after installed.
