Old 05-29-2020, 08:58 PM   #151
joedoh
joedoh's Avatar
Re: Project "Bickle" 1948 1/2 ton 4.3 4l60e
thanks jim!
today me and beeps went to the first swap meet since we bought those 55-57 beds, remember that? we walked straight to a table and swap met a cranky guy with a bunch of steering wheels. crank or not, he had a 67 deluxe chevelle cap and thats what I was missing.
found a model A taillight stand and license plate bracket, I wanted it for the 53 number riveted over the 51 plate, never have seen anyone do that before. and the chrome 55-57 headlight bezel for my 56, $3!
then I visited travis and he he had what I needed. 1/2 ton short running boards and aprons
and a whoa black beddy.
visited his GMC too, great looking swap, going to run a 6BT.
thats all till tomorrow!
Old 05-29-2020, 10:51 PM   #152
OutlawDrifter
At it again! That GMC has potential!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 05-31-2020, 10:36 PM   #153
joedoh
joedoh's Avatar
yeah travis is crazy talented, I saw him do a swap with a 69 GMC long bed and a 91 c1500 shortbed in a weekend, tbi and shortened the bed, everything.
had to get the old wood out of whoa black beddy. if you havent done this before, it sucks. the bed wood is put in with perimeter bolts and angle strips, and lots of extra bolts in the cross sills. you can go ham and cut the wood straight across, through the bed strips, but that ruins the bed strips if you were planning to reuse them.
if you want to save them, dont bother trying to take off 70 year old nuts, they wont budge with a gallon of penetrant on them, and why would you want to save old hardware like that anyway. what I do is use a long (9") sawzall bimetal blade and slide it in between the wood and the cross sills. the long blade will flex. then a quick cutoff wheel on the side bolts, and for that stubborn front cross sill that is bolted both horizontally and vertically, I just get a 7/16 socket on my impact and a 7/16 box wrench and tighten. snap snap snap.
everything will just kind of fall out when you get all the perimeter bolts out. viola! strips and cross sills intact.
the angle strips are spot welded to the sides, so I take a screwdriver and pry till I can see the spots and then I use an air chisel to pop them. easy peasy
clearance for tires.
put the s10 bed floor on the frame, had to do a LOT of trimming. my friend wanted the bed sides for his roadster blazer (to cap the sides with the bed rails) and so I told him where to cut. he did ok but some spots were wavier than ruffles. I got it all sanded smooth though
more next post
Old 05-31-2020, 10:46 PM   #154
joedoh
joedoh's Avatar
needed the yellow fenders from the storage, same drill (ha, get it? drill). 1/2 inch socket in my impact drill set to tighten, snap snap snap. I threatened it with TWO cutoff wheels but didnt need either.
picked up these lights on marketplace. I have been needing to replace the sidewalk light pole (never made it back up after the retaining wall replacements) and the light pole at the bottom of the drive (a victim of over exuberant mowing). forget the old gas light style fixture with the yellow bug light, how about some 400W HID?
all 4 lights, $60. I think the steelers will be able to play night away games in the front yard this year.
I was tired when I got back so I just shot pictures of the truck outside.
hows that fender alignment now?
I should throw the spacers and the 20s on for a look but I think I will put the bed and running boards on first.
more to come!
Old 05-31-2020, 10:53 PM   #155
mongocanfly
mongocanfly's Avatar
Looking good Russ....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-31-2020, 11:24 PM   #156
oldman3
oldman3's Avatar
Russ, looks like everything is lining up good...Jim
oldman3 is offline   Reply With Quote
Old 06-01-2020, 09:42 AM   #157
OutlawDrifter
In your area, you might want to be careful with those lights, might have some aircraft circling looking to set down!
1991 Z/28, 6.0L/T56
Old 06-01-2020, 02:05 PM   #158
joedoh
joedoh's Avatar
haha did you hear about the cargo plane that landed at jabara instead of mcconnell about 7 years ago?
https://www.aopa.org/news-and-media/...jabara-airport
they had to empty it so it could take off on the short (comparatively) runway.
Old 06-01-2020, 03:04 PM   #159
OutlawDrifter
Yes that was quite a snafu. I remember laughing about it with my granddad who was a WWII Naval Aviation Vet. He had some of the best flying stories!
1991 Z/28, 6.0L/T56
Old 06-01-2020, 09:12 PM   #160
joedoh
joedoh's Avatar
oh man, what a time that must have been, when flying was all about the large piston aircraft. the movie Fury sure got the airplanes flyovers just right for a mediocre tank movie.
oh by the way, my new shop is literally across the road from the jabara approach light array, parallel to the runway.
popped the bed on before it got hot. its hard to see in the resizing that the forum does (by the way WHY does the forum resize pictures to 640x480?! is it 1995 again?) but the center fender bolt is dead on the center of the axle, and the bed is only 3/8" away from the cab at the center.
eagle eyed readers will remember I shortened the frame 6.5", the extra 0.5 to close the bed gap. I may never go back to longbed donors.
I have to trim the front panel and bend it down, the shortbed s10 bed floor is about 3" shorter than the AD shortbed.
once I have that measurement I will lock it away too.
it got pretty hot in the driveway so I took a break to shorten the bench seat height. I always MEAN to do this, and never have. on this one the steering column is 0.25" lower than previous trucks (thickness of the bracket) so it had to be done. let me tell you, it makes a huge difference. I used 2" tape to mark my cuts, then welded it back together. that overbite you see is in the back so I just patched it in for strength and called it good.
mrs joedoh always complains about the seat height when the trucks are done so I had her test this one. shes very shy but I snapped a pic when she wasnt looking, better to beg forgiveness than ask permission, right?
she said it was light years better than any previous truck, so now I can send it out to be recovered. still deciding between black upholstery on the seat or matching the dash champagne mist. guess I will decide when I see how close he can get...
mocked up the running boards to set the bed depth and tacked the floor in. woop woop!
tomorrow I will pull it all apart and weld things up. I need a driveshaft still. I got some ribbon cable to extend the gauges. things are going well!
Old 06-01-2020, 11:40 PM   #161
oldman3
oldman3's Avatar
Nice...Jim
Old 06-02-2020, 08:38 AM   #162
8man
Nice job.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-03-2020, 09:18 PM   #163
joedoh
joedoh's Avatar
thank you jim and robert!
had to do an old school repair to the bed side, the drivers rear was way out of whack, wagged out like 4 inches and the angle part jacked up. a cclamp and ratchet strap (my new son in law) fixed er up.
that was after tacking the bed floor in place. I used a chisel and cut a neat 3/8" strip of the bed liner out, when I am done tacking it in I can fill it back with seam sealer and NO ONE WILL EVER BE THE WISER
blew it all apart, finish welded everything and squirted some black satin paint on it
it was hot as heck today, I looked like I took a shower after taking the cab and bed and front end off then shoving them around. I put the cab on that heavy duty cart I bought earlier this year and regretted it because it looked too tall to roll in the garage. I tried and sure enough, it hit the clearance lights (isnt that what they are for anyway). a couple minutes with a grinder and it literally left a rust mark where it dragged the roof on the header. doesnt matter, fit.
found all the parts I need to weld in and shot a little champagne mist on the piece I will be cutting out (to check the color)
more to come, jeremy is bringing his frame saturday so I need to have this rolling again by then
Old 06-03-2020, 09:51 PM   #164
OutlawDrifter
Russ I had to do some work outside when I got home from my "day job" ended up in the same condition.
Initial thoughts on the color?
1991 Z/28, 6.0L/T56
Old 06-05-2020, 02:31 PM   #165
28TudorAZ
28TudorAZ's Avatar
Truck is looking geat!!! I love the seat idea. I may have to do it. Can you really tell a big difference?
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 06-05-2020, 07:21 PM   #166
mobileortho
mobileortho's Avatar
That bed floor turned out great!
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 06-05-2020, 10:32 PM   #167
joedoh
joedoh's Avatar
28TAZ its a HUGE difference. YUGE. so much more comfortable, and only took about an hour.
Marc its an ok color. one thing I have learned is even though I have impeccable taste (guffaw) sometimes it aint just about what I like. I still havent decided on a seat color.
mobile thanks, using the ext cab bed is really nice, sssssuuuuuper strong because it has all 8 bed bolts. with a longbed bed, you cut off the very front and lose the very rear. the ext cab is just a couple inches short of filling the AD bed, but if you save the front panel of the s10 bed (leave it attached to the floor) you can fold it down and make up the couple inches in front.
got the HVAC panel welded in 100%, not only was I able to work inside (its reeeeally hot right now) but that cart I picked up holds it high enough that I can sit on a stool to weld the bottom side of the firewall and stand up to weld the top. 10/10 would buy again.
sorry, not many in process shots. I actually lined it up using an old photo of wamego haha.
I braved the heat and put the cab back on the fresh painted frame, then the bed. and rolled the front clip in on the same cart.
for anyone wondering how to move big parts like this around on your own, my secret is two things: balance and leverage. I use the balance of heavy things like beds, standing them on end and "walking" them to where I need, then using leverage of the bed balanced on the frame to let me lift it by the corners into place.
on the front clip, tonight I noticed that if I lifted it by the bar I welded at the bottom of the core support, it was perfectly balanced and actually light enough that I could carry it in the garage!
got another potential real estate deal in the works, maybe update monday.
Old 06-06-2020, 12:14 AM   #168
OutlawDrifter
Russ, hot for sure 104° heat index today.
I cut my Astro/Safari rear rear seat down too. Can't remember how far, but it was totally necessary.
Having a comfortable welding position makes all the difference!
1991 Z/28, 6.0L/T56
Old 06-07-2020, 01:23 AM   #169
joedoh
joedoh's Avatar
Question Re: Project "Bickle" 1948 1/2 ton 4.3 4l60e
marc it was surface of the sun hot today. I am getting worried about the rental, it hits 80 in there and the AC runs alll day.
today I did other peoples stuff. my daughters friends came over early and we set up the waterslide for them. my neighbor came by, he said last week he wanted to build a kayak holder for a trailer and needed some scrap for gussets. I pointed to my scrap pile of table pieces that still had gusset sized areas in them. todaay he said he had designed the gusset and could I cut them? his gussets were 10x10, and he needed 10. double gulp. he brought me a 2x4 sheet of 1/8 though, after I told him it was a 100 linear inch job, and I programmed the CAD and the CAM and cut his stuff.
then a very patient jeremy came over and even though he was early waited until I finished the neighbors job and did all the honey dos with the kids. he had bought a longbed s10 frame, or so he thought at first, I told him it was an ext cab frame by the third cab mount in the middle.
so I offered to help him shorten it and we quickly went from 123 to 116.5, about 2.5 hours! including the stupid early s10 fuel lines that run through the frame.
as payment, he left with my spare roller set of s10 swirls and I got some deep offset slots.
not my favorite but looking around, slots an RWL tires are just white hot right now. the plan so far is to keep them handy and when the inevitable hagglers come for bickle they will be the bargaining chip to keep the 20s. I didnt pay a lot for the 20s, but they have brand new tires too.
back on bickle tomorrow.
Old 06-07-2020, 08:23 AM   #170
oldman3
oldman3's Avatar
Russ, as if you weren't busy enough, now the neighbors are seeking you out. Your a good man...Jim
Old 06-09-2020, 12:08 AM   #171
mobileortho
Really like the bed floor. I was thinking about doing the same thing.
Robert C.
1950 3600
Old 06-09-2020, 09:50 PM   #172
joedoh
joedoh's Avatar
thanks jim, and mobile I LOVE using the steel floor. with the shortened ext cab frame it retains all 8 bed bolts and is SUPER strong. I usually put bed wood and strips over top of the steel.
while I was working on my neighbors parts I also popped out a lower rad mount. normally I cut these by hand with some snips but liked the idea of repeatability so I designed it in cad and cut it on the table. unfortunately I forgot about the bend line cuts so they needed some technical tapping with a hammer. not great.
luckily I had my head up my butt and made two "rights", so I went back and added the bend cuts in the design and popped out two more, bending a left and a right this time.
I thought that worked well so I did the closeout panels on the table too, and started fitting them.
I had to stop because it was threatening to rain, the truck has been languishing outside in the sun this last week but cant get wet yet. I hope to have this rad mount done tomorrow and the front end put back together.
on the real estate front: we wanted to talk to the guy who owned the land next to the shop, and I finally caught him mowing. under no circumstance could he be persuaded to sell, which was a bummer. then a 2 acre lot around the corner came up for sale, and we considered it but the realtor never called back. after looking some more, it backed up to some tract homes and I didnt like that. I told my wife maybe something closer might pop up.
then I got a call, a woman in the neighborhood heard I was looking, and asked would I be interested in the place across the street?. why yes, yes I would. she stated her price and I agreed. its an older double wide manufactured home on a foundation and has an attached 24x24 garage with 11ft ceilings. its in great shape, and hits all my buttons, side load garage, treed lot, house number is 4 3 2 1. we close in three weeks so its all over but the shouting. I am trying to convince my wife to rent our current house and live there, that neighborhood is so quiet and I would be across the street from my shop. no luck yet haha. the plan is to build a house on the lot eventually.
Old 06-09-2020, 11:30 PM   #173
oldman3
oldman3's Avatar
Russ, nice job on the parts, congats on the property...Jim
Old 06-10-2020, 11:07 PM   #174
reaper71
reaper71's Avatar
Nice progress
reaper71 is offline   Reply With Quote
Old 06-11-2020, 07:40 AM   #175
8man
Those brackets are nice. Looking good.
8man-aka Robert
