Old 06-03-2020, 10:50 AM   #1
blazer2007
redoing headliner ?
Just in the process of fixing the sagging headliner and starting taking off the old glue and it pulls off like paper and leaves the fiberglass type headliner. I read on anther truck forum that he sprayed the headliner after it was cleaned with a polyurethane spray and let it dry and then used glue and put on headliner in the normal fashion. Is this a good idea to spray something on the headliner to help hold the fibers and make the headliner more uniform ?
blazer2007 is offline   Reply With Quote
Old 06-03-2020, 12:16 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: redoing headliner ?
you could spray it with an aerosol clear coat
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-05-2020, 08:41 PM   #3
blazer2007
Just wondering if the glue and headliner would pull off the clear coat ?
Old 06-05-2020, 09:58 PM   #4
SilverMiner
SilverMiner's Avatar
I did the headliners in my Suburban (both front and rear, and the rear is HUGE) on my own without messing around with a clear coat. I did carefully scrape off the scuzzy old foam which left a reasonably smooth cardboard surface that accepted the 3M Super77 adhesive in excellent fashion. The new headliner has survived nearly three years now including very cold winters and quite hot summers.
When it comes to almost everything including adhesives, surface prep is everything. Simply carefully cleaning the scuzzy old foam worked for me, but I wouldn't be surprised to hear additional efforts may work as well.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 06-06-2020, 10:24 AM   #5
72c20customcamper
72c20customcamper's Avatar
I just did mine no clearcoat just removed the foam from the cardboard . Used weldwood landau top high heat resistant glue sprayed on with an old binks N° 7.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-06-2020, 10:35 AM   #6
72c20customcamper
The foam just brushed off with a scrub brush . The hitch was for weight I lightly moistened the cardboard and placed weight on it to remove the sag worked out well.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-06-2020, 12:05 PM   #7
rideair
Like others here, had the same problem with my 1988 Suburban, but decided to go another way.
Now, the Suburban has the old fashion "vinyl and bow" headliner with sound deadening (Dynomat) along with 3M™ Thinsulate™ Acoustic Insulation SM400L for heat/cool and sound control.
Also thought the vinyl-bow was a more classic look than the fuzzy stuff.
Enjoy,
rideair is offline   Reply With Quote
Old 06-06-2020, 06:19 PM   #8
72c20customcamper
Enjoy,
Mine isn't fuzzy its snakebite vinyl. Picture of the original . Found the exact match from a company that does alfa Romero's
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-06-2020, 06:58 PM   #9
TKCR
TKCR's Avatar
I’ve done several headliners, and never needed to spray anything but the adhesive glue on the headliner board. All the old foam can be removed using a wire brush. Then spray about half the the board and half the headliner material. Once that half in done, move to the other half. The adhesive I use is the High Temp for high heat area, like headliners.
Old 06-06-2020, 09:13 PM   #10
blazer2007
Thanks for all the suggestions. Making headway on removing the old stuff,wear a mask, it bothered me at first. The only trouble is none of the products you mentioned are not available in Can. I had no luck with super 77 on simple projects. Might try loctite high heat adhesive
Old 06-07-2020, 07:24 AM   #11
TKCR
TKCR's Avatar
The High Temp Adhesive I mentioned can be bought online. Amazon, eBay and a few headliner material places online. I get mine from MiamiCorp, they are the cheapest. Plus they are in Ohio, so when I order, I get it in a day or two. I also get other supplies there also. Headliner materials, foam adhesives and other things.
https://www.miamicorp.com/default.as...13&parent=2699
https://www.stockinteriors.com/headl...sp?ItemId=6731
https://www.amazon.com/High-Temp-Per.../dp/B072LYCDLH
Old 06-07-2020, 09:02 AM   #12
blazer2007
I,ve tried and comes saying no sellers available to ship to your area. Don,t know if it is the CPP virus thing or certain chemicals can,t be shipped to Can.
Old 06-07-2020, 10:51 AM   #13
72c20customcamper
Try an upholstery shop they should be able to steer you right direction to buy the glue. Or many even sell you some.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-07-2020, 10:56 AM   #14
72c20customcamper
How many cans does it take to do a truck headliner? @ 12 bucks a can that could get expensive . I used over a quart just doing my suburban. The gallon of weldwood was $ 57 shipped
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-07-2020, 03:05 PM   #15
TKCR
TKCR's Avatar
1 can for a regular cab pickup. But I like to keep an extra can on hand just in case.
Old 06-07-2020, 04:33 PM   #16
kipps
All this talk about headliners -- Did all trucks come with a headliner?
Mine doesn't have one. It's just steel overhead. Was it removed at some point, or was it only included with the high-optioned trucks?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 06-07-2020, 07:02 PM   #17
TKCR
TKCR's Avatar
Some trucks did not come with headliners. But they can be added, you just need the interior headliner trim and headliner.
Old 06-08-2020, 12:35 PM   #18
69Tom
I have the same style material in my 74. Can you let me know where you got it? I'd rather not drop $250 on a new one.
Thanks.
69Tom is offline   Reply With Quote
Old 06-09-2020, 08:02 AM   #19
TKCR
TKCR's Avatar
Thanks.
Snakebite is another word for perforated vinyl headliner material. You can do a Google search and all kinds of places online will come up. Then from there, you can check prices and colors. A lot of places offer color samples. I like using this place, because it’s in Ohio. I get my orders within a day or two. But they have the materials for the headliners and adhesives.
https://www.miamicorp.com/products/H...EADLINING.aspx
https://www.miamicorp.com/customer/m...Headlining.pdf
Old 06-10-2020, 09:19 AM   #20
Pontiac1976
Pontiac1976's Avatar
blazer2007:
You could try 3M Adhesive 77 I be leave it's called, try online Amazon.ca search 3M Adhesive 77 works on headliner.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-10-2020, 10:25 AM   #21
blazer2007
I tried some super 77 on some material on the side panels on my Blazer and it started letting go after a year. We get some real hot weather here in the Okanagan valley. I talked to a upholstery shop and she said she uses Lepages contact cement from Home depot but she doesn,t do headliners as no one wants to pay her for all that work at $85 a hour
Old 06-11-2020, 08:30 AM   #22
72c20customcamper
Thanks.
Place in Califonia
https://www.jjautofabrics.com/endura...-sold-by-yard/
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-11-2020, 08:31 AM   #23
72c20customcamper
Perferated isnt the same while both are technically perferated . The snake bite has a pattern much different to it
Perferated and snakebite
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-11-2020, 09:16 AM   #24
Big Chip
Big Chip's Avatar
Thanks for the link to Miami, TKCR! I ordered white perforated, foam back headliner for the crew cab this morning.
Big Chip is offline   Reply With Quote
Old 06-11-2020, 05:26 PM   #25
TKCR
TKCR's Avatar
Your welcome
