Old 06-05-2020, 09:12 AM   #1
lks dcvn
lks dcvn's Avatar
ACC Carpet - Cargo Carpet Unfinished at front?
For those who ordered your ACC Carpet and opted for the CST carpet - was the front edge of the carpet 'finished'? I do plan to install rear side panels so the CST carpet was the right choice for me.
I was surprised to find the front edge was just raw carpet and I would have to finish it myself or cut/tuck it under the front trim piece. Alternatively, I guess I could tuck it down under the front seats without cutting, but that wouldn't give a clean appearance.
Does the non-CST carpet come this same way with the front edge like this?
lks dcvn is offline   Reply With Quote
Old 06-05-2020, 12:22 PM   #2
SeventyOne
Re: ACC Carpet - Cargo Carpet Unfinished at front?
Yes - the edge at the front is unlined and needs to be trimmed. Do you have the carpet strips to cover them? I dont think rolling it down that lip and tucking under the front carpet would work or look good...
Here's pics of mine:
SeventyOne is offline   Reply With Quote
Old 06-05-2020, 12:28 PM   #3
Classics Fan
The ACC CST Carpet I installed was rough on the leading edge of the cargo piece by design. Trim it and tuck under the front piece. Pics attached.
Classics Fan is offline   Reply With Quote
Old 06-05-2020, 12:57 PM   #4
SeventyOne
haha two hugger and parchment examples
Oh BTW LKS_DCVN - with the carpet on the wheel wells you will likely have fitment issues with the CST panels. At least that's what I've read.
Old 06-05-2020, 12:58 PM   #5
Classics Fan
Attachment 2021899
Attachment 2021900
Different strokes for different folks. I like both looks. Nice, SeventyOne! I like your chrome trim strip.
Old 06-05-2020, 01:01 PM   #6
SeventyOne
Ah I stand corrected! I wouldn't of thought the carpet would lay flat and make that 90* bend nicely. Either way you need the carpet strip.
Old 06-05-2020, 01:34 PM   #7
lks dcvn
lks dcvn's Avatar
I have the chrome strips so all good there. Thanks for the replies all. Unsure if I will use the wheel covers or not yet. No trucks had them from the factory.
Truck will be the 71/72 Medium Green (back to factory color) with parchment interior.
Old 06-05-2020, 01:40 PM   #8
harrij4
FWIW, having just gone through an interior refresh, my thoughts on the two concerns brought up here:
1) Folding the carpet down over the edge. If you chose the mass-backing it can be a bit tough to create a clean fold. If you wet the carpet then use a heat gun on low temp you can create a thermal fold in the carpet - that's what I did. The water should help reduce the risk of melting the pile.
2) My repro CST panels fit just fine with the carpet over the wells - even with the mass backing AND a layer of dynamat over the wells (under the carpet)
harrij4 is offline   Reply With Quote
Old 06-05-2020, 01:53 PM   #9
SeventyOne
Great info!
Old 06-06-2020, 02:19 PM   #10
Harold Holbrook
SeventyOne, Did you use velrco to hold on the rear panels ?
Harold Holbrook is offline   Reply With Quote
Old 06-06-2020, 08:48 PM   #11
a1vintage69
a1vintage69's Avatar
I am interested in knowing this question about the panel attachment also. good eyes HH!
a1vintage69 is offline   Reply With Quote
Old 06-08-2020, 12:28 PM   #12
SeventyOne
Harold and A1: Yes - I didnt want to put holes in my new panels (rear CST and door panels) so I used 3M "velcro".
see my build here: https://67-72chevytrucks.com/vboard/...&postcount=210
Old 06-09-2020, 10:16 AM   #13
awelle01
awelle01's Avatar
What did you do around where the roll bar bolts to the floor? Did you cut and sew a finished edge around the roll bar, or bolt through the carper? Would not mind seeing some pictures of that! looks great!
awelle01 is offline   Reply With Quote
Old 06-09-2020, 02:04 PM   #14
SeventyOne
Bolts for rollbar go through the carpet.
Old 06-09-2020, 05:14 PM   #15
Classics Fan
Again options to the approach. I measured and cut around the roll bar. Regarding the OP who asked how to install the untrimmed edge, be sure to not trim too much. I did, slightly. It only shows if you look for it but I know it’s there and now you do, too.
