Old 06-03-2020, 03:00 PM   #1
rustytruck50
rustytruck50's Avatar
Trying to get a handle on camber adjustment
I noticed a couple of days after I got my '05 Sierra home, that the RF tire sits out a bit at the top. I've been watching some videos to see how to fix this. How do you know when you need the offset upper control arm bushings and special cams & bolts? Is it strictly for lowering? I did notice that at some time in the trucks past, that it had some minor damage on the rh side. Seems to drive fairly straight and the alignment guy at work said all was within specs...unfortunately not so sure about that.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 06-04-2020, 06:36 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Trying to get a handle on camber adjustment
The text at this link gives a simple explanation of Caster, Camber....
https://explorationoutfitters.com/pa...0is%20positive.
"All within specs"...get a new alignment shop...if one side looks distinctly different from the other there is obviously something not right.
Here are the true GM Specs
Left Front
Camber = .5 degrees to -.7 degrees
Caster = 4.7 degrees to 2.7 degrees
Toe = -.05 degrees to .15 degrees
Right Front
Camber = -.7 degrees to .5 degrees
Caster = 2.4 degrees to 4.4 degrees
Toe = .15 degrees to -.05 degrees
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 06-04-2020, 08:17 PM   #3
rustytruck50
I definitely appreciate that info...I'm considering trying to adjust myself and go outside of my dealership for alignment firming up. I have a suspicion that it has to do with a employee with a 15 year old truck, if you know what I mean.
-Doug
'05 RCSB Sierra 2WD
Old 06-05-2020, 06:41 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Re 15 year old truck and modern shops...sad but so true...total lack of skills in most shops I have seen of late.
Before you get a new alignment or try and change it yourself...best practice is to fully check all suspension components...
Upper and lower ball joints
Steering joints
Suspension pivot bushes
Pitman and idler arm bushes and joints
Shock bushes,,( does your have the rattle left front when going slow over small bumps?) Shock mount bushes....
Steering joints etc....
If you suspect the vehicle has had damage to the right front, the chassis pount points for the suspension pieces may be out of design limits...
Does this vehicle chop up front tires?
2025 Chevy Equinox
Old 06-05-2020, 11:21 PM   #5
rustytruck50
Very good point on the full check up...I haven't had a chance to check those pieces, but I'm very interested in finding out what kind of shape they're in. Tire wear seems to be confined to the outer area of the right front, which is tilted out at the top. The wear seems to be uniform and not choppy.
-Doug
'05 RCSB Sierra 2WD
Old 06-06-2020, 07:50 AM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Yep, common sense tells the story....tire tilted out at top means it is going to wear out the outer edge of the tire...."But the settings are all within spec"...yeah right !
2025 Chevy Equinox
Old 06-06-2020, 12:35 PM   #7
hatzie
Moderator
hatzie's Avatar
I get a before and after printout from the alignment machine or I don't pay for the job.
I make this very clear when I drop off for the work.
I've had a couple shops balk at those terms. I walked right back out the door. I'm not required to take it to those shops and I'm not shy about telling friends and family that I don't trust them.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-06-2020, 08:53 PM   #8
1967GTO
I will always spray the inner and outer areas of the upper control arms with GM Superlube so the adjusters will move easier. You have to be careful or the adjusters will round out. Alignments are not hard with the computerized machines they have now. Definitely tell them you want a before and after printout.
1967GTO is offline   Reply With Quote
Old 06-15-2020, 10:15 PM   #9
rustytruck50
Thank you for the great advice...I will definitely act upon!!!!
-Doug
'05 RCSB Sierra 2WD
