#826 |
Weekend Warrior
Re: How about some pics of Static Dropped C-10's
Thanks for the responses guys. If Bagging it doesn't really achive better results unless you use AM front xmember etc, then Im perfectly fine with static.
I understand that the lower you go the more you comprise in ride quality, but I'm still slighlty confused I guess. I see alot of guys running 5/7 and seem to be ok, but who knows for sure. I had a 69 shorty step about 15 years ago with just a ece 2/4. It handled good, just still looked high lol. Problem fo me is, the look that I like is this pickup. I messaged the owner...6/8 static and claims it rides good. I guess ride quality is all relative to whos driving.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered
#827 |
The statement "it rides good" is very subjective.
#828 | |
#829 | |
I bet most people use this statement because on a nice smooth road surface a truck that's <3" off the ground will do just fine. But as soon as the irregularities start, that 'rides good' statement goes out the window. Some will say "it's all part of it" (it being the experience of owning/driving a lowered classic truck). I've driven my 'classics' daily. I've only had 2 or 3 vehicles along my journey that weren't hot-rodded or lowered but they were temporary rides. After tolerating the constant collisions caused between a lowered truck & common road surfaces I started building w/the mandatory clearance requirements (4" min ground clearance; 3" compression travel/clearance). That made a big difference in the driving experience.
#830 |
I have one static and one bagged. The static one can be embarrassing in the spring when road construction starts and I can,t make it over a deep cut out on the asphalt ,out comes the 2x4,s.It,s not too low, spindles and 1 cut coil but still run into the odd road. Air bag one, just push a button
#831 |
Weekend Warrior
Again thanks guys. Basically what you are all saying is "buy the ride tech streetgrip setup" sacrifice a little bit of "the look" lol
#832 | |
Ridetech is a reputable source but it will come down to your set-up parameters if/where things are adjustable (settings things to their spec or setting things to "OMG that looks BA" can yield two distinctly different ride/driving quality experiences). The 'Street Grip' line of kits definitely seems a good choice. Me personally? Their Street Grip would not be low enough because they build the set-up around the limitations of the lowest point on a C10.... the front x-member & a-arm pivots. In order to have good ride characteristics, that point needs to be ~5" off the ground which puts you @ about a 4/6 - 5/7 drop when cruising. Moving those pivot points higher up on the chassis/rails gets you lower w/the same amount of clearance. Of course, old school dropping the body over the chassis can yield a similar result.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-03-2020 at 09:27 AM. |
#833 |
Active Member
![]() Join Date: Oct 2007
[QUOTE=SCOTI;8750093]When you get past 4/6 static drops using OE geometry/pick-up points, the driving experience diminishes quickly.
I drive my stuff low (5/7 or more). With no mods, it does suck on crappy roads. Static or air doesn't make a difference if you're bottoming out. To make it better, I use a modified factory or aftermarket raised front x-member. It allows for the more aggressive drop I like while provide additional ground clearance. The additional ground clearance is only part of it though. Once you have the aggressive drop w/a modified or raised x-member, you now will most likely need some raised fender wells so the tires don't constantly buzz. SCOTI, What are you doing for steering on the raised factory X-Member |
#834 |
The box, pitman, & idler all remained in the stock positions. I've done the multiple combo u-joints/shaft on one & standard shafts on others w/the upper 63-72 drivers side a-arm c-notched for clearance. My dually has a standard straight shaft w/the a-arm notched.
#835 | |
Active Member
Do you think I'd be okay with the 2" section and leaving the steering components in the stock location. |
#836 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=799484
#837 |
Mine with a 4/6 drop. Ride is firm but very easy to live with as a summer cruiser. Nice part is speed bumps are no issue.
#838 |
![]() Join Date: Apr 2005
4.5/6, 15's with some sidewall make the ride pretty nice...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#839 |
3/5 drop.
1967 C10 1972 Monte Carlo |
#840 |
My 72' 2.5" / 4" drop. Not much of a drop but drives really nice.
#841 | |
Posted via Mobile Device |
#842 |
At the body shop.
My 73
Clipped 2 coils And welded new axle pads on the bottom of a 3.25 tube 9 inch No notch.
" That didnt make it any newer " " Dont antique the equipment " |
#843 |
This is long overdue but I finally installed the ECE suspension I've had in the garage for about 4 years
![]() Here are some details:ECE 4.5/6 drop with drum to disc conversion with (2.5" drop spindles and 2" drop springs) Rear has 6" drop springs, shock relocator kit, and super track bar kit. It's frustrating that they are unavailable for support as a number of small parts were missing (banjo bolts, prop valve mounting kit and lines, dust caps, etc.). Tires are 255/55R18. I have since put different Nitto NT421Q tires on but no pictures yet. Wheels are Eagle Alloy 146s I'm guessing BS is 4.5 or 5.5. While the tires fit with very little clearance, I'd suggest a shorter tire. Overall it's riding really well but the brakes are dragging so I'll need to figure that one out. ![]()
Last edited by 70chevc10; 03-31-2021 at 01:49 AM. Reason: Adjusting picture size |
#844 |
The LuvShack Garage
Forgot to add my old Farmer Truck here. ("Betty")
![]() 6" F ~ 3" Belltech Spindles, 1.5 rounds cut off stock coils 9" R ~ Is a TinWorks Rear Axle Flip / C-Notch Combo Kit
Owner/Op: "TN Classic Transport Carriers" Daily Driver: "HerNameIsRio" 68 GMC SWB The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Toy Hauler: "Feathers" 14 Aluma 8218T |
#845 |
5.5” front & 7” rear
#846 |
![]() Join Date: Dec 2018
not pretty...yet...lol
#847 |
Maybe got a little carried away but I dig how it turned out. Cheap and low. Jaguar ifs up front, explorer 8.8 and suspension out back. 20x9.5 and 20x11.5. Rides great because both suspensions are totally stock.
68 blazer buggy 68 stepside 58 gmc |
#848 |
![]() Join Date: Sep 2014
Hey cornfed, I like the interesting route you went with the suspension.
Do you have a build thread or? I can't view the pics in the link. |
#849 |
A guy with a truck
Nice, and agree: need more pics!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). |
#850 |
4.5/6+. Spindles and springs up front flipped axle in the back.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
