Old 06-11-2020, 09:33 AM   #1
Captain J
What’s this for
Can someone tell me what this knob for?
1972 GMC Sierra
Truck have only one in cab fuel tank
1972 GMC Sierra C2500, V8-350
1986 GMC Sierra C2500, V8-454
1986 GMC Sierra C2500, V8-LS1
1986 GMC Sierra K2500, V8-350
1987 GMC Sierra R3500, V8-454
1997 GMC Sierra K2500, V8-454
Captain J is offline   Reply With Quote
Old 06-11-2020, 09:36 AM   #2
68bowtie
68bowtie's Avatar
Re: What’s this for
I bet it’s anti-theft
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
68bowtie is online now   Reply With Quote
Old 06-11-2020, 09:36 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: What’s this for
It's a switch to toggle between the sending units for the in-cab fuel tank and the now missing but once present auxiliary fuel tank.
Post up a photo of the build decal (SPID) on the glove box door if present
Old 06-12-2020, 06:34 AM   #4
Killer Bee
Killer Bee's Avatar
Re: What’s this for
to add to that, if you follow the fuel supply line from the tank underneath the cab and you might find evidence of it's removal..
Killer Bee is online now   Reply With Quote
Old 06-12-2020, 07:00 AM   #5
Re: What’s this for
That's the '72 auxiliary fuel tank gauge switch to read levels in both tanks. There should be a hole in the floor between driver seat and door where the control valve was mounted. Might even still have the valve and placard in place. I guess someone removed the tank. Might have filled the filler hole in the upper forward part of the bedside or switched beds
Old 06-12-2020, 07:22 AM   #6
Captain J
Re: What’s this for
It might be.
Old 06-12-2020, 07:23 AM   #7
Captain J
Re: What’s this for
Not sure,
I’ll thanks
Old 06-12-2020, 07:24 AM   #8
Captain J
Re: What’s this for
I’ll check,
Old 06-12-2020, 07:27 AM   #9
Captain J
Re: What’s this for
But where was the aux fuel tank located?
As I saw no evidence of aux fuel tank, but I’ll look for the valve and placard.
Old 06-12-2020, 11:57 AM   #10
MJN
MJN's Avatar
Re: What’s this for
Aux fuel tanks were under the box, between the bedside and the frame rail. If there is no filler hole in either bed side I have seen aux fuel tanks that had fill necks inside the rear wheel housing in front of the rear wheel.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-12-2020, 12:18 PM   #11
jocko
jocko's Avatar
Re: What’s this for
NL2 RPO was what got you a single, driver's side only aux fuel tank setup, which included the fuel gauge selector in your picture and a left (only) bedside fuel filler - i.e. a fuel cap just like the cab tank cap, but located on the bed, as shown below. The fuel flow selection valve was on the driver's side floor just inside the door sill and in front of the seat belt retractor. No passenger side fuel fills were available from the factory nor were wheelwell fill tanks - but there were several different vendors that offered dual saddle tank installs - but they would not have had the switch shown in post 1 though. Dealers could also install saddle tanks - but these setups only had the cuts in the bedside for the little metal, lockable fuel filler access doors or wheelwell filler necks. Do you have NL2 on your SPID? If no filler neck on bed, then it's been filled or bed is not original to the truck (assuming NL2 is on your SPID).
Old 06-12-2020, 10:56 PM   #12
Re: What’s this for
Driver side front between bedside and chassis. The other thing, if it still has the same bed, would be the filler tube cover. About 3"-4" wide square "duct" from top of bedside to floor that covered the fuel fill tube.
Old 06-14-2020, 05:06 AM   #13
Captain J
Re: What’s this for
Decal says it has an aux fuel tank, surprise surprise,
Old 06-14-2020, 05:11 AM   #14
Captain J
Re: What’s this for
Couldn’t find either of them, must remove all.
But where is the location of the aux tank and how it’s connected, size of the tank. I like to re install it if easy.
Old 06-14-2020, 05:13 AM   #15
Captain J
Re: What’s this for
I’m not familiar with NL2 & SPID!
Old 06-14-2020, 07:24 AM   #16
sick472
sick472's Avatar
Re: What’s this for
SPID = service parts identification... It's the sticker that was put on the inside of the glovebox door that has the options that where ordered with the truck. NL2 was the aux tank option code.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 06-14-2020, 07:32 AM   #17
Captain J
Re: What’s this for
It has that code NL2, but none exist
Old 06-14-2020, 08:38 AM   #18
Re: What’s this for
I answered a couple of those questions. The fuel line runs from top of tank to the valve in the floor and from valve to fuel pump. The valve is body is a "block", I would call it, like the t-block in your rear brake lines. You'd have to ask for pictures for proper routing.
The tank is something like 10-12 gallons if I remember correctly.
There is also a piece I'd call a guard that mounts across the front of the valve to protect it.
Old 06-14-2020, 01:05 PM   #19
Captain J
Re: What’s this for
Thanks, I found the fuel filler capped (on the left side) painted over, the valve is removed, no fuel lines.
Again thanks for your help 👋🏻
Old 06-14-2020, 06:04 PM   #20
57taskforce
All about them K’s
57taskforce's Avatar
Re: What’s this for
Here’s the NL2 tank and filler from my K20.
Tyler
Old 07-01-2020, 11:15 AM   #21
Cesar Diaz
Re: What’s this for
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Cesar Diaz
1972 C10 Big Block 402 Cheyenne
Cesar Diaz is offline   Reply With Quote
Old 07-01-2020, 11:23 AM   #22
Captain J
Re: What’s this for
I wish I can, I’m 3500miles away, cost of shipping exceeds the value of the switch.
Old 11-11-2020, 04:02 AM   #23
doowopper
Re: What’s this for
Are replacement SPIDs available?
Thanks,
Roger
doowopper is offline   Reply With Quote
Old 11-11-2020, 11:07 AM   #24
LockDoc
The Older Generation
LockDoc's Avatar
Re: What’s this for
Thanks,
Roger
Yes they are.
http://outintheshop.com/
A lot of other good info on there also.
Jeff is a member on here and a really nice guy.
LockDoc
Leon
Old 11-11-2020, 02:25 PM   #25
doowopper
Re: What’s this for
Originally Posted by LockDoc View Post
Yes they are.
LockDoc
Doc, thanks a million. That site is a keeper.
Roger
