Old 06-11-2020, 02:18 PM   #1
Dabigman04
Dabigman04's Avatar
Exclamation cant get a wrench on front bleeder screw
I am having trouble bleeding my brakes. i cannot get a wrench on the front bleeder screws because of their location. My brake pedal goes pretty much to the floor before i begin to stop.
Zachary M. Sefcovic
—— 1970 C10 454 BBC +0.030 over, TH400 - lowered
Dabigman04 is offline   Reply With Quote
Old 06-11-2020, 02:44 PM   #2
68Gold/white
Re: cant get a wrench on front bleeder screw
Another reason to convert to disc brakes....
Sorry, to compound your ordeal...the simplest way I know to remedy this deal, is to take a die grinder and grind a relief in the spindle. It's so tight, making the grinding a challenge also...
68Gold/white is offline   Reply With Quote
Old 06-11-2020, 03:09 PM   #3
toolboxchev
Its pretty simple.
1. Use a deep well 6 point socket to first ensure the bleeder is loose. Sometimes I tighten them just a hair and undo.
2. Take the appropriate 12 point box end and bend it approx. 1/2 to 1 inch from the box end at an angle. I prefer the box end to a line wrench due to the strength being a bit better.
Pic coming. I have used this tool for years, BUILT NOT BOUGHT!
toolboxchev is offline   Reply With Quote
Old 06-11-2020, 03:17 PM   #4
toolboxchev
Wink Re: cant get a wrench on front bleeder screw
Motto I try to live by is "You have to be smarter than the tool."
Get er Done!
Old 06-11-2020, 03:27 PM   #5
my67c20
Hate to say this, but go to Harbor Freight and buy the 7pc brake tool set. It will set you back a whole $20, but comes with all the tools to deal with brake springs, bleeders and adjusting wheels. The wrenches might be a bit flimsy to break a stuck bleeder loose, but they are 6pt and can take a bit of torque.
my67c20 is offline   Reply With Quote
Old 06-11-2020, 04:04 PM   #6
Happy_dan
Happy_dan's Avatar
Yes it's a pain withe brake hose right against it. Amazing the things they do! I ground down a wrench so it would give me a little room. Bending it would be better as shown above but I did get it to work.
Happy_dan is offline   Reply With Quote
Old 06-12-2020, 12:14 AM   #7
External
External's Avatar
I had the same problem. Then I picked up a metric deep well socket.
10mm.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 06-12-2020, 01:00 AM   #8
toolboxchev
Somebody must know my thinkering!
1970, 1970 c10, bleeding brakes, brakes, c10
