![]() Join Date: Aug 2018
Help ID this rear end
I bought this rear end on FB Marketplace and I'm pretty sure it's a 12 bolt, but I want to figure out a few details on it so I can rebuild and convert to 5 lug. I've been searching all over the forum and the internet and haven't been able to decode all of the codes. The seller thought it came out of a 70s squarebody.
Castings on the pumpkin: -GM83 -3896839 N Stamping on the axle tube: -KAN -300W91 Stampings on the ring gear: -3819037 -9:37 -GM 2 801 Pics below. My questions: -Doesn't KAN mean it's a 3:55 open differential? -Doesn't 9:37 mean it's a 4:11 gear set? -Is there a way to tell what year and model (C10/K10/C20/K20) this rear end came out of? I want to buy the right brake parts, bearings, etc. -What is the best deal on a set of 5-lug conversion axles? -Can I use C10 5-lug drums off a 73-80 or do I need something different?
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Re: Help ID this rear end
![]() Join Date: May 2015
You've got 4.11 gears..most likely the gears were swapped over the yrs..the axle orig came with 3.55s
The 300 means oct 27
and 12 bolt truck rear .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
73-81 This most likely out of a k20-k25 since 6 Lugs.
Sorry tried fixing missed that it should have been C20-C25
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 06-17-2020 at 04:47 PM. |
6lug = half ton NOT 3/4 ton thats 8 lug .
I figured it was out of a K10 since C10's had 5 lug. So it looks like I can put C10 drums on? I see that there are two different shoe sizes on C10's and K10's but the corresponding drums appear to be the same, except for the lug pattern and bore.
And for axle shafts, will any 71-83 12 bolt 5 lug axle shaft work? It looks like the shafts for C10's and K10's are both 31-7/16" long and 30 spline.
Moderator
![]() Join Date: Oct 2008
Look it up in the parts books...
KAN axle code was used twice on the squarebody trucks between 1974 & 1991. 8.75" locking rear with 3.08 gears from a 1974 K10 8.75" open rear with 3.07 gears from a 1979 C or K10 with JB5 brakes 8.75" is a twelve bolt axle. It originally came with 3.07 or 3.08 gears. It's also 40 years old or older and gears are easy to change.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#9 | |
Moderator
The Ring gear stamping shows your present tooth counts... 9:37
I would say it's been changed out. 37÷9 = 4.1 so you have 4.10 gears in that axle not the original 3.07 or 3.08. The production code stamping doesn't conform to what the parts books list so I can't give you a year of mfg or the plant. W could mean Warren Ohio but that W is in the wrong place in the sequence.
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-17-2020 at 02:43 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
