Old 06-17-2020, 09:22 PM   #1
kipps
Big Ten?
What years was this name used? What differentiated it from a typical 1/2 ton truck? Was it used on c10 and k10 trucks, or c10's only? Did GMC use this name?
Just a curiosity -- how tacky would it be to put a "big 20" sticker on a "c6p"-equipped 3/4-ton truck? It's sorta' the same thing.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 06-17-2020, 09:57 PM   #2
Ziegelsteinfaust
Re: Big Ten?
Well a C20 is twice as good as a C10. 10x2=20.
So I would do it, and if you get some 70's goodness stickers it will look right.
Ziegelsteinfaust is offline   Reply With Quote
Old 06-18-2020, 08:45 AM   #3
MJN
MJN's Avatar
Re: Big Ten?
Big 10's were C-10, no K's, C-15 GMC's were called Heavy Half. It was a heavier suspension package and gave you a higher GVWR rating. It was available from '76 through '80.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-18-2020, 09:34 AM   #4
Re: Big Ten?
Were bigger rear brakes part of the Big 10/Heavy Half option? I have run into different rear brakes on C10s from backing plate-out. The bigger brake backing plates set inward toward the leaf spring more. Not sure on diameter, but wider for sure
Old 06-18-2020, 10:26 AM   #5
MJN
MJN's Avatar
Re: Big Ten?
It appears they did get bigger brakes on the BIG 10's per this screenshot of the 1978 Vehicle Info Packet on the GM Heritage site
'17 GMC Yukon XL
VCCA member #58596
