Old 06-15-2020, 10:57 PM   #1
Root2812
Root2812's Avatar
Air intake and Maf
So years ago when I started my project I bought this ls2 style Maf in an air cleaner assembly thinking it was cool. My project is very slow..... Now I’m At the point where I need to order my PSI harness and thus need to know what Maf I’m using so I decided to test it on my LS. See pics. So first the collar was too big because it was meant for a larger throttle body but I made it attach with a cheap silicone coupler. Now it’s in the way of my radiator hose and they’d rub. (Old Rad for mock up only but new champion is the same shape)... The company who made the Maf/air cleaner is out of business so I think it’s time to just chock it up as a few hundred bucks wasted and go with the typical plastic tube. Chrome tube would be nice if I could.
So since I have no Maf to start with I’m totally open to how to get an air cleaner and Maf on this thing. What would you guys recommend? I’d like to stay somewhat cheap if I can but I also want a nice clean look. I think to make anything fit I’ll have to go 90 degrees off the throttle body toward the drivers side. I don’t know what type of Maf I should buy. I’m open to any suggestions.
The project is a 1950 Chevy with a 2000 5.3L engine. Engine has LS6 intake and accessories and 2008 corvette water pump. I swapped the the Vette stuff for clearance.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 06-15-2020, 11:04 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Air intake and Maf
That is gonna be a tight fit..spectre makes 90deg rub or boots that will get it turned ..you can put the maf in the long run section..I used alum tube from Ebay on mine and all spectre connectors and filter..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-15-2020, 11:12 PM   #3
Root2812
Root2812's Avatar
Yep everything about this project has been tight so far. I like your idea. What Maf should I use? There seems to be a few choices. My throttle body came with the ls6 intake (2002 corvette is what I think it came off of. Should I use the Maf for that or buy another Ls2 one?
My 1950 Chevy build
Old 06-16-2020, 05:08 PM   #4
LS short box
I would go with a maf from a 2002 Corvette so you aren't mixing and matching parts that make the harness suppliers and tuners go nuts. Is the throttle body drive by wire or cable? I would not use the cheap China units on ebay. They don't have good reviews at all.
Check over on LS1tech and Corvette forums for used parts.
Side note. The LS engine tuners will say that short air filter in your pic will cost you an easy 30 hp because of it's small size and the hard right turn the air needs to make it as it flows into the intake. Additionally if you have electric fans when they turn on and push air towards the air filter it will disrupt the normal air flow to the air filter.
Old 06-17-2020, 04:16 PM   #5
mongocanfly
since your using a PSI harness , they also sell the MAF...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-18-2020, 12:34 AM   #6
Root2812
Root2812's Avatar
The little air filter thing is going away. Its got a MAF built into it and I got my mail order tune and harness already. I am just trying to determine what MAF is essentially the same and a direct swap. Inside that tiny filter thing is a MAF with GM (or DELCO) part number 25168491 but they cut the housing down to make it fit in there. Now I need a new one to go in a standard tube and cone filter set up. I can find 25168491 used but not new. I don't know if the part number changed or what but I know I want a new GM one.
The harness from PSI says its for a 5 wire LS1/LS6/LS2/Vortec MAF so I am pretty sure I can use any of those as far as my wiring goes. But when I had LT1swap flash my PCM I told him MAF 25168491. If I went with the 2002 Corvette MAF its part number is different so do I need a retune or are most of the 5 wire MAFs interchangeable as far as the computer registers.
My 1950 Chevy build
Old 06-18-2020, 07:42 AM   #7
TomMLSx
TomMLSx's Avatar
Rock Auto has one....
https://www.rockauto.com/en/moreinfo...433513&jsn=591
Random search..
https://www.gwaautoparts.com/product...13778234769463
Both are same MAF, one part number supersedes the other. You will need it tuned no matter what, but when you switch MAF's the scaling is wrong depending. One of the tuning steps is to tune the MAF curve no matter what...
T,
TomMLSx is offline   Reply With Quote
Old 06-18-2020, 09:58 AM   #8
mongocanfly
Lots on ebay... https://www.ebay.com/itm/MASS-AIR-FL...edirect=mobile
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-18-2020, 11:48 AM   #9
Root2812
Root2812's Avatar
I don’t want an aftermarket one. I want an authentic GM part but not a used one. Those links you guys shared are aftermarket. Gm parts direct doesn’t even show 25168491 on its site. So I am having trouble finding a brand new GM one.
My question is that since 25168491 is a 85mm 5 wire gm Maf can I swap to another 85mm 5 wore Maf with no problems. For example, gmpartsdirect shows a 2002 corvette used either 19330122 or 19330121 depending on if you had LS1 or LS6. I just wanted to know if these parts are Interchangable without having to tune.
When I find aftermarket or used parts listed as 25168491 they list a bunch of things they fit or came out of but when I search for a new part based on those models I get different part numbers. Was 25168491 superseded by a different number?
My 1950 Chevy build
Old 06-18-2020, 12:43 PM   #10
mongocanfly
I'm not sure what to tell ya ..if you want OEM. Then I'd call the dealership parts counter..give them the 25168491 number,, and see what the replacement part number is for it...
That should give you a current part number to look for..
.I guess I missed where you only want genuine gm...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-18-2020, 05:06 PM   #11
Root2812
Root2812's Avatar
I found the answer to my question. I went out and found someone my dad knows who drives a 2006 Sierra, turned out to be a 4.8l but I looked at the Maf and it’s the same part number I have. I was able to look up the Maf based on that vehicle and came up with a replacement of GM 19330121. According to GM parts direct that Maf works on a 5.3l of the same year. For the heck of it I checked and it’s also the correct Maf for a 2002 corvette zo6. Now I know a current part number that will work for my setup.
My 1950 Chevy build
Old 06-18-2020, 10:49 PM   #12
mongocanfly
good deal
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-19-2020, 07:03 AM   #13
TomMLSx
TomMLSx's Avatar
The first link I posted to Rock Auto is the Delco 19330121.....
Good luck..
T,
Old 06-19-2020, 12:09 PM   #14
Root2812
Root2812's Avatar
I have a few more related questions. So I’ll have 90 degree elbow, pipe, Maf, pipe, then air filter. What length should the straight section with the Maf be? Do I need some sort of support for the filter end or do you guys have good results just letting them hang out there? Then what’s a good size filter to use? I found a K&n cone filter but it’s only 5.5 inches long. Is that too short for a 5.3 or good? I’ve never had a reusable air filter and I think they need oiled, can you use any brand air filter oil? Like k&n oil on a generic filter or vice versa?
My 1950 Chevy build
Old 06-19-2020, 12:35 PM   #15
First c10
First c10's Avatar
No matter what MAF you use it will have to be tuned. I have tuned my stock 2008 MAF but I am changing to a card style MAF and will need to tune all over again since the MAF and intake piping will change. I am using all stock GM parts.
They say the longer the straight pipe before the MAF the better, but sometimes you only have so much room. so a good tuner helps.
I have a dry Spectra filter on one of my swaps and a K&N oiled filter on the other. I use the cleaner and oil for the kind of filter I have. no problems with either.
I hope this helps
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-19-2020, 04:52 PM   #16
mongocanfly
I've seen all the replays about where to put the maf over the yrs...my tuner said it dont really matter as he can tune it to anything...mine is about 1in from the throttle and I've never had any issues..circled in red
And yes..put a support under the tube...I didnt when I 1st got my C30 going and the weight of the filter kept twisting the rubber 90..my support bracket fastens to the fan shroud bolts and goes under the tube and is held to the tube with a hose clamp...circled in blue
And I would go with the biggest filter you can use ..I think mine is about 9or10 in long
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-19-2020, 05:18 PM   #17
LS short box
Here's a pic of my setup. I typically add a brace the under side of the tube and mount it to a open head bolt to support the tube, MAF and air filter. The engine rocks a bit as it's running so I don't like fastening the air tube and filter to a stationary position.
Old 06-21-2020, 12:38 AM   #18
Root2812
Root2812's Avatar
Thanks for the pictures. I will put something together and report back.
My 1950 Chevy build
Old 06-24-2020, 01:24 AM   #19
Root2812
Root2812's Avatar
So here is a possibly dumb question. When you put all these pipes and joints together do you push the pipes together inside the silicone joints so the pipes touch or do you prefer to leave a little space so the joint can flex some? What would the recommended space in there be?
Also, the throttle body is 4 inch and one side of the MAF is 4 inch but the other side is a little smaller like 3.75 inch or something. Do you guys use a reducer coupler or will a 4 inch silicone coupler clamp down that much?
My 1950 Chevy build
Old 06-24-2020, 01:26 AM   #20
Root2812
Root2812's Avatar
Is your 90 degree elbow flexable or the more ridgid plastic? Also is the air filter attached right to your MAF?
My 1950 Chevy build
Old 06-24-2020, 02:34 AM   #21
mongocanfly
On mine in post 16, you can see my 90 has a flex section made into it..
But it would depend on how you route yours
I only used one tube so theres no tube touching going on.
I used a reducing coupling on the maf..
My maf is right at the throttle...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-24-2020, 01:14 PM   #22
aknovaman
I find it amusing to watch you guys try to figure out which MAF and tubing to run and then pay a tuner to 'fix' the file so it runs correctly. If your tuner is worth his pay and you have physical space limitations, then run the motor in speed density (SD) mode including a inlet air temp sensor. That totally eliminates the need for spending money on any MAF. Running an engine in SD mode will give you the same power, throttle response and MPG as running a MAF, if tuned correctly (easy). I have tuned a bunch of street rods with the stupid tiny air filter and cast aluminum MAF as described above. I just don't see the point in spending money for a MAF and time wasted in trying to get a tune right. Side note the inlet air temps would be extreme with the filter right behind the radiator. Seen it every time on 30-50's cars/trucks with narrow and tight engine bays. Placing a MAF right at the throttle body or right before/after a bend significantly affects the readings which directly affects both fuel and timing. This can be proven using and EFI tuning data logger.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 06-24-2020, 05:07 PM   #23
LS short box
The 90 degree elbow is made of rubber. I typically purchase them form IntakeHose.com
Old 06-24-2020, 11:52 PM   #24
Root2812
Root2812's Avatar
Thanks for the help so far. I figured out how to route my set up for now and was ordering the pieces on amazon. I was going with spectre components and saw the 90 degree elbows and couplers in both EPDM/TPE rubber and in PVC. Their website seemed like both types do the same thing so why should I choose one over the other?
My 1950 Chevy build
Old 06-25-2020, 12:15 AM   #25
mongocanfly
I used epdm,,,mainly because that's what they had where I bought all my other parts for the swap
Mongo...aka Greg
RIP Dad
RIP Jesse
