Old 06-16-2020, 11:22 AM   #1
kljfamily
Coolant weep coming from radiator 2003
2003 8.1 4wd suburban
Knew I had a slow leak from somewhere and finally tracked it down. Just under the upper return hose there is a metal hose that connects to the radiator(Trans collier or heating ac line?). I haven’t messed with this kind of fitting before. Is it a seal I need to replace? OR does the whole line need to be replaced.
I’ve added pics
kljfamily is offline   Reply With Quote
Old 06-17-2020, 02:36 AM   #2
EVRLET
EVRLET's Avatar
Re: Coolant weep coming from radiator 2003
It’s a quick disconnect fitting.
https://m.youtube.com/watch?v=r0pmPVXjyLo
You may have to replace the silver fitting that’s screwed in the radiator. I just did this on an 03 Yukon that was leaking tranny fluid from this connection.
The trick to getting the lock clip back in is to put the legs on the solid surface of the fitting and then pushing it down so the leg slides down the solid part and into the groove.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 06-17-2020, 08:29 AM   #3
kljfamily
Perfect thank you it was exactly what I was looking for. Love these forums
Old 06-17-2020, 12:02 PM   #4
hatzie
Moderator
hatzie's Avatar
LH side is the engine oil cooler. RH side is the transmission.
If it's a coolant leak and not oil from that cooler pipe fitting the radiator is knackered.
Those are called Jiffy Tite fittings. They have an o-ring inside that eventually gets flat and weeps.
Replacement fittings come with new o-rings and brandy new strange bendy spring clips.
I don't re-use the fittings or bendy spring clips if they rusty or are of unknown age or more than a few years old.
Lisle sells a four piece set of release tools for these. They're darn nice to have.
This is how the fitting works.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-18-2020, 04:23 PM   #5
kljfamily
I changed that fitting and the weep didn’t stop. Letting the engine run for awhile after removing the shroud gave me a better look and after decreasing I could see it clearly that the leak is not from that fitting but looks like possibly a hairline crack. Can this be jb weld or repaired or should I just tackle the entire replacement
Old 06-18-2020, 04:35 PM   #6
hatzie
Moderator
hatzie's Avatar
JB Weld would be a stopgap at best.
The plastic has started to break down from thermal cycling over time.
Old 06-18-2020, 05:23 PM   #7
AussieinNC
Moderator
AussieinNC's Avatar
Time for a new radiator...
Repairs like JB weld never seem to last...
Some may suggest Bars Leaks....it may or may not work as the plastic swells under pressure when Hot...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 06-20-2020, 10:09 AM   #8
hatzie
Moderator
hatzie's Avatar
I would change it as soon as you can manage it.
Murphys' law and it's corollaries are correct.
That cracking plastic tank will pick the most inconvenient time possible to completely let go. This kind of stuff always happens when you can least afford to have it do so.
