![]() Join Date: Jul 2015
Next steps - it’s running
Ok, it’s running good and I drove it around the complex. It definitely needs brakes gone through, however, every time I released the clutch it was not smooth, it chirped the wheels. Thinking I should go through the brakes and maybe replace the clutch.
Just wanted to get some insight from others, I’m sure there are others in here that have gone through this. As always, I appreciate everyone input.
1963 C20, small window, long bed 292, 4-speed |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Next steps - it’s running
Brakes, Steering, Fuel
Dual Master Cylinder and shoes, or go discs. Get the steering linkage tight. Verify fuel lines are good. Make sure they don't route over the exhaust manifolds. Here is a similar thread: http://www.67-72chevytrucks.com/vboa...ighlight=Order
Everything that Lost said, and I always add a good set of seatbelts. https://www.seatbeltsplus.com/catego...eat-Belts.html
Would the clutch problem be described as grabbing and sticking then? If you do a clutch kit don't overlook having the flywheel resurfaced and maybe even having the ring gear for the starter either flipped around or replaced too. |
I have a single master cylinder, can I add a power booster from RockAuto, or is some kit required? Would brake lines need to be changed?
And, what is the best way to add power steering? Just buy a kit? https://www.performanceonline.com/19...onversion-Kit/
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 06-22-2020 at 10:33 AM. |
Moderator
![]() ![]() Join Date: Aug 2011
Or you could buy the frame adapter from captainfab, the steering box from an auto parts place etc etc. It'd be much cheaper. That POL link doesn't show a engine bracket for the pump http://www.67-72chevytrucks.com/vboa...d.php?t=332923
Return hose - https://www.ebay.com/itm/Power-Steer...9/113738230621 Supply hose - https://www.ebay.com/itm/Power-Steer...QAAOSwV6heIoa1 Saginaw Pump - https://www.ebay.com/itm/BLACK-Sagin...0AAOSwmphcoTOC The bracket for the pump would depend on your set up now, Water pump length and other brackets/pulleys currently used. And the power brake booster firewall adapter - http://www.67-72chevytrucks.com/vboa...=1#post3257836
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 06-22-2020 at 11:59 AM. |
#6 | |
Return hose, supply hose, pump, bracket for the pump, bracket for the booster - Comes out to around $271.00. The only thing I need is a close-ratio steering box. That's going to cost about $300-$400... still comes out to the same cost.
