#276 |
Re: Greg's 50 Build
Oh boy, I wish I had done this years ago. I let things get in the way of this project and then I lost interest for a while. I have been getting a lot done the last 2 months and am really close to running my engine! I bought a new harness from PSI that arrived today so I need to install that. Other than that I need to finish my fuel lines, radiator and hoses, and a few other odds and ends. My goal is now to have it run by July 19th because that's the 6 year anniversary of the day I last drove the truck and blew the motor.
I got the borgeson power steering pressure reducer kit to install so the pump is off but it looks so good I am getting really excited. This engine is huge! Space is tight. I will have to modify both inner fenders but there is lots of room to wheels at full turn. I also have just barely enough space for steering linkage but it will work. |
#277 | |
![]() Join Date: Mar 2007
Re: Greg's 50 Build
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#278 | |
Re: Greg's 50 Build
Since you had the GM type 2 pump and the ford rack, what fluid did you go with. The GM pump says power steering fluid but my 96-98 mustang rack says mercon ATF. I saw the 79-93 rack called for type F ATF. Oh and BTW, your truck has been an inspiration for me. A long while back you helped me in PM with some exhaust questions because I want my exhaust to be though the running board like yours. I had to pull the exhaust for now but I did buy the flex joints you talked about and put them before my x pipe. Then I have a set of hangers at each Borla muffler. I will probably put in a much smaller flex at the hard mounted tip so the exhaust can move and the tip stay put. I figure this way I have more flex and room for expansion by the down pipes and then a little room for movement further back. As soon as I get it all reinstalled I will share a photo. Last edited by Root2812; 06-22-2020 at 11:34 PM. |
#279 | |
Re: Greg's 50 Build
Marc
#280 |
![]() ![]() Join Date: May 2015
Re: Greg's 50 Build
Nice looking goat..!
#281 |
Re: Greg's 50 Build
gotta love those Ponchos
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#282 |
Re: Greg's 50 Build
Hey Greg, good to see you back at it. I rarely post any more since my truck is basically done and I drive it when ever the weather allows! Always tinkering though...added a fulton visor and built a center console over the winter.
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
#283 |
Re: Greg's 50 Build
Thanks for asking them. I am hopefully going to get to fire my engine in the next few weeks and I want to make sure everything is filled up and ready to go when I do. I am looking forward to hearing what they say.
#284 |
Re: Greg's 50 Build
Thank you. We are really proud of it and my dad is very happy. Its not perfect but its a fun driver. The interior is a mix of old and new stuff but one part at a time its getting refreshed. We had no engine to start with but we found a not so nice 73 Grand Prix that had a nice running Pontiac 400 and turbo 400 trans and picked the car up for $1500. That made good value for an engine donor and helped move progress along faster. Its got a highway gear rear end so its not a rocket off the launch but its a great cruiser.
Nice looking car! I like that gold color. We went with the victory red off of my dads 2015 Silverado. It fit the car well. |
#285 |
Re: Greg's 50 Build
Good to hear from you. Its been a few years since we bumped into each other now. I am glad to hear you are still enjoying your truck. I hadn't posted on here in a long time too but since I got fired up for this project again I have been asking questions left and right.
#286 |
Re: Greg's 50 Build
On the gm power steering pump to the m2 rack I used all the spacers to get the pressure reduced on my 39 ford build. It tightened up the steering and drove very nice.
#287 |
Re: Greg's 50 Build
I ended up using the recommended amount of shims in the instructions. I saved the rest incase I need to add more later.
#288 | |
Re: Greg's 50 Build
Marc
#289 | |
Re: Greg's 50 Build
After that it was really easy. The second thing that worried me was that when I took the valve apart there was a.... well I don't know. It was either a really thin and misshapen washer or the remains of some kind of thread sealer. I honestly couldn't tell but it fell apart when I tried to remove it to place the shims. I guess I will see if everything works when I finally get to driving. Reassembly was easy too. I forget the exact number of shims I used but I googled what PSI the mustang rack likes and then used the number of shims the instructions said to use to get that pressure. They have a chart. |
#290 | |
Re: Greg's 50 Build
Marc
#291 |
Re: Greg's 50 Build
I’m getting closer. I have some loose ends to tie up still but the main things are getting done. I still need to move the motor back a 1/4 inch and set all my pinion angles. Then I’ll put in a new trans filter, install the exhaust, install aluminum radiator (Old for mock up to avoid accidental damage), make hoses, and fill the fluids. Having built the motor too I am really nervous and excited to hear it run.
I managed to avoid any firewall mods by getting the engine low and using the corvette accessory drive to keep the engine forward. I’ll have to modify the inner fender but that’s ok. I’ll just keep chipping away and soon it will run and I can start building the rest of the truck! Also, I found a cool assembly line mark. It’s a cursive G which also happens to be my first initial. No idea what it was meant for but they did it before paint so it survived. I think it’s cool. Edit: sorry the pictures are sideways. They’re not sideways on my phone and this is my first mobile post. |
#292 |
![]() Join Date: May 2007
Re: Greg's 50 Build
really nice work!
#293 |
Re: Greg's 50 Build
Nice progress....Your getting there..
Marc
