Old 06-25-2020, 07:18 AM   #26
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Tow Hooks: Post your foundry casting marks
The one forge symbol above resembles that for the Continental Foundry and Machine Co. shown here: http://the.shadock.free.fr/sherman_m...Trademarks.pdf
I know there is another thread re white tow hooks but to add to Larry’s post here’s yet another example. Prior to the 72 model year tow hooks as a factory option were only available with a painted bumper. For 72 the painted bumper requirement was dropped but hooks could only then be had on “K” models. I suspect at least some were painted white by GM and perhaps it’s a plant-specific like white paint accents in highlander blazers from St Louis.
Old 07-01-2020, 12:36 PM   #27
MJN
MJN's Avatar
I dug these out just to see if they had similar markings but they do not and appear never to have been installed. The only marking on these is the '2800'. Best I can tell these are part number 2234024 front hooks for 3500-5000 series trucks.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-01-2020, 02:27 PM   #28
MJN
MJN's Avatar
Another I found- same hexagon with U in the middle. Believe this is a C-60 and larger style front tow hook.
'17 GMC Yukon XL
VCCA member #58596
Old 07-04-2020, 04:33 PM   #29
too much stuff
Roadtrip!
too much stuff's Avatar
Rear hook...Starting to see a pattern on the symbol here.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-24-2020, 12:32 PM   #30
davischevy
davischevy's Avatar
Some more from another pair. I couldn't detect any evidence of white paint on these.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 07-24-2020, 10:38 PM   #31
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for posting.
For the curious, here’s a link to the white tow hook thread: http://67-72chevytrucks.com/vboard/s...d.php?t=799808
Old 01-12-2021, 11:01 PM   #32
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Figured I’d post examples of the reproduction tow hooks now circulating. Would be helpful to have more examples so please post ‘em if you got ‘em.
The 72-only extreme bend examples (only photo I have) of the “same grade steel” not otherwise specified.
Old 01-12-2021, 11:03 PM   #33
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Examples of the 69-72 style reproductions (cast not forged) - tips look more pointed to me
Old 01-12-2021, 11:08 PM   #34
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Believed to be reproduction 69-72 examples courtesy of member landarts. Note mirrror image relief of the p/n
Old 02-12-2021, 09:19 PM   #35
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Another replica being sold. “Sand-molded, mild steel” I guess that means cast not forged copies of the original. What is “mild” steel?
Old 02-12-2021, 09:31 PM   #36
IronCanine
I'm trying....
IronCanine's Avatar
Mild steel means low carbon. Definitely cast. More likely to bend and break.
EDIT: BTW...if we're going to start casting something for these trucks...why aren't we doing the trim rings for the 3/4T Spicer lockouts. No safety issue there (though I assume no one is hooking a chain the those repro hooks), and IMO there is a definite market for them. I mean the repro plastic dials are $100 for gosh sakes.
DOUBLE EDIT: I guess these are stronger than I would have imagined according to 72ironmike: https://67-72chevytrucks.com/vboard/...d.php?t=818316, but GM forged the originals for a reason.
IronCanine is offline   Reply With Quote
Old 02-12-2021, 09:52 PM   #37
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I use my tow hooks and these repops just make me nervous. I just put medium truck front hooks on the rear of my truck.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-07-2021, 01:05 PM   #38
Ironhorse
Ironhorse's Avatar
Bring back an older thread on the tow hook mysteries. Just acquired these 3 hooks, two an obvious pair and one looks to be a LH single. Have seen a LOT of tow hooks thru the years but have never seen anything like these at all. Look VERY similar to the 73-80 style tow hooks seen on the square body trucks except for the odd curvature at the mounting end. Lower portion is identical to the curvature of the 73-80 hook end. One hook is marked "14029217" and I presume a left hook with the PN ending in an odd number. The other two are marked "14029218", one having additional numbers of 468, the other does not. The 14029217 hook has additional numbers of 400. ALL have the letter "U" clearly marked on the shank. 5/8'' diameter mounting holes, holes are 3 3/8" at center to center, shank is 1'' in thickness. Each weighs a hefty 4 1/2 lbs per.
Was doing a search for these thru the board and landed on this thread. Perfect place to post these and hopefully someone has some info concerning them. Was going to post on the WIW board for a future SALE thread but thought this would be a better place for posting.
A Google search turned up NADA for pics or info on these.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 11-07-2021, 01:49 PM   #39
MJN
MJN's Avatar
Those look like 81-87 hooks. Regular RPO for hooks is V76 but there is also V70 for Hooks-Towing-Export. Not sure what would be special for export tow hooks.
Looks like there was a pair similar listed Ebay awhile back https://www.gm***************/thread...-option.24301/
'17 GMC Yukon XL
VCCA member #58596
Old 11-07-2021, 02:18 PM   #40
cak20
cak20's Avatar
just released 69-72 non extreme tow hooks.
https://rustyk5.com/products/69-72-tow-hooks
cak20 is offline   Reply With Quote
Old 11-07-2021, 04:19 PM   #41
DeadheadNM
Carpe manana
DeadheadNM's Avatar
“Sand molded” “Mild steel” “Virtually unbreakable” aka dangerous.
Old 11-07-2021, 07:19 PM   #42
Ironhorse
Ironhorse's Avatar
Agree the hooks I have posted look similar to the 81-87 style but to the best of my knowledge the 81-87 style hooks are made more in a true round rod shape with an obvious bulge or bulbous section at the bolt mounting. Much more slender in design also.
As for the reproduction sand cast hooks, don't think I would want to put those to a real test other than for just to be stylin' so to speak. Mild steel and sand cast would not even come close to a forged hook in strength in my opinion. I'll stick with the General's original forged hooks.
Should come with a "REPRODUCTION" marking of some sort. Bound to get someone hurt or worse one of these days.
Wellington, Ks
Old 11-07-2021, 07:55 PM   #43
too much stuff
Roadtrip!
Pretty sure those are the late 70s heavy duty gm option. No sure how many years they were used, but i think they were like a one ton application. Check with trevor from KS. (drawing a blank on his board name) Or ask on the 73-87 side. I may need a single, but can't remember which side if they come up for sale...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 11-07-2021, 08:26 PM   #44
Ironhorse
Ironhorse's Avatar
Eric, You Are Da Man,!! Went to the 73-87 forum section and did a search for ''one ton tow hooks''. An older thread came up from 2013 for tow hook options on 81-87 trucks. Believe it was member KrazyLarry who posted a pic of those exact same hooks saying a friend of his pulled them from a one ton 4x4 at a salvage yard. Also mentioned they are rather extremely hard to find. Makes sense being for the one ton crowd as with a beefier frame and running gear combo it would make for a more extreme load pulling weight capability possible. They will be going to the 73-87 parts forum at some point. Check to see if you need a single left or right if you have an interest in such. Thanks for the search tip,
Wellington, Ks
Old 11-07-2021, 08:40 PM   #45
Ol Blue K20
I'll second the "dangerous " if used as a real hook was intended.
Dale
Old 11-07-2021, 09:53 PM   #46
Ironhorse
Ironhorse's Avatar
Eric, sent member Keith Seymore a PM in hopes he will chime in with any square body info and knowledge he has about these tow hooks.
Wellington, Ks
Old 08-13-2022, 02:28 PM   #47
sdwolff98
Turning Wrenches Daily
I just acquired an 82 k20 frame with those tow hooks on it. Definitely time to check my parts books and see if they have a listing in them.. otherwise gmpartswiki here I come!!
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 08-13-2022, 02:48 PM   #48
sdwolff98
Ok gm parts wiki has a parts update page which ties the 1402 7917 to another hook and that hook ties to another parts number hook lol and it got less beefy as you follow the parts lol
Sean
