Old 05-03-2020, 05:53 PM   #51
J Williams
J Williams's Avatar
Originally Posted by notsolo View Post
After your Done with primer.......fast Light even coat of color, Not trying to get color, just cover. By the time you have gone over everything, start at the beginning Slowing down, and overlapping 50% ...Getting just the right amount of paint on without runs is the hard part.....Slow and steady like the robot, he talks about in video....Nothing better than laying down paint, some runs will happen. Spraying outside can be tricky.....in a garage, doors almost down with fans to pull fumes out, filters for air coming in. Wet the floor down, reduce dust. Practice panel to get the gun set....I did the white 1st, cover most of the parts you don't want white....keep the over spray and dust off....reverse.
Remove tape and paper and tarps. ...mask off white after it dries about an hr or more, 3m blue painters tape is good stuff.....Cheers Ed.
Copy that! Thanks man
J Williams is offline   Reply With Quote
Old 06-18-2020, 12:45 PM   #52
J Williams
J Williams's Avatar
Well my first attempt at painting. Went pretty good! Not sure that the color match is perfect but it’s close. Tipped the cab onto its back to paint the roof and ceiling and then rolled it back over to get the rest. Actually surprised how smooth the paint laid down.
Old 06-18-2020, 02:29 PM   #53
cwcarpenter98
cwcarpenter98's Avatar
Re: Grandpa’s 63 C10 build
That looks good!
Makes me want to paint the interior of my truck once I fix all the rust
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 06-19-2020, 12:29 AM   #54
notsolo
notsolo's Avatar
Looks great, hot color with white just pops. Your going to need to mask off the interior when you get that done keep the over spray out.
notsolo is offline   Reply With Quote
Old 06-19-2020, 11:35 PM   #55
J Williams
J Williams's Avatar
First of all, thanks guys! I just couldn’t take it though. I want the original or as close to the original as I can get. So after a lot of research I found a color I think matches a LOT better. I guess this new color is the color they used in 69. Not sure why the colors from 63 don’t match. But I am happy with this color and like you say, the white will really make it pop! Too bad I have a gallon of that other orange! If anyone can use it I would be happy to give it to them. The second photo is of the inside of the door jam where it doesn’t have as much color fade.
Old 06-20-2020, 02:05 PM   #56
notsolo
notsolo's Avatar
New color looks great, it does seem to match better. 1 gallon of color is going to be close, even with the white. Painting skills looking good.
Old 06-20-2020, 02:29 PM   #57
J Williams
J Williams's Avatar
Thanks man. I have heard about nightmares later on like cracking and such.... hopefully I won’t have any problems. If it holds up and the rest of the project goes that easy I will be stoked!
Old 06-20-2020, 10:16 PM   #58
Captainfab
60-66 Nut
Was the first color Omaha Orange?
Old 06-20-2020, 10:57 PM   #59
J Williams
J Williams's Avatar
Sure was
Old 06-21-2020, 11:30 PM   #60
Captainfab
60-66 Nut
I would be interested in that gallon of it you have left.
Originally Posted by J Williams View Post
Sure was
Old 06-22-2020, 08:43 AM   #61
J Williams
J Williams's Avatar
Sounds good to me. Someone might as well use it. I like the color it just doesn’t match. How would you want to take ownership of it?
Old 06-22-2020, 10:11 PM   #62
Captainfab
60-66 Nut
Send me a PM with your contact info again and we'll work out the details. I do not have it still from our past business.
Old 06-23-2020, 09:33 AM   #63
roll_the_dice
roll_the_dice's Avatar
Looking good J! Glad I found your build thread!
roll_the_dice is offline   Reply With Quote
Old 06-23-2020, 10:19 AM   #64
J Williams
J Williams's Avatar
Thanks man. Slowly trying to get it put together
Old 06-24-2020, 03:26 PM   #65
J Williams
J Williams's Avatar
Well I finished these up last week, wish I would have talked to Roll the Dice before I did.... his lines look better then mine but I still think the turned out good. I am thinking about doing a thin pin stripe of the orange around the edge. Not sure yet, maybe black.
Placed another LMC order to finish up the dash. Heater cables, instrument panel lights and a couple other items. Performance online is supposed to be swapping me motor mounts, hopefully they follow through.
Old 06-24-2020, 05:25 PM   #66
roll_the_dice
I think it looks good...The 2 tone is a nice break on the door! Our builds are so similar!
Old 06-24-2020, 07:49 PM   #67
J Williams
J Williams's Avatar
Yeah they are!
Old 06-25-2020, 06:32 AM   #68
notsolo
notsolo's Avatar
Looking good....On the glove box door, those 4 horizontal lines in your accent color.....3m fine line tape is good stuff for crisp clean lines.....
Old 06-25-2020, 08:23 AM   #69
J Williams
J Williams's Avatar
Thanks man, and thanks for the idea. Always up for tips or tricks. This is my first ever build so learning as I go.
Old 06-25-2020, 12:29 PM   #70
clemdaddy
clemdaddy's Avatar
[QUOTE=J Williams;8763537]Thanks man, and thanks for the idea. Always up for tips or tricks. This is my first ever build so learning as I go.
You are doing great. If this is your first build... wow, very nice. And, by the way, a family heirloom is the best motivation there is.
Real good advice and help 'Notsolo'.
clemdaddy is offline   Reply With Quote
Old 06-25-2020, 02:39 PM   #71
J Williams
J Williams's Avatar
Well yesterday was a crappy day. I was exposed to a positive COVID person for about 3 hours in a vehicle. I have been placed on admin leave from work for 14 days. Had my wife get the camp trailer ready, thank goodness I have a camper! I am now quarantined from my family for 14 days as well. At least they can visit me from a distance. Probably see a little bit more accomplished on my truck as long as I don’t get sick. Y’all stay safe out there
Old 06-25-2020, 02:47 PM   #72
roll_the_dice
OMG J... I am sorry buddy! Hopefully it will pass soon. At least you have a camper! Keep your family safe...Will be praying for a quick recovery!
Old 06-25-2020, 02:54 PM   #73
J Williams
J Williams's Avatar
Thanks man I appreciate the prayers. God is in control and He will only allow what is in His will. Not too worried, just want to keep my family safe.
Old 06-26-2020, 07:01 PM   #74
notsolo
notsolo's Avatar
Also sorry to hear this, good you have positive additude. Hang in there...Ed
Old 06-27-2020, 12:57 AM   #75
J Williams
J Williams's Avatar
Thanks man. Doing good so far. Just missing hugs from the family!
