Old 06-27-2020, 01:02 PM   #1
1-PU70
1-PU70's Avatar
Front Brake Fitting Size
This fitting came off the front brake lines of my 70 (drums all around)
Can someone tell me what size this is or a part#
I need both pieces
Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 06-27-2020, 05:47 PM   #2
HO455
HO455's Avatar
Re: Front Brake Fitting Size
Hard to certain from the photo without measurements. But I believe it to be a common tee with 3 inverted female flare connections. The 2 end ones should be 3/16" and the center 1/4". The 3/16" & 1/4" designations come from the tubing size. 1/4" tubing should be 7/16-24 and the 3/16" should be 3/8-24 threads. The other fitting is once again I am guessing is a 1/4" tubing inverted flare fitting.
They should be available at NAPA or other Dorman suppliers. If you are unable to find the tee in the 3/16 x 1/4 x 3/16 configuration you can use one with all 3/16 threads and then an 1/4 to 3/16 adapter. (2nd link)
https://shop.advanceautoparts.com/p/...7CL4*-49996422
https://shop.advanceautoparts.com/p/...8281/9075429-P
RIP Bob Parks.
