06-27-2020, 03:36 PM | #976 |
Re: A '54 named Busty
then although I chased the threads in the holes, and wire wheeled the exhaust manifold bolts, and even used anti seize on them, one of the bolt heads broke off on me, darn it! and I wasn't even in the ultimate tightening phase yet - wth?
Note: this is very common so I didn't even have to make a deposit to the swear jar, I swear - ha ha Last edited by Gregski; 06-27-2020 at 09:39 PM. |
06-27-2020, 03:41 PM | #977 |
... and that still wasn't the worst of it!
both Hooker down pipes were clocked wrong for the second gen Camaro subframe leaving no room for the O2 sensors |
06-27-2020, 03:48 PM | #978 |
10 minutes later... it was all over but the crying
(I gotta tell you, you aint Hot Roddin' if you aint choppin' brand new parts before they even go on the rig for the first time, am I right fellas?) |
06-27-2020, 03:49 PM | #979 |
then it was on to the other side (passenger)... re clocked this one as well
06-27-2020, 03:52 PM | #980 |
and then it was on to the intermediate pipes, here is the driver side done!
Notice I decided to keep things difficult and make the entire 6' stretch out of nothing but 6" or shorter pieces, ha ha (had to use what I had on the account of the virus and all) |
06-27-2020, 08:50 PM | #981 |
Dang that’s some high quality H2O!
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
06-27-2020, 09:42 PM | #982 |
then it was on to the passenger side side...
I'm really happy with the way the exhaust turned out, job done! |
06-27-2020, 09:43 PM | #983 |
I also installed the shortened and balanced for $85 drive shaft!
06-27-2020, 09:44 PM | #984 |
So here is our LS Swap - Progress Report Card - LSS-PRC
06-28-2020, 05:49 AM | #985 |
Grate progress on the truck. 85 $ that ja really cheep. Here in Germany you pay 300 to 400 Euro for shortening and balaceing the driveshaft!
So long |
06-28-2020, 08:17 AM | #986 |
Man you're gonna be driving it real soon. Congrats.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-28-2020, 08:29 AM | #987 |
yeah, the trick is to keep your head down and not let them upsell you like last time, when they ask what it's for it's for a 350 small block with a TH350 that's it, cause if you start running your mouth and saying it's for an LS Swap and you want up to 500 horse at the rear wheels they will sell you a whole different brand new drive shaft, and fact is you won't be pulling that much power in your truck, at least not for a while
06-28-2020, 08:31 AM | #988 |
06-28-2020, 08:39 AM | #989 |
1 1/2 at least!
06-28-2020, 11:15 AM | #990 |
06-28-2020, 11:18 AM | #991 |
well time to do the fuel system, and unlike my 2001 LS Swap donor, this being a 2004 it does not have a return line, so I only needs to run one 3/8ths line from the 95 Blazer fuel tank to the fuel rail
nothing to it but to do it |
06-28-2020, 01:10 PM | #992 |
What regulator are you running?
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
06-28-2020, 09:17 PM | #993 | |
of course its two builds, most notably because you had the old motor in and hooked up!
06-28-2020, 11:32 PM | #994 |
06-29-2020, 12:32 AM | #995 |
Curious if your doing a vette setup or a aftermarket one.
06-29-2020, 01:07 AM | #996 |
06-29-2020, 01:09 AM | #997 |
Fuel pressure reg is on the engine fuel rail, drivers side rear.
06-29-2020, 01:25 AM | #998 |
not starting in 2004 through 07
06-29-2020, 07:22 AM | #999 |
there are two types of returnless systems, the early had the FPR at the fliter so it was only returnless at the engiine, there was a return at the rail. in 2005?ish the returnless moved the filter and FPR to the tank pump, and added a fuel pressure sensor there so the PCM could modify pressure based on load. if that means you need some type of regulator, I have no idea, I havent swapped one, only worked on the two different systems as stock.
06-29-2020, 09:21 AM | #1000 |
I'm certainly no one qualified to give advice here, but I believe you need the Corvette regulator ( 2 lines in and one line out) for this set up. Someone qualified please verify this because I will be doing this set up very soon.
