#76 |
![]() Join Date: Aug 2017
Re: My 1968 C-20 Golden Anniversary Project
Cylinder head hole indentification
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 |
#77 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Heads look great! Tell me about the beer in post #70 please
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#78 |
https://www.google.com/url?q=https:/...8FbdZmDlXE48RB
Augustiner Hell ( means not Hell means bright) My favorite if I'm not in US and drinking IPA
#79 |
Measurement of the hole for the temperature sending unit, guessing 1/2 NPT, will show evidence later.
#80 |
Insvestigation where to measure the valve shaft ( Approx, 1.5" of the shaft is in the chamber and the valve guide is round about 2" long. Differences between several instruments. Use the micrometer therefore (3 Positions all 0.3414")
#81 |
Valve head 2.02 " and 1.60"
Preparation for measurment chamber volume.
#82 |
Forget to screw in the spark plug = Leak & again
Chamber volume 63 cc Intake runner 164 cc Exhaust runner 52 cc Small block 64cc: Amount to reduce chamber volume by 1 cc (milling): 0.0055" Remember: In the outer area cylinder heads up to 0.3 mm (0.011811") removed, means more or less matching.
#83 |
So next steps:
1) Evidence for thread temperature sending unit in cylinder head driver side: NPTF 1/2 x 14. Remember NPTF is similiar to NPT but not identically. 2) Thinking on tomorrow: Piston stop tool already bought.
#84 |
Load test on the rocker stud threads: 60 ft-lbs (without oil, sealer or antisizing)- ok and ready for go (production is 50 ft-lbs). Nut: deep-well wrench 11/16".
Rocker studs are 3/8 fine thread x 7/16" course thread, length overall 2.475". Earlier pressure test done and investigation: no guide plates needed (as in the original engine in my car).
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-04-2020 at 07:26 AM. |
#85 |
To measure the gap of the valve guides is not so easy for beginners. In my opinion you need a couple of hours to get a feeling what can be true and what not.
First cleaning of the guides. I used two measurement tools. First digital inside calipper. You have 5 digits thats could be a litte bit confusing because even if you make the identically measurement twice, you dont get the same last digit. But on the end is easier than expected. Let say a new valve has 0.341" shaft diameter (and this is over the complete shaft lenght. Than the maximum stem clearance can be inlet 0.0027" + 0.001" and exhaust 0.0027" +0.002". So that means the guide must be less than 0.3447" inlet and 0.3457" outlet. In practice I was measure all inlets and exhausts and was looking that I have no 0.35" at all. I get all guides below the limit. Than I asked an expert, he don't measured the system, only moved a new valve in the guides and told me: "Good for go"! Guide job will only burn additional money and is not necessary yet. Second I used an inside feeler and micro, was also very suitable and delivered the same results. Further I measured a brand new bronze insert: 0.342, ok bether than my existing with 0.344 but will do without guide job.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-04-2020 at 07:23 AM. |
#86 |
Last for today: Looking for warped heads, but the heads are already resurfaced:
By the way my orientation is a good book: "How to rebuild your Small-Block.CHEVY by David Vizard". Example given, there you will find that the limit of warpage schould be 0.003" (a compound gasket will take up far more warpage up to 0.005" according David. Result: Less than 0.0025" Monday shopping: 16 pcs Rocker stud (because I lend) 16 pcs Rocker arm 16 pcs Ball seat (Pivot ball) 16 pcs Rocker clearance adjusting nut 08 pcs Inlet Valves 08 pcs Outlet Valves 16 pcs Valve Springs (use always new one) 16 pcs Valve spring retainer (I got already with the heads) 32 pcs Keeper (use always new one) 16 pcs Oil seal To fire on the 50 years old short block: 01 pc Oil pump 01 pc Oil pump securing bolt 01 pc Oil pump pickup pipe 01 pc Oil pump drive shaft 01 pc Oil pump drive shaft adapter 01 pc Oil pan 01 pc Oil pan gasket 14 pcs Oil pan bolts (small) (1/4"-20UNC x 1/2"long) 01 pc Oil pressure switch 10 ltr. Breake in oil 04 pcs oil pan bolts (large) (5/16"-18UNC x5/8" long) 14 pcs oil pan bolts star washer (1/4" diameter) 01 pc Oil filter pressure relief valve housing 02 pc oil filter pressure relief valve housing bolts 01 pc Oil filter spin on cartridge 01 scew set small block 01 gasket set small block
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-27-2020 at 01:27 PM. Reason: Parameter changed to 0.0025" |
#87 |
And preparation for the new valves:
looking for stock similiar but stainless steel. At the moment I believe that the contact area (Seat width) shut be: .060 to .080 inch for the exhaust and .040 inch for the inlet. (Exhaust must transpoprt more head) .060 to .080 inch = 1.524-2.032 mm = 1.5-2 mm .040 inch = 1.016 mm = 1 mm Apply the paste to 3-4 points on the underside of the valve. Rotate the valve in the seating with the valve grinding tool, lifting occasionally. You can tread the paste with a litte bit oil. Good cleaning after is mandatory.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-05-2020 at 06:45 AM. |
#88 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Your going to have a nice set of heads
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#89 |
Carpe manana
German engineering - love it!
#90 |
![]() VALVE SEAT JOB BY MACHINE SHOP Heads are already there. In the meantime two other side jobs: Left door glas is shaking. Railing is rusty.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-14-2020 at 03:56 AM. |
#91 |
White side covers produced by SMS Auto Fabrics. Tool for removing the securing brackets door handle.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-13-2020 at 09:31 AM. |
#92 |
:-) Little bit rusty but below strong american steel. I'm happy.
Several paints and rost lockers are not allowed in Germany by law, therefore my favorite: 1. Owatrol oil (Rost stopper) 2. Brantho Korrux nitrofest (under coat) 3. Sealer Korroflex 4. Minimum 2 layers Brantho Korrux nitrofest 5. Alkydharzlack (Alkyd resin varnish) 6. Klarlack (clear varnish) In the last picture Owatrol already done.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-13-2020 at 04:55 AM. |
#93 |
Next layer done.
#94 |
Wow Gerhard! You've been working hard at it! Looks fantastic my friend.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#95 |
Hi my Friend, thank you for the compliment. On the end it is heavier than expected. It was my first paint job and the roof railing and pillars are the most complicated places I think. As the spray can for the under coat was empty I used a paint roller- THAT WAS A HUGHE FAILURE! The surface is than not smooth enough for the final coating. I was removing everything again by grinding. A couple of days. But now it comes to an aceptable surface.
Have seen your project has done a great step forward too and your shop -GREAT!!!
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-20-2020 at 12:05 PM. |
#96 |
Ready for final Cameo white, already tested on one place.
#97 |
Looking good, don't forget to post a picture after paint.
#98 |
Clear vanish added, paint preparation (taping) was not precise enough- that means time saved on the beginning and lost by factor 3 on the end, a lot of work. Will do more accurate next time.
For spray and first job the result looks good. Color is 526 Ivory (also of-white and Cameo white)
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-26-2020 at 08:57 AM. |
#99 |
Was starting to make some measurements on my motor, found out that I need a gauge with thread not rubber as it is not enough comfortable for me.
Spark plug #4 is oily, all others good bud maybe a little bit to lean (more white than brown color). GAP is 0.035". Compression between 11-13 bar, but measurment will be done again with different gauge (with thread).
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 07-26-2020 at 12:00 PM. |
#100 |
The hard work of preparation has paid off. Congratulations on a job well done! The roof paint really looks great.
Tags |
327, c-20, golden anniversary, th400, truck |
