07-06-2020, 09:23 AM | #1 |
Is this all for the TCS Harness?
I have a small harness from my 72 and I am thinking it can be deleted. It went through the firewall where I am pointing at. The relay looks like it mounted above the horn relay by the steering column under the dash and should be Trans Control Spark Relay. I will not be putting TCS back in.
Is this whole mess for the TSC? Or, are there wires in there which I may need?
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
07-06-2020, 09:29 AM | #2 |
Who Changed This?
Re: Is this all for the TCS Harness?
That appears to be all of it. If all your equipment works, you didn't lobotomize it too much. Did you also remove the solenoid from the passenger's side of the intake manifold? You don't have to take the pressure switch off the trans unless it is leaking.
07-06-2020, 10:21 AM | #3 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Looks like it to me. I used the 10 gauge pink wire for my HEI installations on both my 72's. There was an idle solenoid and a vacuum switch located on the intake. Getting rid of all that really cleaned up the motor. I don't recall having those holes in the firewall though...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
07-06-2020, 11:40 AM | #4 |
Yup, that is definitely it. As Ironangel said, you can use the pink power wire for something else.
72 C10 lwb fleetside -stock 350/350 combo |
07-06-2020, 12:05 PM | #5 | ||
Thanks for the fast repies!
I think I will ditch the whole harness, meaning put it in a box just in case somebody can use it someday.
07-06-2020, 12:11 PM | #6 |
Oh, and I found this today...I think this is for the 70 TSC wiring, but 71 and 72 should be the same. It's starting to make some sense.
