Old 07-07-2020, 10:28 PM   #376
roll_the_dice
roll_the_dice's Avatar
Re: 1965 LWB Stepside Build
OK, so I made a deal tonight to buy a new truck. It is getting delivered in a few weeks. A matching numbers 64 GMC 1 ton Dually. It runs, needs a new master cylinder...no idea what I am going to do with it. Probably put a flatbed on it eventually. Not going to touch it (much) until I finish my current truck. I will start a new build thread when I get it and start on it. Here is a teaser picture...
roll_the_dice is offline   Reply With Quote
Old 07-08-2020, 10:22 AM   #377
J Williams
J Williams's Avatar
That looks like a good time!
J Williams is offline   Reply With Quote
Old 07-08-2020, 12:51 PM   #378
straight6chevyguy
straight6chevyguy's Avatar
Keep up the great work it's looking good!
And the dually looks like the beginning of another great project!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 07-10-2020, 06:54 PM   #379
roll_the_dice
Thanks! I think the dually will be fun, but I won't start anything on it until I finish my current one.
Going to bleed my brakes tomorrow morning. I went around and made sure all the bleed valves would open yesterday. Got the 2 for the rear drums cracked...the fronts would not budge and one broke. I tried PB Blaster, heat, etc etc and multiple times...I tried everything. Then I went out and spent $22 per wheel for new brake calipers! So today I swapped out my front calipers and put in new pads at the same time. Was worth the $ not to fight with the bleed screws any longer. Probably should have swapped out rotors also, but I will down the road.
Once the brakes and clutch are bled, I am going to start buttoning up the front end and getting things back together! Shouldn't be long before I am driving it.
Old 07-10-2020, 07:24 PM   #380
Johns 66
Johns 66's Avatar
I have seen this truck somewhere......hmmmmm
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 07-11-2020, 12:13 PM   #381
roll_the_dice
Thanks for taking a look at it for me John! Glad you were close enough to do that! Sorry the 59 didn't work out for you.
Got my brakes bled this morning! WOOHOO I need to get the clutch bled and get the exhaust on...1 thing down...not as many to go!
Old 07-13-2020, 06:11 PM   #382
roll_the_dice
BIG DAY today! I got the clutch bled and hooked up the battery and installed the Steering Wheel...and backed it out of the driveway and pulled back in! First time it has moved under its own power since June 2017! I have a small leak on the hydraulic clutch line I need to get straightened out, then I will start putting the front end back on it...then take it to the exhaust shop to get new exhaust put on...so close to being able to take it for a cruise...a few more weeks!
Old 07-13-2020, 10:39 PM   #383
cwcarpenter98
cwcarpenter98's Avatar
Gotta love when it moves again after not moving for awhile! You could probably get the front end back together in about 1 and a half full days of work. That's basically what I did on my truck a couple weeks ago
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-13-2020, 11:00 PM   #384
J Williams
J Williams's Avatar
[QUOTE=roll_the_dice;8774013]BIG DAY today!
That’s awesome man! So jealous! Haha way ahead of me! Let’s see some pics of that thing!
Old 07-13-2020, 11:33 PM   #385
roll_the_dice
BIG DAY today!
Thanks guys....it was a huge day. I am stoked! I have a video of it moving, but I will get a better one soon...I ran it for 30 seconds...no radiator was hooked up so I didn't want to go crazy with it! I literally backed it into my cul-de-sac and drove it back in...Main thing I was checking were the brakes and the clutch.
Old 07-14-2020, 02:24 PM   #386
roll_the_dice
Just ordered my seat belts from Seatbeltplanet.com Thanks Christian for the correct items to order and the discount code...from last year. It still works! Some pricing went up, but not a lot...
Bleed Brakes
Bleed Clutch
Order Seat belts
Install front end
Install wood in bed
Drive & Enjoy
marking more and more off the list!
Old 07-14-2020, 03:01 PM   #387
cwcarpenter98
That's funny that the code still worked I hope the belts serve you as well as they have served me. I feel much more comfortable driving around with the shoulder belt than I did with just lap belts. I'm sure my passengers feel the same way with my driving
Christian Carpenter
Old 07-14-2020, 03:06 PM   #388
roll_the_dice
That's funny that the code still worked ...
I know...saved me about $20. I think all 3 belts were $266 delivered...including all new hardware and I did what you did and upgraded the buttons to the GM logo...the look was worth it to me. I went with charcoal gray belts to go with my black seats and silver interior. Should look good, but as long as they secure me in the vehicle...it's worth it!
Old 07-14-2020, 03:19 PM   #389
cwcarpenter98
They do lock fairly quickly compared to modern cars, so whenever my friends ride with me, I always have to tell them that the belt has to be pulled out a little slower than what they are used to. It doesn't really bother me though, so I have no complaints with them
Christian Carpenter
Old 07-14-2020, 07:27 PM   #390
roll_the_dice
OMG...I have never done anything with drum brakes before. So today I tackled replacing the parking brake cable for the passenger side. It frustrated me for longer than I care to admit. I got the drum off easily, which surprised me. Then I was "hoping" I could just get the cable out and replace...but I couldn't figure out how to do that...so I had to disassemble the shoes to get to the cable. Then it took me forever to finagle everything back together correctly. So happy I got it back together without throwing any tools!
Old 07-19-2020, 08:14 PM   #391
roll_the_dice
Trying to finish the A/C install...got the heater hoses installed. I also put the drier on the condenser. I was about to drill the radiator support when I realize I don't have a 1 1/4" hole saw...thought I did! Will pick one up and finish up. Going to install the inner fender gaskets also, so I can get those installed...then go from there.
Old 07-21-2020, 11:06 AM   #392
roll_the_dice
Just found out the seat belt GM logo buckle is backordered until the end of August. So I called and changed the order to the starburst logo. A little disappointed, but can't wait that long since my truck will be finished before then.
Old 07-21-2020, 07:13 PM   #393
roll_the_dice
So before I put on my inner fenders and radiator support I thought I would clean up some of the engine bay wiring. Much easier to get to now with no fenders on than later. Here is a before and after picture...still need to connect the green temp gauge wire and the alternator wire, but much better!
Old 07-22-2020, 02:43 PM   #394
roll_the_dice
Quick question...figured someone could answer here instead of creating a new thread on the main board. Never had a 1 wire alternator before.but I have a 1 wire alternator now and the AAW wiring harness. I am "assuming" the 1 wire from the alternator goes to the battery post on the starter or directly to the positive terminal on the battery?
Old 07-23-2020, 06:19 PM   #395
roll_the_dice
I got a text today from my buddy John who milled my bed wood for me. Here are a few pictures of them in process. The wood is walnut. I am just going to use marine grade sealant. I am also going to fill any knot holes or imperfections with black two part resin...I should have it first week of August.
Old 07-23-2020, 06:24 PM   #396
cwcarpenter98
Dadgum, that wood looks nice!
Christian Carpenter
Old 07-23-2020, 10:25 PM   #397
72cs20
My instructions say to the battery post on the starter.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 07-25-2020, 08:29 PM   #398
roll_the_dice
After much research, the alternator can be connected to the starter or battery...I am choosing to connect to the battery. I think it will be a cleaner install in terms of wires.
In between raindrops today, I got one of the bed cross sills sand blasted and primed. Waiting on some black paint to arrive. Will get the others blasted and painted this week. Not a fan of outdoor blasting in the heat and sand blowback. I also couldn't resist installing the air cleaner since I received the new stud kit. I thought about painting the top green, but decided to keep it powder coated black.
Waiting on my "new" v8 radiator bracket to arrive. I will need to sand blast it and powder coat satin black, but that shouldn't take long.
I also "think" I am going to try and take off the horrible DIY spray on bedliner the PO put on. I have already taken it off the inside of the tailgate. I used paint stripper and it did a good job and keeps the theme of the truck going..."not a show truck".
Will try to get a better picture of the air cleaner tomorrow...looks like the colors don't match, but they are spot on.
Old 07-26-2020, 10:59 AM   #399
Johns 66
Johns 66's Avatar
Looking real good Andy. Once you get the wood finished I think its gonna look killer in your truck. Left some of the character on the top side of the wood which will go nicely with your truck....Im hoping GMC Pauls dimensions are correct....lol....If not we will just have to make some more...lol
2019 GMC AT4
Old 07-26-2020, 11:21 AM   #400
roll_the_dice
Thanks again John! Yes, I was thinking the same thing about the dimensions from GMC Pauls! HAHA
