Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-04-2020, 08:36 PM   #51
IronCanine
IronCanine's Avatar
Re: 1969 Blazer - 507 Light Blue
Late to the party...but on board. Fantastic work.
Good for you 1) For saving this truck. I love to see this type of truck get resurrected...they all deserve it. 2) For some outstanding metal work. I don't know what to say, other than I wish this was a TV show....I'd DVR it. Metal work of this caliber is the cornerstone of a real restoration. And 3) For sharing.
I will enjoy this follow. Keep it up!
IronCanine is offline   Reply With Quote
Old 06-05-2020, 04:34 PM   #52
harrisoncole4
harrisoncole4's Avatar
Thank you. I am down to the high hump transmission tunnel, the center of the dash and the b pillar area as all that is left of the original sheet metal. My goal is to repaint an extra glove box door that I have in the 507 blue, and have the original one that came on the blazer clear coated with the patina still on it. I don't know which one I would end up using, but at least I would always have a reminder of where the project started!
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 06-05-2020, 04:45 PM   #53
harrisoncole4
Originally Posted by bmfm64 View Post
Can you share some of the repairs on your top? I have a few spinning nuts as well.
I have a lot of photos to share of the top repair so bare with me. The top I got was supposedly a really clean example of a double wall top, and while I haven't seen any other tops to compare it to, it had a lot of rust issues. On the bright side the top has no sagging in the middle. Here are some rusty areas hidden behind the fiberglass. This is where the bottom of the hatch is and the top hold down bracket that mounts to the end of the bed sides goes.
Name:  Blazer (249).jpg
Size:  39.5 KBName:  Blazer (250).jpg
Name:  Blazer (257).jpg
Size:  47.8 KBName:  Blazer (258).jpg
Old 06-05-2020, 04:57 PM   #54
harrisoncole4
As I had mentioned earlier on in the thread, there was some pretty awesome metal work done to the top. Now that the truck wont be worked as hard as its early years, this stuff should hopefully last 100 years without rusting!
Name:  Blazer (269).jpg
Size:  45.4 KBName:  Blazer (270).jpg
Name:  Blazer (276).jpg
Size:  34.5 KBName:  Blazer (277).jpg
Old 06-05-2020, 05:08 PM   #55
harrisoncole4
The thought process behind this modifcation was that even if we repaired the loose nuts, they would eventually sieze up again and break apart the fiberglass. Instead, the area where the top meets the bed rail had a few cuts made out of it so that a metal bar could be inserted with threaded holes where the nuts would have been. This gives it a great deal of extra strength and alleviates one of the bigger probelms with a double wall top.
Name:  Blazer (251).jpg
Size:  41.7 KBName:  Blazer (259).jpg
Name:  Blazer (262).jpg
Size:  30.7 KBName:  Blazer (263).jpg
Name:  Blazer (308).jpg
Old 06-05-2020, 06:30 PM   #56
CG
BlahBlahBlah
I cant tell with just pictures and comments, but to me it looks like the place you chose to do the work is really getting at it.
You hear story after story of body and paint shop prison. Have you had that at all? If not these guys are awesome. Awesome work and awesome at getting it done!
Old 06-08-2020, 09:34 AM   #57
bmfm64
bmfm64's Avatar
Thanks for the info- thats exactly what I was thinking on the top hold down bolts-
bmfm64 is offline   Reply With Quote
Old 07-11-2020, 04:11 PM   #58
harrisoncole4
I am extremely happy with the shop that is doing the work on this project. These guys are crazy talented... To answer your question though, the metal work that I have shared was completed in two stages, the first portion last spring and the second one this winter. Both times they had the truck in and out in less than a month. The main guy always says that he is not in the business of storing cars. They move em out pretty quick!
Old 10-21-2020, 11:18 AM   #59
bmfm64
bmfm64's Avatar
Any updates on this?
Old 01-31-2021, 10:57 AM   #60
davischevy
davischevy's Avatar
I just found this, and I'm amazed at the great work. Thanks for saving this Blazer.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 02-02-2021, 08:42 PM   #61
underliner6
underliner6's Avatar
Absolutely awesome resurrection. WOW!
Jim
1972 K20 Cheyenne- 350/350/205
1972 K20 Cheyenne - 350/SM465/205
1971 K5 Blazer
underliner6 is offline   Reply With Quote
Old 07-21-2025, 07:01 PM   #62
soloma
Any updates to this blazer?
soloma is offline   Reply With Quote
