#76 |
Re: 1959 Fleetside Short Bed Project
Truck is looking awesome! I’ll be following.
Not sure the 2011 6 speed will work with your 2002 engine. That trans is controlled by a tcm( transmission control module) that is contained in the ecu. Gm didn’t start using a tcm until 2007 when they changed to the 58x reluctor. Your 2002 won’t be compatible unless you change the reluctor wheel n ecu To one that has an internal tcm... if that’s possible. I’m not sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build Last edited by Jason 56; 07-01-2020 at 10:41 PM. |
#77 | |
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#78 | |
1959 Apache Fleetside Short Bed |
#79 | |
#80 |
Cut off the stock mounting points for the rear end and making it a permanent fixture
![]() ![]() Adding some bracing ![]() ![]() ![]() Cups for upper air bag mounts ![]() ![]() ![]() rear shock mounts: ![]()
#81 |
More bracing in the rear to fit around a fuel cell
![]() ![]() Making lower control arms ![]() ![]()
#82 |
![]() Join Date: Jan 2015
killer pipe work
#83 |
![]() Join Date: Mar 2007
Man that's an impressive chassis....Nice work.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#84 |
#85 |
thank you! my father in law has a JD2 manual bender we put to work. I am really considering a roll cage...
#86 |
Kick ass fabrication work!!
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
#87 |
Wow, great fab skills! Very very nice work.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#88 |
the progress continues...
Got new Holley valve covers. The red should be good for a few HP ![]() ![]() About 2 weeks of sha-hit loads of grinding and sanding to get the whole frame (top and bottom) metal finished getting it ready for primer. ![]() Throwing sparks in gawds country ![]() bottom side of the frame where the 1959 Apache meets the 2015 Camaro SS ![]() Top of the fabricated rear airbag mount ![]() I love me some files ![]() ![]() Primered black until I get back home to LA where I will have it blasted and epoxy primered. ![]() ![]() ![]()
#89 |
Going back together (and I got a zx14
![]() ![]() ![]() 5 Gallon Air Lift tank mounted behind the drivers step ![]() Dual Viair 444C compressors mounted ![]() ![]() Air Lift 3h manifold mounded behind the seat ![]() Got some of her clothes back on ![]() ![]()
#90 |
Wow! Your fab work is so clean. Very inspirational and makes me wish I went with a similar suspension. Your truck is going to be top notch!
#91 | |
Next up is one piece glass in the doors
#92 |
1959 Apache Fleet Side + 2015 Camaro SS = Camache
Starting to build the raised bed frame. Because of the IRS I am able to keep a pretty decent bed depth and only ended up raising the bed floor about 6" while being able to lay the body on the ground:
#93 |
Looks great man..Nice fab work
Marc
#94 |
BAD ASS!!! So much work in these photos, you're killin it. I love all the bent tube, it really shows off how bespoke the chassis is vs. bolting on parts from the hot rod store like I did. Excellent work...I won't even try to keep up. I made two fuel lines and a bracket this month lol!
#95 |
Thanks I appreciate it. Progress is fun, sometimes I need to work on little pieces like mounts because looking at “the whole picture” can be overwhelming ha
#96 | |
#97 |
Wow!! Killer fab work my man, I really like those rear upper bag mounts! You've got one killer rig on your hands!
#98 |
Very nice fab work!
#99 |
Core Shifter base installed with a Hurst stick and an unbranded Hurst shift ball. Shifts are nice and short and precise.
#100 |
Holy neglected thread, batman...
I am still working on the truck, lots has been done, I am just way behind on updates. I will go a more comprehensive update when I have a little more time but here are a couple teasers.. I went air/air intercooler, here is the evolution of the mount design: ![]() Looks good! I went with a Treadstone IC, should be good for 1,000hp: ![]() not exactly fitting... the cross bars gotta go: ![]() Im liking it... What isnt pictured is a lot of metalwork in the opening, contouring the IC with a rolled edge to look like factory: ![]() Happy with that! ![]() oh and I picked up a snail... BW S480 SXE ![]() ![]()
