07-19-2020, 07:15 PM | #1 |
Clean gas tank
What do you guys use to clean out gas tank varnish?
Going to tank swap latter but want to get the truck rolling on its on steem this week |
07-20-2020, 03:43 PM | #2 | |
The Older Generation
Re: Clean gas tank
Depends on how bad it is. I usually just pressure wash the inside with soap then rinse. I then empty out as much of the water as I can, blow it out with the long nozzle on my air hose, pour a couple of bottles of HEAT in it and slosh it around to absorb what moisture is left, and let it dry out good. That works on most of them..... Be sure and put a new fuel sock on the end of the pick up tube. LockDoc
07-20-2020, 04:40 PM | #3 |
Re: Clean gas tank
Thanks doc
Its a bit white last time it seen fresh gas would have been a fiver in 91 when dad had me cobble a 283 together with 350 heads never ran well Tank is a bit white inside google seen a few with lots of chemicals not sure how there residue would mix with gas |
07-20-2020, 05:23 PM | #4 | |
Re: Clean gas tank
There was a post on here a few years ago where a member put some gravel or old nuts and bolts and a little sand in his and bungee strapped or ratchet strapped it to his tractor tire for a few days. He said that thing was so clean inside that you could eat off of it.... LockDoc
07-20-2020, 06:26 PM | #5 |
Re: Clean gas tank
I thought of sand blasting it but decided i proubly could not get all the sand out
