Old 02-07-2015, 11:28 PM   #1
66mustangguy
where to I find 90 ohm resistor for the fuel gauge?
where to I find 90 ohm resistor for the fuel gauge? do they come with new fuel gauges?
I have looked all over, any help is appreciated.
66mustangguy is offline   Reply With Quote
Old 02-08-2015, 12:46 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: where to I find 90 ohm resistor for the fuel gauge?
A little more explanation would help with your quest. What is the problem you are having? Is your fuel gauge not working? Have you replaced your sending unit?
LockDoc
Leon
Old 02-08-2015, 01:01 AM   #3
66mustangguy
sorry here is more info.
71 gmc suburban - just replaced the sending unit and tested it out for 0 - 90 ohms and it reads correctly. gauge will read full when wire is disconnected, but will read empty when grounded so unloaded the gauge seems to work. when its all connected, full tank of gas will only show 1/4 tank on the gauge.
so I am at a loss. I have read that the resistor is the likely culprit. any help is greatly appreciated.
Old 02-08-2015, 09:39 AM   #4
LockDoc
LockDoc's Avatar
Read through this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=334105
If you want to PM me your name and address I will send you one.
LockDoc
Leon
Old 02-09-2015, 11:54 PM   #5
LockDoc
LockDoc's Avatar
Resistor sent. Post back here when you have a chance to try it out....
LockDoc
Leon
Old 07-23-2020, 12:31 AM   #6
Copper116
This info is way past the date of your posts but just for info... the company you sent the info on for a new resistor no longer has them in stock. Their supplier is not carrying them anymore. The company said they're looking for another supplier.. so just FYI... I'm looking for that resistor as well.
Copper116 is offline   Reply With Quote
Old 07-23-2020, 07:39 AM   #7
Bigdav160
Bigdav160's Avatar
Sounds like you need to adjust (bend) the arm on the sending unit
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
