#26 |
Re: No C-notch
Took her for around block - 1st ride in 4 years ---- rode awesome ....... even without shocks ..... But I do have a power steering leak as well as a "grinding" sounds .... again definitely PS ..... I thought I had addressed this ....... any ideas on how to track down issue/fix .... i.e too much pressure versus ???
FAKKY 57 PANEL BUILD |
#27 |
![]() Join Date: May 2007
Re: No C-notch
woop woop! congrats!
bleeding power steering is usually turning it lock to lock a few times. if you have too much pressure and the steering feels like you are turning on ice, thats common on a MII setup with a GM pump and you can change the pressure shim at the back of the pump, jegs sells a shim kit.
#28 | |
Re: No C-notch
Yeah not a MII setup ....... GM astro hydro and GM dakota IFS Im away for a few weeks on a family trip ....... if this is all I have to sort out when I get back shouldnt be too bad ...... well that and get the seats bolted down ![]() Appreciate the input guys.
#29 | |
Re: No C-notch
the rack and pinion doesnt need the pressure of a steering box, so the reducer shim is still what you would need. but I am not sure how the pressure reducer would affect your hydroboost? maybe ask the guys with gm power steering boxes, hydroboost, and rack steering what they did. I had a truck with waaayy overassisted power steering, you could steer with a pinky. it wasnt a rack, it was an older GM steering box with a newer GM steering pump, but a shim fixed it.
#30 | |
Re: No C-notch
![]() Im going to check all teh fittings when i get home as well as high/side low side and just the general once over ...... and might buy a PS pressure tester just to see where I am at. Then assume this is what you mean https://www.summitracing.com/parts/brg-899001
#31 |
Re: No C-notch
yessir, thats it
your leak could be overpressure pushing fluid out of the rack seals.
