Old 07-27-2020, 12:20 PM   #1
jrbynf
Grandpa's 66 GMC SWB
Starting a thread to show my restoration in my 2 car garage over the course of the last year. From Missouri River Bottom barn to licensed in 1 year and 1 day. There were many ups and downs as I had never before welded or done major mechanical work. I used this forum daily as well as Mr Gibson on Youtube for guidance. Mr Gibson's videos, knowledge and overall attitude were very inspiring to me. I hope you all enjoy
jrbynf is offline   Reply With Quote
Old 07-27-2020, 12:48 PM   #2
jrbynf
Re: Grandpa's 66 GMC SWB
Some pictures from picking it up from the Missouri River Bottoms
Old 07-27-2020, 12:50 PM   #3
jrbynf
Back in the early 90's. I am on the right and my brother on the left side. Looks pretty rough in this picture already.
Old 07-27-2020, 01:31 PM   #4
Android04
Android04's Avatar
Looking forward to seeing the progress.
Android04 is offline   Reply With Quote
Old 07-27-2020, 01:39 PM   #5
jrbynf
Some pictures from the inital disassembly in my garage. Lots of rust
Old 07-27-2020, 02:15 PM   #6
jrbynf
Initial repair of drivers side. First time welding
Old 07-27-2020, 02:18 PM   #7
jrbynf
Floor pan and rear corner repair
Old 07-27-2020, 02:20 PM   #8
jrbynf
Repair of passenger side
Old 07-27-2020, 02:35 PM   #9
jrbynf
More of the passenger floor.
Old 07-27-2020, 02:43 PM   #10
jrbynf
Removal of the top of the cab and above windshield piece, the inner cab forward ceiling was also replaced. I completed the inner cab repair first to maintain the 3D dimensions, then I welded the above windshield piece in second using the old outer roof and new inner roof as a guide. This was welded in position with tack welds. After secured I removed the roof, removed all the rust, chasis saver, insulation, and then tack welded the roof on the cab. I wish I took better pictures. I should have also used panel adhesive instead of tack welds
Old 07-27-2020, 02:45 PM   #11
jrbynf
More disassembly
Old 07-27-2020, 02:49 PM   #12
jrbynf
Sand blasted, cab/frame/doors/all usable parts in my 2 car garage. Rented a sunbelt 300lb blaster and used it the entire weekend. I went through over 1500lbs of sand. I re-used the sand as much as I could. Needless to say the neighbors were not impressed. I got 90% of the sand out of the garage but the last 10% has been coming out ever since
Old 07-27-2020, 02:51 PM   #13
jrbynf
I primed the chasis and cab with Chasis Saver. I ended up sanding nearly all of it off the cab in favor of a epoxy primer eventually. The fumes in the house were terrible with the chasis saver. Turned out very nice tho
Old 07-27-2020, 03:20 PM   #14
jrbynf
Engine, transmission and rear end arrived.
Engine: SP350/357 ordered from JEGS
Transmission: Tremec TKO 600 ordered as a kit from SilverSport
Rear End: Ford 9 inch made by Currie Transmissions, 3.7 rear end ratio
Engine and transmission mated easily with new bellhousing provided by SilverSport. Their pressure plate and clutch were easy to install. My runout specs for the transmission alignment were within spec for Tremec. I chose to use a mechanical clutch for simplicity.
Old 07-27-2020, 03:25 PM   #15
jrbynf
Engine and transmission mounted to frame. I used the rear engine mount holes which was stock for this year truck. Pros for this was weight distribution, shorter drive shaft, and near ideal shifter location. Cons are proximity to firewall.
I had re-used by upper and lower control arms. They were all blasted, painted, new ball joints were placed. I used heavy duty springs at original ride height.
Old 07-27-2020, 03:32 PM   #16
jrbynf
Rear end installed. Again I had Currie make it special. 3.7 ratio, with a detroit trutrac. Since GMC's for the most part have leaf springs the hangers were added by them. Everything fit perfectly. I purchased the leaf springs through General Spring locally here in Kansas City. They are actually for 3/4 ton trucks from 67-72. They are rated for 2725lbs. The original springs were rated at 1500lbs. Here is a link to the springs. https://www.generalspringkc.com/product_p/22-409.htm
I used shakles from a 3/4 ton truck slightly modified. I used 5/8 u bolts and u bolt pads from RuffStuff. The pads are sold for 3 inch axles for Ford Broncos. All came together very well.
The fuel tank is aluminum from Brothers
Old 07-27-2020, 03:44 PM   #17
doobiebro
doobiebro's Avatar
Saweet! Keep up the good work!
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 07-27-2020, 03:56 PM   #18
roll_the_dice
roll_the_dice's Avatar
Looks great...following along although I think you are going to be finished soon. Glad to see you with a manual transmission too!
roll_the_dice is offline   Reply With Quote
Old 07-27-2020, 03:59 PM   #19
jrbynf
Brake lines run using 3/8 inch steel tubing. Master cylinder was wilwood and all brakes were Wilwood. Front calipers/rotors and spindles (stock height) were bought from Performance Online as a package. These were 2 piston calipers. Rear brakes were part of package from Currie. These were 4 piston calipers.
Old 07-27-2020, 04:02 PM   #20
jrbynf
Wheels were cheap steel 15 x8. Tires are Michelin. I would have use the original steel rims but they would not fit over the disc brakes. Front sway bar is from CPP and the largest they make. Rear sway bar is from Hellwig and also the largest they make. The rear had to be modified slightly as I did not like the mounting hardware. Shocks are from CPP
Old 07-27-2020, 04:03 PM   #21
jrbynf
The radiator is a 4 core radiator I purchased from Classic Parts of America. The mounts had to be enlarged to fit over this
Old 07-27-2020, 04:04 PM   #22
jrbynf
Fuel tank, rear brakes, rear end and Hellwig sway bar. Drop hitch rated for 8k pounds
Old 07-27-2020, 04:13 PM   #23
Johns 66
Johns 66's Avatar
You are doing an awesome job on this truck
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 07-27-2020, 04:26 PM   #24
jrbynf
Body work. I used epoxy primer from SPI. I used Evercoat Rage for the filler. Lots of sanding hours with many mistakes.
Old 07-27-2020, 05:15 PM   #25
jrbynf
Assembly. Painted at MAACO. I called around to 20-30 different body shops and everyone wanted 20-25K for the job or just refused. MAACO was fair and did a fine job. This is a daily driver and not a show truck
