Old 07-28-2020, 12:17 PM   #1
rdc72
Gauge cluster grounding issues
I hope someone can help me out on here? i have a 72 with factory tach and it stopped working. A little back story, i changed out the circuit board and replaced all the bulbs with LEDs, now the tach doesn't work and the lights that didnt work now work and the ones that didn't do? i have tried to put a ground from the back of cluster to the chassis, no go there too? i have tried everything to get this thing to work. any help would be much appreciated.
rdc72 is offline   Reply With Quote
Old 07-28-2020, 02:56 PM   #2
sick472
sick472's Avatar
Re: Gauge cluster grounding issues
I would clean up the contacts at the gage cluster to harness "U" shaped connector and at the back of the gage cluster where the harness connects to the circuit board. LED's need bright and shiny connections. I'm not sure about the tach issue. If all else fails, go back to incandescent bulbs to eliminate them as part of the problem.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 07-28-2020, 10:30 PM   #3
custom10nut
custom10nut's Avatar
The Tach is separate from the Circuit panel. Check you grounds on everything. These trucks LIVE for grounds
custom10nut is offline   Reply With Quote
Old 07-28-2020, 10:36 PM   #4
davischevy
davischevy's Avatar
Is the tach plugged in backwards? It can be done, but I won't devulge how I know.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
