07-30-2020, 08:59 PM | #1 |
colmn swap
what is all involved with swapping the column out 84-87 into to 78 c10
with column shift |
07-31-2020, 09:52 AM | #2 |
Re: colmn swap
It is a bolt in operation as far as the column, but the wiring is different.
The wiper controls, and high beams are on a stalk on the new model. So you will have to re-pin your connector or add a new connector. That way you can add the function to the column. |
07-31-2020, 12:10 PM | #3 |
Re: colmn swap
or you can leave the wipers and high beams where they are and not use the new column functions
07-31-2020, 12:23 PM | #4 |
Moderator
Re: colmn swap
The harmonica plug is pinned the same from 78 on.
The wipers and dimmer switches are up to you.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-31-2020, 04:18 PM | #5 |
Re: colmn swap
is the shaft from the firewall to the steering box the same too.
I want all the stuff on the new column to work like factory. |
07-31-2020, 04:36 PM | #6 |
Moderator
Re: colmn swap
The stub end of the column is shaped differently for different model years.
You'll have to get a steering shaft that mates with your power steering box and column. Not difficult to find. Some folks use a Jeep intermediate shaft with universal joints rather than a rag joint.
08-01-2020, 03:17 AM | #7 |
Re: colmn swap
ok so grab the shaft at the same time I snag a column
08-01-2020, 08:08 AM | #8 |
Re: colmn swap
yes. It may or may not work depending on your steering box end. But you could use one end from your old shaft and one from your new one to make what you need. It would take some work taking them both apart and building what you need but it would work. It could be as easy as a bolt on or a new rag joint
