Old 08-03-2020, 11:56 AM   #226
88Stanger
88Stanger's Avatar
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
Originally Posted by SCOTI View Post
Don't know the how to answer your question. But, I just saved it to my computer, opened it in 'Paint', rotated its orientation & saved it again....
Well dangit. i will try again. lol
88Stanger is offline   Reply With Quote
Old 08-03-2020, 11:57 AM   #227
88Stanger
88Stanger's Avatar
So any idea on what or how to fix the door jam? I could just cut out that bad area, bend and weld in new section.
i was looking into this and found where some are just using Jeep Door Check stop brackets, anyone else on this?
Old 08-03-2020, 12:04 PM   #228
88Stanger
88Stanger's Avatar
test
So I tried what you suggested Scoti, and it shows it just fine in Paint, Paint 3D and other selection, but as soon as i link it here, it rotates it. So, i just did as previously suggested and cropped it and tada now it works. lol
Old 08-03-2020, 12:07 PM   #229
88Stanger
88Stanger's Avatar
test again..
So this is interesting... I did as Scoti said, saved a copy of the pic, then i had to rotate it and resave it, tada... Not sure what the heck, but anyways....
Old 08-03-2020, 12:09 PM   #230
88Stanger
88Stanger's Avatar
Ok, anyways, back to the real issue, how to fix this area of the door pillar. I cannot find anywhere that sells this replacement panel or at least i cannot find or located one. So does anyone know about this? I have seen that others are using Jeep Check stop backets inplace of this. Bolts or welds on. That is great, but do i just cut out this nasty spots and weld in new metal or ??
Old 08-03-2020, 03:28 PM   #231
SCOTI
SCOTI's Avatar
I haven't looked to see what's out there are far as patch panels so I can't comment
If there are no patch panels for that area, choices are sections from a donor cab or flat sheet-metal & bend the 90° areas as dimensionally needed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-03-2020, 03:52 PM   #232
cwcarpenter98
cwcarpenter98's Avatar
I have not seen any patch panels for that area yet. Easiest option would probably be getting a donor cab section, but you could also make one yourself. The Cherokee door check link swap uses the factory piece you are pointing at
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 08-03-2020, 10:10 PM   #233
Captainfab
60-66 Nut
I have a part of a cab I can cut that section from. Do you need both sides or just the passenger side?
Old 08-04-2020, 06:39 AM   #234
Paul Y
I am a neanderthal compared to what you have achieved so far, therefore if I can cut in a donor panel to my door striker panel you can do the same with the hinge side!
Must admit that the great and the good from this very board provided me with the encouragement, you can see my efforts here.
http://67-72chevytrucks.com/vboard/s...=658621&page=6
Good luck, looking forward to seeing you throwing sparks and sticking bits together with the sparkly stick.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 08-04-2020, 08:38 AM   #235
88Stanger
88Stanger's Avatar
Captainfab, Thank you sir for the offer! Honestly, both sides are shown, so i need both. Do you have both? Costs?
Old 08-05-2020, 10:40 PM   #236
Captainfab
60-66 Nut
Sorry I was in a hurry and didn't pay enough attention. I'm thinking $25.00 per side plus shipping. Unless you want to make the trip up here and pick them up.
Old 08-05-2020, 11:27 PM   #237
SCOTI
SCOTI's Avatar
Thats a good deal.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-07-2020, 10:34 AM   #238
88Stanger
88Stanger's Avatar
That is perfect. I will PM you on this.
Old 08-07-2020, 10:44 AM   #239
88Stanger
88Stanger's Avatar
Pm Sent Captainfab - Done deal. Thank you for the offer!!! I owe you one...
Old 08-07-2020, 10:49 AM   #240
88Stanger
88Stanger's Avatar
I am amazed each day on this site how willing people are to help each other. In the times we are in today, the crazy way some treat others and then i am on here and see how much help others are willing to do for another, it is just awesome. I know that i will help anyone i can in any way i can. Shortly here, i will have a bunch of "extra" items that i will am replacing with new and will have the original parts up to get rid of, maybe help another out here. So, to all those who do help out others, not just me, but others, God Bless You for being a positive person!
Old 08-07-2020, 11:55 AM   #241
SCOTI
SCOTI's Avatar
Add your items to the 'Pay it Forward' thread/s.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-07-2020, 12:29 PM   #242
88Stanger
88Stanger's Avatar
Yep, that is where they will be going....
Old 08-07-2020, 12:43 PM   #243
roll_the_dice
roll_the_dice's Avatar
I totally agree! So many amazing people on this board that help others and I am sure we don't even know half of the good that goes on...Like I told someone recently, the Chevy Truck restoration world is not big...6 degrees of separation in the hobby at any given point. I have had so many things done for me after I joined this board, I would never be able to pay it back monetarily, but I will pay it forward in help or parts or whatever I can.
roll_the_dice is offline   Reply With Quote
Old 08-07-2020, 01:31 PM   #244
88Stanger
88Stanger's Avatar
So true. The amount of knowledge i have gained just by reading other posts, having other comment on my questions. Ya, i can never repay what i have gained, but i will help as much as possible.
Old 08-07-2020, 03:04 PM   #245
SCOTI
SCOTI's Avatar
That's the easiest/best way to 're-pay'. Watching others builds or just browsing forums & helping others w/'been there-done that' guidance. Even if someone doesn't heed the advice, they made a better (informed) decision w/others experiences. That's one of the main reasons I try to detail the 'whys' behind any comments, questions, or recommendations.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2020, 11:22 AM   #246
88Stanger
88Stanger's Avatar
UPDATE:
I got the cab back from blasting. Not to bad looking. A few rust fixes required, but nothing real bad. The front window area on the passenger side is only really bad spot, and i have the repair panels for that already. Never done one of them, but with some thought and slow working i can get it. Please feel free to comment any suggestions.
Old 08-15-2020, 11:25 AM   #247
88Stanger
88Stanger's Avatar
few other pits with some minor rust repair ....
At least i do not think its bad....
Old 08-15-2020, 11:27 AM   #248
88Stanger
88Stanger's Avatar
i do have a question. The old gas tank mount bracket, must it stay in place? I would like to remove it if possible.
Old 08-15-2020, 11:53 AM   #249
The Rocknrod
Moderator
The Rocknrod's Avatar
If your tank is going elsewhere they can be removed.
Old 08-15-2020, 12:25 PM   #250
jrusher
I just cut the bracket off where it starts to bend up on both my trucks . Was quick and easy and I kept the pieces if somebody wanted to use a stock tank again . Amp and sub boxes fit back there nicely
jrusher is offline   Reply With Quote
