08-11-2020, 10:22 AM | #1 |
Longer brake hoses
I lowered my 84 c10. Now I need longer brake hoses cause they rub. I have 1" rotors (light duty). Is there a place I can get longer ones made or can I use some from another truck. Most I brake lines i seen are squared but mine are more triangular. I'll try to post a pic if I can figure out how. Thanks in advance
08-13-2020, 09:06 AM | #2 |
Re: Longer brake hoses
I would think a 4x4 shop that does lift kits.
08-13-2020, 09:17 AM | #3 |
Try Off Road Design.
08-13-2020, 01:21 PM | #4 | |
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
08-17-2020, 11:11 AM | #5 |
I'm in the same situation. Lowered my '86 and now the factory hose crashes into the ball joint nut. If you try to route it over the top it's too short. Going to attempt to bend the steel 90 on the factory line to clearance the nut.
The Stable: 1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me. 1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck. 1951 Chevy 1/2 ton, 3-window...building to sell. Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado. I grew up in Flint, Michigan so I can't help but to bleed Chevy! |
08-17-2020, 11:41 AM | #6 |
Lowering should not require longer brake hoses. I've done close to 20 trucks personally over the years & never needed longer hoses (for disc equipped years or swaps).
The hard line from the banjo fitting @ the caliper requires tweaking to ensure the hose doesn't contact any metal & it's easily done w/a heavy screwdriver or small pry bar. When prying, work slowly as it's easy to kink or pinch the tubing if you're 'heavy handed' w/it. Please post a pic of this issue.
08-19-2020, 12:27 PM | #7 |
I found it wasn't just rubbing against the nut on the upper ball joint, but crashing into it. May have been able to bend the line enough to clear it, but it would have been more than a tweak.
Based on that I went with aftermarket lines from Skyjacker for a 6-8" lift (Part #FBL18). Several benefits: Replaces old, soft factory line (better safety and improved braking), was able to route the line around upper control arm versus under it, thereby avoiding any potential for contact with the control arm, coil spring or anything else (there was even a handy stud on the control arm that I used for a retaining clip). Not the least expensive route to go, but for me it was worth it.
08-19-2020, 04:20 PM | #8 |
Try Crown Performance, http://www.crownperformance.com/
08-24-2020, 02:00 PM | #9 | |
08-24-2020, 03:45 PM | #10 | |
