#76 | |
Re: 1970 C30 Car hauler Buildish thread.
Here is what I have so far of the rear extension I am reusing some of the railing on the rear it is welded to a mix of chrome moly and dom tubing from other projects its all 1.75 120 wall. the plan is to use 1.50 inch pins to hold on the dovetail at the top. the bottom will slide into the receiver on the bumper hitch I made. ![]() ![]() ![]() The outer parts of the extension of the bed is shorter than the 4 inner extensions, I am hoping it will help distribute the load of the dovetail instead of all the weight being on the bumper hitch. ![]() ![]() I also got a cheap rear view mirror off ebay ![]() ![]() I also replaced the rear brake line I could not front one the same length one that was on it I ordered 2 but they were too short. I ended up making me own brake line I ended up ordering a 18 inch 3an brake line and a male and female 3an to 7/16-24 adapters and a 7/16-24 t fitting so I could get the correct length line. ![]() ![]() Current state of the garden ![]() ![]() ![]() ![]() The forest of tomatoes is taking over ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#77 |
![]() ![]() ![]() I got the final design done in C.A.D of the rear of the flat bed. ![]() ![]() ![]() Welded on nuts for the license plate and reverse lights. the brake lights are screwed on. ![]() I was hoping to make it out of 11 gauge but I ended up getting laid off last month when my work reopened. So I ended up using a piece of 14 gauge. the piece is not very big and the bend at the bottom of the corners should give it enough strength. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Tomorrow I will finish weld it |
#78 |
The rear end turned out great now I just need to paint the rest of the bed.
#79 |
Finally installed the grill. I was having a problem with my turn signals I could not get them to flash. It turned out the relay was wired backwards when I wired up the fuse box. thankfully it was an easy fix unfortunately it took me a month of trying different things to figure it out.
![]() I painted the door panels the other day. When I painted the hood for my brothers jeep. ![]() ![]() I painted the rest of the bed and frame today ![]() ![]() ![]() |
#80 |
Work on the truck has been slow I have been having hip problems. I ended up having hip surgery and the beginning of october. So I am just now getting back to working on the truck. But Before we get to the truck I built myself a santa maria grill for our fire pit back at the end of september.
If it makes a difference I used some of the metal from the truck to build the grill. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now back to the truck. ![]() I installed a set of under hood lights ![]() ![]() I also installed a 3rd gen cummins intake horn to clear my brake master cylinder. ![]() ![]() ![]() I also picked up a 12 gallon air tank as my 3 gallon tank is not enough for my front 5k each bags. I also ordered another 5.65 CFM air compressor, but its on backorder. ![]() I also picked up a set of new shoes for the front of the truck, they are 19.5x 6 I wanted to run 20s for the tires but they are all ugly. I got a really good deal on one of them it was a return. I also got a decent deal on the second but it's slightly different its the same wheel but newer and the center bore is 1mm bigger and the lug holes are not chamfered. That said they require Flange Nut lug nuts so it doesn't matter. But I am going to have a set of center caps cut to fit them they will be cut out of 3/8 aluminum plate and I will polish them and depending on how close they get to my measurements they should be press fit. I don't like the large center caps that bolt on the out side to the lug nuts and I cant find any they fit a 4.59" Center Bore. ![]() ![]() I took a gamble on the tires I wanted a set of open shoulder all seasons steer tires for the front of the truck. I could only find 3 that fit that and the other two were more of a mud tire that a all season. But the other two where name brand and I have never heard of Otani. regardless they should be better than the tires they are replacing with a date code of 1993. That said its impressive that tires from 93 hold 80 psi. and hulled a 6500lbs tractor. ![]() ![]() Well I also decided to delete the factory heater the turbo touches it, and just from driving it around the yard in low gear it has put a hole in the heater box that and I am afraid it will catch fire once I start driving it on the road. I ordered a vintage air 506101 Compact Heater with Defrost. it should be in wednesday. I also ordered a vintage air heater delete plate a while back when I was planning on just ordering the heater/ ac box from vintage air. but realized I would still need to order the controls and the defrost would not work with out the a/c. One day I plan on installing a/c but I dont have the money for that right now. I am selling a few things to save up for a custom set of gauges. ![]() Hopefully I can install the 506101 Heater using these holes. ![]() ![]() I also installed a set of bulkhead air line fittings. ![]() I drilled and tapped the manifold for a egt gauge while I had the turbo off. the other side already had been drilled and taped for a egt gauge but now that I have flipped the manifold I need one on this side because you need the egt gauge to read from the rear 3 cylinders as they run hotter. ![]() I also made a block off plate for the blower motor hole. ![]() |
#81 |
Small update.
I painted the block off plate. ![]() I bought two 5.65 cfm compressors for my air ride/ onboard air. ![]() I install the vintage air heater. ![]() ![]() ![]() ![]() I got the tires mounted ![]() ![]() I finally installed the other intercooler tube. ![]() I modified the inner fenders to clear the intercooler piping and bedlined the under side. ![]() ![]() ![]() ![]() My custom gauges came in today! The are NVU New Vintage USA gauges. in order Gps speedo, Coolant temp/ Oil PSI, 4k diesel tachometer. Boost gauge, Battery voltage, Fuel level and a EGT gauge. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#82 |
The new gauges are great. I am not a diesel guy so this might be a dumb question.... What kind of boost is typical for your set up? The range on the gauge is higher than I expected.
Also, is that a Fiero fastback roof in the corner?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#83 | |
The roof is for the Porsche 911. I had a 1970 911E rust bucket. But I bought a targa tub to build instead so the roof is going on the targa tub at some point. |
#84 |
6>8 Plugless........
![]() Join Date: Sep 2007
Jarrod, very nice work on your truck! Those gauges are sweet! I wish DD would have done custom gauges when I ordered my VHX cluster in my orange truck. Oh well. You will be able to defrost with out AC. It may just take a little longer. My orange truck has no AC hooked up and on certain wet snowy high humid days it is a pain but I just crack the windows a bit and it helps. I like those wheels too. The bed is taking shape quite nicely as well. Keep up the great work.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#85 | |
I am finally able to start on the exhaust. I ordered the tubing V bands a stuff before I had my hip sugary I am just now getting to where I can get down and back up that I am able to install the exhaust. I'm using 4 inch stainless tubing. ![]() ![]() I have super low ceilings just over 8 feet. ![]() ![]() ![]() using a WIX Filter - 42790 ![]() ![]() ![]() I started milling a heater control bezel. I scored for cheap on ebay. ![]() Test fit. ![]() ![]() ![]() ![]() I used an steel/ aluminum epoxy ![]() ![]() ![]() ![]() I'm still wait on some switches the one I have I bought off amazon but I ordered some from billet automotive buttons I did not realize until after I placed the order they are coming from australia so its going to be a while before I can get them wired up. ![]() |
#86 |
Very nice! I've been making a similar gauge/switch mounting panel for my orange truck. I need to finish it but there just isn't the time. Your heater control mount turned out sweet! Keep up the great work!
#87 |
Very nice work.
#88 | |
Thanks! I started wiring the gauge cluster. ![]() ![]() I tested the lights ![]() I installed a coolant overflow and prefilter. ![]() ![]() I had to install an aftermarket washer bottle. ![]() ![]() I cooked my old battery so I upgraded to this monster. I was considering going with dual batteries. But I believe it will be sufficient. It's 15.5 inches wide. ![]() ![]() I bought a new under bed box off ebay. I know you get what you pay for. But I was not expecting it to be so thin. it's made of 18 gauge aluminum. Its 48W,17T,16D the battery fits in it perfectly. ![]() ![]() ![]() I plan to install the compressors in the box as well. ![]() |
#89 |
Those compressors can really generate some heat. I would keep an eye on how hot it gets in that sealed box.
#90 |
Very interesting thread. You've done a lot of nice work on this rig and it's going to be very useful. I'm envious.
#91 | ||
Well I started on the box I layed out everything I was planning on installing the box behind the cab on the driver side. So I drilled all my holes installed rive nuts and started mounting and wiring everything up. Then I thought I need to install the new gas tank as I need to put a hole in the back of the cab as I wand to use the stock fuel fill. I was planning on using the 40 gallon suburban tank and have it in the middle of the frame behind the cab but I wrote the measurements down wrong. the tank was to tall to fit where I was planning on putting it. And as big as my truck is I had nowhere else to put it as the only other place it would have fit was where I was putting the air tank. So I had to find a new fuel tank. I started looking at semi tanks I was hoping to find a 40-50 gallon tank. But all the 40 to 50 gallon tanks had a diameter of 25-26 inches but my bed from the out side of the frame to the outer edge of the bed was only 26 inches and from the underside of the bed to the bottom of the frame rail is only 21 inches so I had to settle on a smaller tank I ended up getting a really good deal on as 33 gallon tank with brackets its from a 2006 Nissan UD2000. its 16x40. Now to the bad news I drilled 30 some holes in the box to mound the battery and compressors and everything else I needed for it but Now I need to mound the box on the passenger side and I needed to move the battery to the other side of the box as the battery cable would be to long but now I have to move everything to the other side of the box so I can still have space to store stuff in it. Before ![]() ![]() After ![]() ![]() ![]() ![]() ![]() I also started on my switch panel ![]() ![]() I also redid the manual fuel shut off. ![]() ![]() ![]() ![]() I got more of the exhaust installed ![]() Since I was not installing the side box on the driver side anymore I installed a side ladder. ![]() ![]() ![]() ![]() The new tank! ![]() ![]() Making some brackets for the tank brackets ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I started making a flange for the fuel fill neck to pass through the cab to fill the tank. ![]() ![]() Here is another truck doing what I plan on doing. ![]() ![]() |
#92 |
Still plays with trucks
Looks like the project is coming along nicely.
Just a side note, I used to fabricate trailers professionally and those short rails you removed from the sides of the bed are usually added to give the outer bed rails extra strength to resist bending under load. With yours being home built it may be over built with larger tubing than needed and not need these secondary rails. If you do need them you may run into some deflection caused stress cracking of the tubing adjacent to the welds where the outriggers attach back to the main rails over the truck frame. Watch out for this.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#93 | |
Back to the build. fuel filler neck bulkhead ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() New fuel sending unit to match the gauge. ![]() ![]() ![]() ![]() I started on the side skirts they will sit flush with the cab they sit 5 inches in and have will have a two inch lip. they will hide the tank and side boxes. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#94 |
I like the side skirt idea. Looks good
#95 |
I'm enjoying your build! It probably wasn't on your radar, but the side skirts are great for pedestrian and bicyclist safety. If something were to occur, however unlikely, you are less likely to have someone's kid get sucked under the rear tires and die.
Another side benefit is improved mileage (small percentage). |
#96 |
![]() Join Date: Mar 2008
I never thought about side skirts about safety. I thought that it needed them for looks. I just kept hoping he would build some. Good work
NHRA Super Street 469C It only runs 10.90 at 156 mph |
#97 | ||
Thanks!
Bought some more cheap aluminum boxes, ![]() ![]() Got the grill out of storage! ![]() ![]() ![]() ![]() Made a bracket and installed a pre pump fuel filter. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The front bumper was in the way so I decided to install it, I don't know if i'm going to get a new one or not. I thought about painting it white as the chrome is peeling off but it matches the look. I bought a set of fog lights as its a 71-72 bumper. They look ok but I hate how the mount. ![]() I wire wheeled and por15ed where they touch the frame ![]() ![]() ![]() ![]() Also installed jumper terminals ![]() ![]() ![]() ![]() Made a door for the gas tank it has a cut out for the pull out ladder. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Its come a long way so far. ![]() ![]() ![]() ![]() |
#98 |
Great work! The lights look pretty good in there. Nice work on the fuel tank and sides. It's amazing how much time these projects will eat up huh?
#99 | |
I picked up a front plate I was looking for something period correct, it's close but its a 90s remake. I was hoping it was steel but its aluminum. It's a bit to nice I was hoping to scratch it up a little and have it rust and make it match the truck but idk. ![]() ![]() That said some of the metal showed up for the sides. i'm skinning the sides in 18 gauge aluminum as at the moment its cheaper than 18 gauge steel. metal prices are way up. 2 years ago I bought some 18 gauge steel 24x48 sheet for $28 its now $63. I was going to use the old side box door skin, but when I striped it all the way down it had a ton of pitting. ![]() ![]() starting on the door skins ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The fuel tank access door with the ladder cut out. ![]() ![]() ![]() ![]() ![]() ![]() |
#100 |
Started on the middle door,
Tags |
air ride, c30, cummins, nv4500, ramp truck |
