08-17-2020, 11:47 AM | #1 |
Drip rail fixable?
I've been looking at a truck im interested in buying, but worried about the drip rail area. The inside above visors looks good and the pillars look good. I only have a few pics as im not local to the truck. Just wanted to get some opinions on if its fairly easily fixed or if I need to be looking at other trucks instead. Thanks.
08-17-2020, 12:04 PM | #2 |
Re: Drip rail fixable?
Welcome aboard. Everything is fixable it just depends on your skill level, patience and pocket book. I wouldn't recommend this for your first body work repair but there are others who have started out with repairs like this. There are other folks who would grind the rust off and slather bondo on it and paint.
The rest of the truck's condition certainly comes in to play in these decisions. If this is your first vintage vehicle and the rest of the truck is solid and in good condition then it may well be worth replacing the damaged area. Posting more photos will help folks help you.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-17-2020, 12:24 PM | #3 |
All about them K’s
Someone used body filler in the seams it looks like to me. The correct thing to use is seam sealer. The only way to know what you’ve got there is to wire wheel or otherwise strip the paint and surface rust back from the seam to see what you’ve got under it all. You may get lucky and it all be surface rust underneath. If that’s the case a little surface prep and a good quality drip rail appropriate seam sealer from 3M, or lord fusor etc. Not all seam sealers cure at the same rate and with the same consistency/flexibility. I prefer one that is still a little flexible and self leveling for drip rails.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 08-17-2020 at 12:30 PM. |
08-17-2020, 12:26 PM | #4 | |
08-17-2020, 01:36 PM | #5 |
Proprietor of Dale's Corner
The true test is to strip it. Need to have eyes one the damage under there....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-17-2020, 06:40 PM | #6 |
Like others have said you won't know for sure until you strip it down. I did a bunch of cleaning up of rust on the drip rails on my Burban. It is slow work but if you don't find any serious rust it doesn't cost much to repair. There are a bunch of photos of what I did to my drip rail scattered across the first 3 pages in the link below.
Since the truck isn't local to you try posting a thread asking if some could go look at the truck for you. https://67-72chevytrucks.com/vboard/...d.php?t=698377
08-20-2020, 10:06 PM | #7 |
When its that dried out and cracking, the likelihood of rust underneath skyrockets. Just dig out all the old putty and then sand the gutter to bare metal all the way around. Then take it off and put rust converter down as a primer, then seal sealer, and then paint. Hope there are no rust holes underneath.
08-20-2020, 11:47 PM | #8 |
I'd look closely at the joints in the gutter that can be seen in the bottom of the pic. From the look of the gutter where there's no sealer, things look pretty good.
I would suggest digging out all the sealer and blasting things--no rust converter or encapsulator. |
