08-19-2020, 05:02 PM | #1 |
Under Hood A/C Actuator - Help needed
My actuator under hood not working, noticed the rod that goes through the firewall seemed loose/not connected.
Pulled off the cowl panel and yes, its got broken parts under the cowl. Doubt the assembly is reproduced ?? Second picture of plastic rubber plate seems to be broken on both ends. Anyone else run into this ?? Is the door in the heater that this controls, very important for cooling ?? Searched for pictures and threads but didnt find much. Drawing is Assembly Manual not helpful. What other parts am I missing (I have the screws that are not shown in first picture) ? I know I can get the actuator and install, but need help with the under cowl stuff and how to connect it. Any help, advice appreciated.
Larry 84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles. "It's a sorry man who can't find his wife a good job" |
08-19-2020, 05:40 PM | #2 | |
Re: Under Hood A/C Actuator - Help needed
http://67-72chevytrucks.com/vboard/s...d.php?t=809842 http://67-72chevytrucks.com/vboard/s...d.php?t=478564 http://67-72chevytrucks.com/vboard/s...d.php?t=674249
Jim Last edited by FirstOwner69; 08-19-2020 at 05:54 PM. |
08-19-2020, 07:59 PM | #3 | |
Yes, that helps A LOT ! Thank you, I feel much better knowing that part is available. And also the pictures and discussion are very helpful for me.
08-20-2020, 02:27 PM | #4 |
That's a common break point, the door is too heavy for how they attach. I have one that looks exactly like the original, only it's a lighter door. Might have been a GM replacement.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-22-2020, 06:02 PM | #5 |
Got the new fresh air door from LMC today. Trying to install but .... the small rod with spring doesn't seem to be long enough where it goes into the firewall.
See the yellow arrow in picture. New part has same rod length as original part rod length ?? Am I missing a part or washer or supposed to shim something ? EDIT: I modified the spring loaded rod so it's now long enough to go into the fitting on the firewall. All good.
Larry 84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles. "It's a sorry man who can't find his wife a good job" Last edited by hooverfish; 08-23-2020 at 02:02 PM. |
