08-10-2020, 07:53 PM | #1326 |
Re: 53 Surburban "Family Truckster"
good night that is gorgeous!
08-10-2020, 09:49 PM | #1328 | |
Thanks man. It is fun to see the vision I've have had for a while bouncing around I'm my head starting to come to fruition.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
08-11-2020, 04:25 AM | #1329 |
Outrageous! LOL, you're slightly behind your "couple of years" timetable in post #1 but it's been worth the wait!
1951 Chevy Panel Truck |
08-11-2020, 07:54 AM | #1330 | |
Marc
08-11-2020, 09:55 PM | #1331 |
So tonight I lined up all of the body mounts so I could slip bolts into each hole. On suburbans there are (4) Wood block 2 5/8" in height the supports the rear wood floor. It takes up the space between the frame and the floor. Since I made my own custom sub floor I knew I would need to make my own blocks.
I used Derlin to make the blocks. Derlin is a high density plastic that is used in tool and die to make worm gears and stuff. I love using this stuff. 1 It comes in black (or white). 2 It's easy to drill, sand and cut 3 it's pretty cheap. I buy drops at Alro metal for a couple $ per Lb. 4 It's not effected by the elements so there's no chance for water damage or rot. I used Derlin to make my trans and carrier bearing spacers as well. I needed to locate the body mount hole, drill thru the sub floor structure and make the top hole large enough to drop the head of the 7/16" bolt thru and also be able to fit a socket. Once the wood floor is installed you wont see any of this. I now have all of my body mounts ready to tighten down as soon as I pick up some 3.5" long 7/16" bolts. Thanks Marc
08-18-2020, 10:05 PM | #1332 |
I really want to try to get the motor fired this spring. I have been focusing on items to help with that. One thing I noticed after I dropped the body on was my poor placement for the battery. I underestimated how buried it would be under the body. I have since ordered a drop down battery box. The bad part is removing the current one. It will be difficulty to get to the bolts that hold on the mount. I might have to cut it off unless I want to crib up the body some.
We had some friends over this weekend so I bolted the grill and core support cover to look a little more complete. I do like the look of the brushed grill. Tonight's project, I made my custom vintage plug wires. For not really having the best crimping tools I made due. I like how they turned out. I just need to source some plug wire separators. I also double checked the wiring going into each coil to verify that I had the firing order correct (which I did...I was surprised) coming from the factory harness. On Sunday I made a small bracket to mount the fuse block for the BPI harness. I'm pretty close to dropping it down the floor and plugging in stuff. Thanks Marc
08-18-2020, 11:31 PM | #1333 |
beaut work! delrin is some cool stuff. we have an aircraft surplus store here and they sell a composite wood substitute that is also listed as a sub for delrin!
7 months from now? or is your summer cooler and more pleasant haha
08-18-2020, 11:32 PM | #1334 |
Spring?...
Those plug wires are cool...never seen them befors.. And that grill....WOW...I really like the brushed look..
08-19-2020, 07:59 AM | #1335 |
Looks great Marc
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
08-19-2020, 08:16 AM | #1336 | ||
Thanks Mark
08-19-2020, 01:48 PM | #1337 |
Yeah, spring...baseball just started.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
08-19-2020, 11:52 PM | #1338 |
Really taking shape...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
08-20-2020, 11:28 PM | #1339 |
Looks great, please post link for those wires, I love the look.
Nice work
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
08-21-2020, 07:51 AM | #1340 | |
Thanks Jim
Check out https://www.ebay.com/itm/Vintage-Clo...Cclp%3A2334524 He has many different colors in his various listings. I didn't pay that much, I think my color was discontinued. I bought them last winter. Marc
08-21-2020, 08:03 AM | #1341 |
Thanks....here I am wanting to replace my wire set and I haven't even started the brand new motor yet....but those look so good.
Thanks for the link
08-21-2020, 09:20 AM | #1342 | |
Marc
08-21-2020, 10:21 AM | #1343 |
Marc..couldnt get your Ebay link to work..
I did search it by using (Vintage Cloth Braided Spark Plug Wires) and found them
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 08-21-2020 at 10:27 AM. |
08-21-2020, 11:42 AM | #1344 | |
Marc
08-21-2020, 01:22 PM | #1345 |
It says.....
(We looked everywhere..Looks like this page is missing.) But that is the one I saw... Tons.performance
08-22-2020, 12:56 PM | #1346 |
looking good! getting the body on is a big step
those plug wires look really good. post up a link if you have time
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
08-23-2020, 06:14 PM | #1347 | |
Marc
08-25-2020, 08:02 PM | #1348 |
you arent kidding! my daughter is still home, since march!
08-26-2020, 08:23 AM | #1349 |
So one item that surfaced when I dropped the body back on was how buried my battery was. The problems we're A. I couldn't easily unbolt the leads. B. it would be very difficult to remove the battery for replacement. I always want access or a way out on any serviceable item. An example of this is why my rear notch cover for the floor is bold (opposed to weld in) in to allow access to the rear mechanical's. The remedy was not pretty. Because the mounting bolts where hidden behind the battery I had to go mid evil and cut the battery box in 1/2. The solution was a drop down battery box. I love these things. I used one similar on my 48.
Oh...and there's this. My oldest son Cooper turns 16 in Nov. I have been looking for something for him to drive. For years I had driven past a mid 90's 2 door 4-wheel drive Blazer (last year of full size Blazer) sitting next to a barn at a farm by my moms. I stopped by last week to inquire. A deal was struck (For cheap) and we drag it home Friday. This should make a fun father/son project. I needs a fuel pump and some general stop and god stuff. Thanks Marc
09-02-2020, 06:47 PM | #1350 |
Awesome to see all the progress pics of your build!
