08-23-2020, 11:19 AM | #1 |
Help with tilt column
Looking for tilt column/shift for my '69 suburban. Currently has tilt out of 80's w/floor shift and key in column (key assy removed) and B&M floor shift. Want to go with column shift/tilt. I contacted a member here that sells columns, but shows as account suspended (randy500). Aftermarket ask for column length and not sure where that measurement is taken and priced from a couple hundred to over a thousand?!
1955 Chevy, 2 dr post, my first car 1969 Chevy C20 Suburban, 6.0 LS w/4L80 2001 Silverado Z71, 5.3 extended cab Last edited by 19Suburban69; 08-29-2020 at 09:18 PM. Reason: Change title |
08-23-2020, 03:28 PM | #2 |
Re: tilt column
I thought I didn't had a drop in column for your burb.
08-29-2020, 06:43 AM | #3 |
Re: tilt column
Looks like a 32 or 33.
Just something to look at. https://www.ebay.com/itm/1967-72-CHE...gAAOSw5VtZ~QWy There are many other choices and brands. The short shaft or intermediate shaft is adjustable.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 08-29-2020 at 06:45 AM. Reason: words |
08-29-2020, 02:44 PM | #4 |
Re: tilt column
Thanks, I saw those on eBay. Confused because they’re 36” shaft and I’m measuring either 32 or 33” is needed so shift linkage is close to firewall. I like the fact they’re complete with neutral safety switch. I’ll probably have to modify anything I put in because previous owner put in 80’s tilt. Has hole for key and I want to leave key in dash. Can someone post pic of shaft/linkage?
1955 Chevy, 2 dr post, my first car 1969 Chevy C20 Suburban, 6.0 LS w/4L80 2001 Silverado Z71, 5.3 extended cab |
