Old 08-25-2020, 10:32 PM   #1
variationperson
variationperson's Avatar
alternator
Ok here my question I have a 69 GMC truck my motor was bad so I put in a motor from a 1976 Malibu stationwagon and the old motor relay for the alternator was on the core support.so since new one has it built in on the alternator .how do i hook it up .the old wires were red,white,blue,black thanks
variationperson is offline   Reply With Quote
Old 08-25-2020, 10:38 PM   #2
geezer#99
geezer#99's Avatar
Re: alternator
Try this.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
Old 08-25-2020, 11:55 PM   #3
variationperson
Re: alternator
thank you very much
Old 08-26-2020, 12:29 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: alternator
Here is a more informative way to do it which includes a newer alternator than yours as well as the one you have.
http://67-72chevytrucks.com/vboard/s...d.php?t=417872
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-27-2020, 08:23 AM   #5
Mike C
Mike C's Avatar
Re: alternator
I trust that you kept the short water pump and pulley setup from the 69 and did not use all the long pump stuff from the Malibu?
If you did, switch back to all the short pump stuff. You will be happier long term... the Malibu alternator bolts right into the original brackets. Then just follow the instructions as outlined above for using the internal regulator alternator.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
