Old 09-01-2020, 11:49 AM   #1
StylEmon
8 Lug Hubs to 6 Lug Hubs??
Hey all, this may be my first post, although I'm a long time lurker. Lots of good info on this site, but I'm having trouble tracking down a situation like mine.
I'm looking at doing a disc brake conversion on a 66 GMC RWD with a 3/4 ton suspension and 8 lug hubs. Can I swap the hub with a 5 or 6 lug hub? Or do i need to swap the entire axles/suspension?
Are there are 8 lug disc brake conversions? Where would i find the them along with the 3/4 ton drop spindles?
I'd prefer not to put an adapter in there and would like to just do this all with the disc brake conversion.
StylEmon is offline   Reply With Quote
Old 09-01-2020, 12:19 PM   #2
gmc684x4
Re: 8 Lug Hubs to 6 Lug Hubs??
Project Copperhead has a 5 lug dana 60 in it done by dts
You can try contacting them to ask about converting the axle
For brakes you can contact captainfab on here he makes several brake brackets for disc conversion
https://staceydavid.com/partners/dts...in-specialists
gmc684x4 is offline   Reply With Quote
Old 09-01-2020, 12:25 PM   #3
CastIron
CastIron's Avatar
Are you only doing the converting the front brakes to disc?
Here's a kit for that (available with 2.5" dropped spindles):
https://www.performanceonline.com/19...-8-Lug-Deluxe/
CastIron is offline   Reply With Quote
Old 09-01-2020, 12:35 PM   #4
StylEmon
Great find! it looks very similar to the Western Chassis kit.
I wanted to do the rear as well.. but that's a nice kit. I'll call em and see about a 4-wheel conversion.
Old 09-01-2020, 12:37 PM   #5
StylEmon
Great! thanks for the recco. I'll reach out and see what captainfab thinks.
I know there are more rim options for the 5 lug, but i'm was thinking of going 6-lug since i've got a 3/4 suspension.. not sure if it matters. I won't be towing a camper or anything.
Old 09-01-2020, 12:53 PM   #6
StylEmon
it looks like POL has the rear 8 lug kit also! That makes things much easier.
https://www.performanceonline.com/19...it-rear-8-lug/
Old 09-02-2020, 12:40 AM   #7
mr48chev
mr48chev's Avatar
Originally Posted by StylEmon View Post
e.
the answer to the first question is NO, as there are no parts available and it isn't practical to redril the hubs and drums for this.
Second queston = Yes, several outfits make caliper brackets for 8 lug floater rear axles that usually use a 4x4 front disk brake rotor and a GM caliper.
Third, that I am not sure as have never researched it.
Are you the guy on FB who was wanting to use a 3/4 ton axle for a "gasser"
My ongoing truck projects:
Old 09-03-2020, 06:47 AM   #8
Don't the front suspension assemblies out of 71-87 GM trucks swap straight up under the mid-'60s trucks? From experiences I've read about experiences with POL I'd steer clear of that outfit. Maybe people don't post good experiences, but all I've seen have not been good.
Old 09-03-2020, 09:38 AM   #9
SCOTI
SCOTI's Avatar
Correct.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-04-2020, 07:12 AM   #10
StylEmon
I’m not the FB guy, must be that time of year for doing silly things to c20s.
Thanks for the reco on the 4x4 GMC parts
Old 09-04-2020, 07:13 AM   #11
StylEmon
This s perfect! Just what I needed. Thanks.
Old 09-04-2020, 08:34 AM   #12
Nice to stay as OEM with parts as possible. Just keep your own build sheet. Plus it's everything you need that you know works together in one package.
Old 09-05-2020, 03:34 PM   #13
Warrens69GMC
Warrens69GMC's Avatar
I was able to pick up a 1977? C20 rolling chassis complete with a good 14 bolt and 3.73 open for $150
Looking to get a 1965-6 C20 for it.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
