#26 | |
Re: Frame mounted Dual chamber Master cylinder for Drum/Drum..who's done it? Who like
Definitely something to look into!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#27 |
![]() Join Date: Aug 2010
The part is called power brake filter
Dorman 80195
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#28 |
could this filter be mounted at the intake manifold instead of on the fire wall and work properly?
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
#29 |
The p.b. Filter should be mounted vertically with the straight inlet at the bottom and be higher then the top of the carb . The higher the better.
Good location would be just below the firewall seam or if you’re going for a shaved firewall mount it inside the firewall. Just be sure that the vacuum line has a down hill slope to the manifold. The line going to the p.b. Booster can be a hard line with short vacuum hose to the booster. Be sure to use power brake vacuum hose , it’s thicker and fuel vapor safe and won’t collapse.
#30 |
ok, thanks for the info. i will add it to my project list
#31 |
I found the GM version on ebay for about the same price:
GM 17056236
