Old 09-09-2020, 10:06 PM   #1
Ramiro0727
LED turn signal issues
So I have United Pacific LED lights all around and my turn signals don’t work when my headlights are on but when they are off the turn signals work but as soon as i flip the switch the brake lights get bright as if you’re stepping on the brakes and don’t blink at all. I added 2 grounds in the back off the bed to frame and one off the block and frame.
Thanks ,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 09-10-2020, 07:17 AM   #2
JMD
JMD's Avatar
Re: LED turn signal issues
Do you have the United Pacific led flasher? I had the exact problem you are describing and I believe that was the fix.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 09-10-2020, 11:54 AM   #3
Ramiro0727
JMD,
Yes I have the LED Flashers with the ground cable on them.
Thanks,
Ramiro
Old 09-10-2020, 04:48 PM   #4
JMD
JMD's Avatar
Are they United Pacific brand flashers though? There’s something about their flashers specifically that make them work with their LED tail lights.
Old 09-11-2020, 12:17 PM   #5
Ramiro0727
JMD, not sure which brand my son purchased.
Ramiro
Old 09-11-2020, 04:02 PM   #6
El_C10
I've read installing a reverse polarity flasher is sometimes required. This maybe what you need.
https://www.raneystruckparts.com/led...tension-wires/
El_C10 is offline   Reply With Quote
Old 09-11-2020, 04:39 PM   #7
Ramiro0727
EL_C10 i have one of those flashers with the ground cable. The one my son ordered didn't come with the lower base.
Ramiro
Old 09-11-2020, 04:48 PM   #8
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
While it will be a bit of time before I can install my United Pacific LED lights, this is what their flasher looks like. When I ordered from Speedway, they recommend this United Pacific flasher.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-11-2020, 04:58 PM   #9
Ramiro0727
Ramiro
Old 09-11-2020, 05:02 PM   #10
Ramiro0727
Thanks, Rich72C10. looks like we need to purchase a new pair of flashers. Ours doesn't have the reverse polarity base.
Ramiro
Old 09-11-2020, 05:06 PM   #11
Ramiro0727
Rich72C10 so If i purchase those new flashers with the reverse polarity base. Will that take care of my problem with the turn signals not working when the headlight switch is turned on? they work with the headlight switch turned off.
Ramiro
Old 09-11-2020, 05:11 PM   #12
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Hi Ramiro0727 - I couldn't say either way (I have my doubts). My brother still has my truck, he is finishing up a full SBC/TH350 rebuild. I am just collecting "parts" for little upgrades for it when it gets back into my hands!
But I am converting all the lights to LED. I got them from Speedway and most of them are United Pacific LED.
I just thought I post a photo of the United Pacific Flasher, so you could easily see it. In about two months I'll be able to feedback any issues I have or success
Richard
Old 09-11-2020, 06:30 PM   #13
El_C10
Ramiro
Ramiro- Im running LEDs all around (Except turn signals, those are next) and I can honestly tell you every truck is slightly different. What works on some doesnt always work for others. I will keep you updated once I install my turn signal LED lights. I might need the fever polarity adapter. I’ll let you know.
Cisco
Old 09-11-2020, 07:59 PM   #14
jessemthompson
Thanks ,
Ramiro
I went through this problem with the lights being fully lit like the brake lights were on when you turned on the headlights. The UP flasher did not fix my issue. I ended up wiring in a dummy 1157 plug into the rear harness to add resistance to the circuit and all works well now. They also sell resistors you can wire in that will do the same thing. Now the UP flasher should help with your turn signal issue though. I had a thread on this in the electrical section about a month ago.
jessemthompson is offline   Reply With Quote
Old 09-12-2020, 07:38 AM   #15
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Arrow Re: LED turn signal issues
Interesting jessemthompson and a good read of your thread (link below). Glad you posted that about your 72 and I'll keep that in mind when I end up doing mine. I suppose this would have the potential to correct two things: Flashing Speed and
Tail light issues
While this YouTube is clearly for a newer Chevy, I suppose this 25 Watt load resistor could be the fix for the Brake Light intensity issue? I suppose this would have the potential to correct two issues: Flashing Speed and Brake Light intensity. Heck I might do this and return the "Flasher" and get a few bucks back.
How to Install a Load Resistor for LED Tail Lights
superbrightleds.com 1969 Chevrolet C10 Pickup Load Resistors
LED Light Load Resistor Kit - LED Turn Signal Hyper Flash & Warning Fix - 50W LED Load Resistor kit
Current Draw 2.25A (2250mA)
Ohms 6 Ohm
Wattage 50 Watts
O'Riley's
Sylvania Load Resistors For LED Mini Bulbs (Pack of 2)
Part # LOADRSLBX2
Richard
Old 09-12-2020, 11:19 AM   #16
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Due to heat that would occur with load resistors, I am thinking about these. If I am needing them after updating to LEDs (if I have Brake Light intensity issues).
Morimoto HD Load Resistor
Richard
Old 09-12-2020, 11:36 AM   #17
jimijam00
Those LED Flashers, like above, contain a load resistor.
jimijam00 is offline   Reply With Quote
Old 09-12-2020, 11:47 AM   #18
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Interesting, which would make sense. I am not doing bulb replacements but whole light/lense replacements from speedway. I am just reading every thread I can on this subject to be ready for anything that pops up! I'd be very happy they they all just work but I do plan to install one at a time and test as I go too!
Richard
Old 09-12-2020, 06:13 PM   #19
Ramiro0727
I ordered a pair of the reverse polarity adapters. Also I’m going to take a look at my turn signal switch.
Ramiro
Old 09-12-2020, 06:57 PM   #20
jessemthompson
You need the reverse polarity switch for the turn signal side, but not the hazard side.
Old 09-12-2020, 07:11 PM   #21
Bobbysgmc
I did the same thing with my truck.Had to put a couple of old style bulbs back in to make everything work right.Something about not enough voltage being drawn.
Bobbysgmc is offline   Reply With Quote
Old 09-12-2020, 07:14 PM   #22
Ramiro0727
Bobbysgmc. Where did u put old style bulbs at? All the lights in my sons truck are LEd.
Ramiro
Old 09-12-2020, 08:06 PM   #23
jessemthompson
You have to wire in an additional 1157 plug. I did it under the bed of the truck. Just cover the bulb and wire it in before it splits between the tail lights.
Old 09-12-2020, 08:17 PM   #24
Ramiro0727
Jessemthompson wire it before the the 2 lights? To which colored wire?
Ramiro
Old 09-12-2020, 08:26 PM   #25
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
here is a wiring diagram - I assume the colors are correct - I got it from another thread that I have saved on this subject. Posted by Andy4639
Information needed on LED side marker lights
boo - its a thumbnail and you cannot see the original size but you can get the full size from the thread above.
Richard
