09-10-2020, 05:45 PM | #1 |
Swap F&R diff between 76 and 81 truck
I have a 1976 K25 parts truck and wish to swat the F&R differentials into my 1981 K20 truck. My question is this doable or do I need to also change drivelines? The trucks have different transfer cases too.
Thanks for any help you can provide in this project |
09-11-2020, 11:17 AM | #2 |
Re: Swap F&R diff between 76 and 81 truck
Axles are very doable, shaft lengths would depend. The one that may give you an issue would be the front
09-11-2020, 12:35 PM | #3 |
All about them K’s
It should be a pretty straightforward swap. I don’t believe you’ll have drive shaft issues but a tape measure would confirm one way or the other.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
09-11-2020, 02:55 PM | #4 |
Thanks all for the info
09-12-2020, 02:10 AM | #5 |
K5Camper
Depends on the t-case situation. The axles bolt in. The earlier front shaft should be the Saginaw style where you have individual saddles for the u-joint on the front output yoke. Also the rear shaft on the early one might be fixed yoke if it's a 205.
The front on the later truck will most likely have a flange style mount for the cv to the front output of the t-case. Also, if the later truck has a 208 it most likely is a slip yoke rear output. But as long as the size of the u-joint is the same at the front and rear diffs as the axles you are pulling out you should be able to re-use the shafts.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
