#26 | |
Re: ???Coolant Temperature Sending Unit???
Woody |
#27 |
I've been doing a lot of research on this exact topic, as I needed to replace the water pump on my Corvette. I found an excellent article written by one of the NCRS guys about how cooling systems work, and how to troubleshoot overheating issues (as they are common in early Corvettes). A few of my lessons learned:
1. Pusher fans are a band aid solution for something else wrong with the cooling system 2. Ignition timing, especially with vacuum advance has more to do with cooling than I ever imagined 3. Thermostat temp setting has nothing to do with the maximum cooling ability of the system, or what your temperature will rise to in a given situation. If you shoot me an email (GPaules03@gmail.com), I can send you the full .pdf article. It is specific to the cooling system in the early Corvettes, but 95% of it applies to any old cooling system.
1972 C20 Suburban 1964 Corvette Coupe 1997 Lexus LX450 |
#28 | |
Woody |
#29 |
No need to apologize for posting lots of information on a problem. You have done a great job troubleshooting this problem.
A couple of thoughts. I am guessing that the motor has a fair amount of miles on it from your report on how dirty the water was. Tired engines can run hot. I had overheating problems on an old 236 Chevrolet 6 that was cured by removing the water pump and physically rodding the rusty clay that had collected in the bottom third of the water passages around the cylinders. You may have a similar situation. However it's nowhere as easy to access the passages on a BBC as it is on a 235. And as FlyNavy says ignition timing can be a big factor. Do you have access to a distributor machine? Have you tried disconnecting and plugging the vacuum advance hose to the distributor to see if that helps? Pusher fans are really more of an air flow reducer and should not be used unless there is on option for a puller fan. And it is hard to tell from the photos, how much of the fan blade sticks out past the rear edge of the shroud? You should have about 1/3 of the fan blade past the back edge of the shroud. This link may help. http://67-72chevytrucks.com/vboard/s...d.php?t=582331
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 09-10-2020 at 09:21 PM. |
#30 | |
Your first thought lines up with what I was wondering about...restricted water passages...but my 1989 454 is old and new at the same time as when we had the heads off and oil pan removed (at my friends shop), the motor looked as if it hadn't had any miles put on it since new. We did not specifically look for water passage restriction at that time, but nothing jumped out at us either. I also realize that even without putting miles on a motor, the water passages are susceptible to the corrosive elements from day one...and may actually be more susceptible due to non-use (water/air just sitting in the passages) as my Suburban sat non-op for 4 years before I purchased it. Like you said, not real easy to get to the passages on a BBC...so that may have to wait until the motor comes out when the body and paint work gets done? I haven't received the "cooling info" from Greg (FLYNAVY) yet, but I am curious about my timing...and will try plugging the vacuum advance to see...although my mechanic buddy usually sets things up "by the book" and there is no indication of pre-ignition/detonation as far as I can tell? I'm not sure if he has a distributor machine or not...but I'll ask. You didn't mention the carburetor...but I'm pretty sure it is a tad on the rich side, which should be better for cooling than being on the lean side...but I guess knowing that for positive would be a good thing as well. I'm not quite sure what you mean about the pusher/puller fan air flow reducer situation...but I wouldn't give up my mechanical puller fan...I would just add an electric pusher fan in front of the radiator. The fan blade edge is just peeking out the back side of the shroud...but I could only get about another inch exposed IF I bought one of Hayden "short shaft" fan clutches...which I might try? There is also the thought that 190 is nothing to complain about, and I am thrilled that I attained that "level of coolness"...so maybe I'm being a little greedy by wanting to be cooler? In any case...I do appreciate your input...as well as everyone else's! Woody |
#31 | |
The devil is in the details when adding a pusher fan. Matching the performance of the 2 fans so they complement each other is where the real work is. Some late model high performance Corvettes have both a puller fan and a pusher fan that the base model Vettes don't get. GM discovered a need for more cooling and then carefully engineered a solution. I have no knowledge as to how or when the fans operate or are controlled. Or even what the goal was. I've just seen them and was surprised to see the pusher fan. I just noticed you have A/C. How is the air flow through the condenser?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#32 |
woody, apologies, I never received your email....checked regular and the junk folder. Would you mind resending? GPaules03@gmail.com and Ill get it right out to you.
Thanks!
#33 | |
Woody |
#34 | |
***UPDATE*** I was reviewing the notes I made before I started removing the original parts and realized that the measurement between the radiator and the face of the thermal clutch is actually 1 3/8" not 3 1/2" (not sure where I got that number from???) so using the short shaft clutch would only put the total distance away at 2 3/8" (more than the optimal distance, but should still register the heat enough to work correctly). That would move the back edge of the fan blades out of the shroud to a total of approximately 1 1/2", which could make a difference. If it doesn't help, I can always change it back as I'm kind of getting good at unbolting these same parts! Woody Last edited by Beach-Burban; 09-11-2020 at 05:14 AM. |
#35 |
email sent Woody!
#36 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
