Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-13-2020, 01:15 PM   #1
Mr3Speed
Wink Sanden 508 Wiring
Hey wondering if anyone could help me out got a new sanden 508 for an original ac truck and need to wire it. A black and a dark green wire go into the og compressor. The sanden only has one black wire. I’m assuming that because the dark green is switched 12v from the poa valve/pressure switch that, that dark green wire should go directly to the black wire on the sanden? Is that the case? Have any of y’all done it? Is there another way I should be wiring it? Anything helps thanks!
Mr3Speed is offline   Reply With Quote
Old 09-13-2020, 09:21 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Sanden 508 Wiring
Dark green is hot and the black is a ground with a diode if I remember correctly.
So yes you would tie the DG into the new compressor for 12 volts. I'm not going to say use the black without you furnishing a picture of it though to confirm.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-14-2020, 11:58 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Look at the 1 minute mark and the clutch only has the single black wire. He says the coil is grounded so the black wire has to be the hot wire for the green to connect to. If you have a voltmeter measure the ohms between the black wire and the coil. If you get some resistance then you are reading the coil windings resistance and the black wire is the hot wire and the coil is grounded to the compressor body.
https://video.search.yahoo.com/yhs/s...46&action=view
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-15-2020, 12:44 PM   #4
Mr3Speed
Thank you I think we are in the same page and I’ll do some testing this afternoon. But it would be awesome if you link directly to a YouTube video I’m fairly sure my yahoo isn’t pulling up the same video. Another question closely related would y’all know what this little connecting wire with a black ball(see picture attached) on it is because if dark green is power and black is ground they shouldn’t be connected right?
Old 09-15-2020, 08:47 PM   #5
RustyPile
RustyPile's Avatar
That's the diode Andy spoke of.. It "clamps" the voltage spikes created when the magnetic field collapses as current is removed from the coil windings..
RustyPile is offline   Reply With Quote
Old 09-16-2020, 12:53 PM   #6
Mr3Speed
So that black diode shouldn’t be necessary for the sanden?
Old 09-16-2020, 07:47 PM   #7
SilverMiner
SilverMiner's Avatar
This information would be very useful to me as well. VetteVet, could you please give a direct link to YouTube? The multitude of videos the Yahoo link throws up all seem generally useful, but a direct link to the video you mention specifically is close to exactly what I'm also looking for.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 09-16-2020, 09:24 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
See if this works.
https://youtu.be/w3aqgpKz5nI
VetteVet
air conditioning, compressor, wiring
