Old 09-16-2020, 10:28 PM   #1
Asshat
Asshat's Avatar
How to secure hubcap to rim
That’s the problem.
There are no clips, and the hubcaps were glued to the old rims with silicone RTV sealant.
I was thinking about drilling two or four small holes through the hubcaps and drilling/ tapping the rim with a #10-32 screw. However, I hate to destroy the hubcaps.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 09-16-2020, 10:45 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: How to secure hubcap to rim
Maybe you could add some clips to the wheel that will hold the hubcap in place?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-16-2020, 10:56 PM   #3
jocko
jocko's Avatar
https://www.chevsofthe40s.com/detail...ning_Clip.html
http://www.classictruck.com/product/...BoCg_IQAvD_BwE
Old 09-16-2020, 11:03 PM   #4
Asshat
Asshat's Avatar
I did see those clips, however, they are not for the 1963 Chevies. I’m not sure if my hubcaps are specifically 1963+.
I was also thinking a machine screw would deter a thief from just popping off the hubcap.
292, 4-speed
Old 09-16-2020, 11:53 PM   #5
Asshat
Asshat's Avatar
I did find this...
http://www.laroke.com/larryk4674/smo...er/hubcaps.htm
Might be worth looking in to.
I wonder if anyone has ever drilled their hubcaps to secure them to the rim.
292, 4-speed
Old 09-17-2020, 12:06 AM   #6
raylube
raylube's Avatar
https://www.stovebolt.com/ubbthreads...&Number=723557 Follow the links on this site it shows you how to use the 1/2 ton clips on 3/4 wheels. Also if you have a junk hubcap to cut up also helps place clips.
raylube is offline   Reply With Quote
Old 09-17-2020, 12:17 AM   #7
raylube
raylube's Avatar
There is also few threads about this. Try the search function.
Old 09-17-2020, 09:58 AM   #8
jayoldschool
Moderator
Those are clip caps. You need to screw clips to the wheel.
jayoldschool is offline   Reply With Quote
Old 09-17-2020, 03:42 PM   #9
cwcarpenter98
Those look to be the correct 61-63 clip hubcaps for your truck. Your truck did not have the original wheels on it when you bought it
Christian Carpenter
Old 09-17-2020, 07:49 PM   #10
DPowers
One foot in front of the other
DPowers's Avatar
Original rims would have looked like this.
DPowers is offline   Reply With Quote
