Old 09-21-2020, 12:12 AM   #1
GoingDown8
66 c10 steering column
Hello everyone, ive never posted before but have been reading this forum for a long time. I currently have the front clip, engine and trans out of my 66. Have painted the front crossmember and suspension. And im getting ready to paint the firewall. Nothing fancy, just cleaning up the engine bay before the new engine goes in. I just pulled my steering column and am looking into rebuilding or replacing it. Does anyone have any experience with the cheaper columns on websites like Brothers trucks? What needs to be done to convert it to a 2 piece steering shaft? I am already doing a power steering conversion also. Or would rebuilding the stock column be easier? Havent found much info regarding that either. Thanks for any help.
GoingDown8 is offline   Reply With Quote
Old 09-21-2020, 07:04 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 c10 steering column
FAQ section: https://67-72chevytrucks.com/vboard/...d.php?t=646002
I did a search there for column:
Steering Columns
tilt steering for our trucks, aftermarket or later model swap ins? : May 2008 / 15 posts
DPowers 1966 build thread - post 8
shows the install of a tilt steering column from a 1964 Impala into his truck.
Tilt column How to install : January 2005 / 24 posts
Neutral safety on van column : August 2003 / 9 posts
Steering column Q : December 2002 / 2 posts
Everything you wanted to know about van column install : August 2003 / 25+ posts
Steering column question???? : February 2007 / 15+ posts
tilt column : March 2005 / 10+ posts
GM Column help : February 2008 / 9 posts
Tilt column help needed please : January 2014
information about which wires go where, by color and purpose
steering column question : June 2014
Old 09-21-2020, 07:33 AM   #3
GoingDown8
Thanks.
Old 09-21-2020, 08:39 AM   #4
cwcarpenter98
cwcarpenter98's Avatar
If you like your stock column, rebuild it. When you go to shorten the shaft for the power steering, you can also add a collapsible intermediate shaft from a squarebody or 67-72 c10. I'm not sure which years from the 67-72 truck though
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-21-2020, 10:47 AM   #5
vince1
I took a collapsible shaft out of a 67 and put it in the 66 column. It fit right in, it was the same length. I'm not sure if a 68 will fit. The bearing configuration at the bottom of the column may be different. I am only going on what a guy at pick n pull told me, that I could use a shaft from a 67. I used a bushing at the bottom rather than the bearing and still used the spring as found on the 66 (and 67?).
I plan on removing it though and installing a column from a van so that I can remove the 4 sp and put in a TH400.
vince1 is offline   Reply With Quote
Old 09-21-2020, 07:55 PM   #6
GoingDown8
Thanks for the info. I may just get a tilt column and an intermediate shaft. Have to think about it a little more.
Old 09-24-2020, 11:24 AM   #7
SCOTI
SCOTI's Avatar
Helpful info!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-04-2020, 07:03 AM   #8
Lugnutz65
Lugnutz65's Avatar
I wrote up a 4 part DIY when I rebuilt my 1963 manual column. Automatic columns are not covered in my DIY. The 60-66 manual columns do have minor differences depending on the year. IIRC, the 64-66 manual columns are all the same.
LINK TO MY STEERING COLUMN DIY PAGES
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 10-04-2020, 03:51 PM   #9
GoingDown8
Thats a great write up, that will help alot. Thank you.
