09-21-2020, 04:05 PM | #1 |
headlight switch rewire
ok so many moons ago i thought i found something on here that said how to jump your stock head light switch to make your parking lights work while the headlights are on? but for the life of me i cant find it can you all help me please?
09-21-2020, 11:35 PM | #2 |
Re: headlight switch rewire
Start by locating the parking light wire on the headlight switch plug ... it should be a purple wire (right next to the light blue wire that goes to the headlight dimmer switch).
Next, find the empty cavity in the headlight switch connector (should be near the brown wire that powers the tail lights). With the connector unplugged from the switch, extract the purple parking light feed wire by using a small screwdriver or terminal pick to carefully depress the latching tang on it's terminal. Pull the wire (with the terminal attached) out of the connector. Bend the terminal's latching tang back out a little and snap it into the previously identified empty cavity near the brown wire. Note, if you have a truck with factory installed cab lights, that wire might already be occupying that otherwise empty terminal on the headlight switch connector. |
09-22-2020, 01:12 AM | #3 | |
09-22-2020, 08:20 AM | #4 |
See attached
1962 chevy short and wide 2015 z71 1967 SS Chevelle |
09-22-2020, 10:54 AM | #5 | |
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-22-2020, 01:28 PM | #6 |
This is a switch that has had it done the purple wire is removed from the right by the blue wire to the empty one that was next to the green most of the switches the blue wire is actually yellow this could possibly have been replaced at one time
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
09-22-2020, 05:18 PM | #7 |
All of you guys are so awesome here thank you for all your help i really love how this community bands together and goes out of their way to help others thank you very much guys this place is my home away from home
09-22-2020, 06:10 PM | #8 | |
Yes, from what I've seen, GM changed the color code on that wire from light blue over to yellow sometime in the mid 1980's. |
09-22-2020, 07:58 PM | #9 | |
09-24-2020, 08:45 PM | #10 |
subscribed
09-24-2020, 09:34 PM | #11 |
I had no idea...what a great thread. Bookmarked for future use.
09-25-2020, 07:50 AM | #12 |
Moderator
Here is another link - http://67-72chevytrucks.com/vboard/s...d.php?t=614234
09-27-2020, 12:29 PM | #13 |
Just tried this and now wish I didn't. The purple wire is rather fragile and the connector broke off when I tried to pull the wire out of the plug.
09-27-2020, 12:50 PM | #14 |
Moderator
Been a while since it was re-wired?
09-27-2020, 03:21 PM | #15 |
You can get new connectors but Yeah that’s a bummer
