![]() Join Date: Apr 2016
Power steering input shaft free play
Hi Folks,
I have a 1969 CST/10 with power steering. I followed this procedure from TX Firefighter to replace the input shaft and pitman shaft seals on my power steering gear box. http://67-72chevytrucks.com/vboard/s...d.php?t=619634 It is back in the truck and working, and it doesn't leak any more. I have a question about the steering gear that I wonder if some of you folks have experience with. I have more free play in the input shaft than I had before the seal replacement. The shaft moves freely over a certain amount of range. I have to turn the steering wheel past this amount of free movement before the pitman arm moves to steer the truck. I had a much smaller amount of this free play before replacing the seals. When doing the TX Firefighter procedure I put the adjusting plug back in, screwed it down and then backed it off a little and put the locking ring on. I am reading the overhaul manual regarding this adjusting plug, and I don't understand what the adjusting plug adjusts. I do recognize a difference in procedures. When I followed the TX Firefighter procedure I turned the adjusting plug until I could feel it making contact and backed it off. The overhaul manual says tighten the adjuster plug "up snug" and then back it off. Is this adjustment what takes out the free play in the input shaft? I don't understand the part about measuring valve drag, and adjust thrust bearing preload to obtain 1/2 to 2 in lbs in excess of valve assembly drag. What does all this mean? Last edited by dmjlambert; 09-19-2020 at 02:41 PM. Reason: corrections in wording |
Re: Power steering input shaft free play
OK, this is what I did to resolve it. I did a lot of reading and researching until my eyes were tired. I found these interesting posts on various sites.
https://www.freeasestudyguides.com/s...djustment.html http://www.earlycj5.com/xf_cj5/index...ustment.53495/ https://www.elcaminocentral.com/thre...ing-box.27532/ https://www.gmtruckclub.com/threads/...rocedure.3698/ https://www.larescorp.com/toolbox/sk...ower-steering/ Based on all I read I think I better understand what is being adjusted by the 2 adjustments on the steering gearbox. Both affect the amount of free play or slop in the steering. The primary adjustment is the thrust bearing preload, and that is the adjustment that would have been disturbed when I replaced the input shaft seals. The adjustment with the Allen wrench and lock nut on the steering gearbox top is the over center preload, and that is the secondary adjustment. Over center preload is a fancy way of saying you are adjusting how closely the sector gear on the pitman arm shaft meshes with the worm gear that the input shaft controls, and particularly how close they mesh when you are passing over the center (driving straight). There is a little more resistance in the center of steering compared to off-center, that is because of this adjustment. You don't want it to be too tightly meshed when passing over center, because it will cause unnecessary wear and will cause the steering wheel to not return to center after a turn. I am thinking if you don't have a little bit of additional resistance at center, the return to center would overshoot or the steering would feel sloppy. After reading the overhaul manual again, I had developed a feel for what some of the words mean. The main confusion for me is how there are multiple names for the same thing. For example, the input shaft, the worm gear shaft, steering shaft, stub shaft all mean the same thing. And in the case of the Chevy overhaul manual apparently there are circumstances where they also call the input shaft the lower shaft (paragraph 9b). To me that's just crazy. But I know they are referring to the input shaft because a 12 point 3/4 inch socket doesn't fit on the pitman arm shaft, and the input shaft is the one with multiple turns that you would have to count. The manual also says to measure stuff, but it doesn't say how those measurements are done. Some of those links I mention get into better detail about the procedures of doing the measurements. I decided to do the adjustments per book, but then I don't have an inch lb torque wrench, and when I went to looking for one I could not find one that I thought would accurately measure in the range of .5 in lb to 14 in lb. In lb torque wrenches are typically in the range of 0-80 in lbs, and there is no way to see .5 to 2 in lbs with any amount of decent precision on one of those. The torque wrench would probably need to be a 0-20 range one, and those are big money and you can't just go up to the store and get one. It would have to be ordered. I went back to Tx Firefighter method, and re-interpreted the instructions. "Screw the cartridge down until it bottoms snugly. Don't force it, its real obvious when it bottoms out. Then, make a mark of some kind as reference and loosen it half an inch (.5 inch)." I was previously too worried about his caution about "don't force it." Because the over center preload adjustment should affect the thrust bearing preload, most instructions (but not the Chevy instructions) tell you to back off the over center preload before doing the thrust bearing preload. Then re-do the over center preload. I decided I would simply take the steering off center when doing the thrust bearing preload. This time I tightened the cartridge down. Throw caution to the wind and just tighten the sucker. There was not very much movement it would do between making it what I call lightly snug, and putting what I thought was 20 ft lbs on it, which was mentioned in on the El Camino Central link I gave earlier. That site mentions tightening it and backing off 1/2 inch same as Tx Firefighter mentions. After backing off 1/2 inch from tight, I put a 12 pt socket on the input shaft and used a small breaker bar to move it. It moved smoothly, and in my judgement it moved with ease and probably only had a couple of inch lbs of resistance. I put the locking nut back on and took it for a test drive. The steering feels quite fantastic. I made my own face pin spanner from a plumbing wrench I have but seldom use. |
Thanks for the write-up. I'm about to dig into my steering box as well. I bought the full rebuild kit though.
That's a great tool there!
72 C10 lwb fleetside -stock 350/350 combo |
All about them K’s
![]() Join Date: Jun 2014
Good info here. I’m gonna look into mine as well. I’ve got probably 1/4 turn of free play driving down the road and the rest of the suspension it tight.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Aug 2017
Good info David, will need them in winter time for overhauling mine.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 |
Additional stuff: I was not overhauling, I was only replacing the seals that were leaking and other than the leaks my gearbox was behaving fine and did not have any free play. Using this method of tightening the input seal cartridge and backing it off by a measured amount does not properly calibrate the thrust bearing preload. I decided to accept the risk for my gearbox by using this shortcut method.
I think the only way to correctly do it is using 3/4 inch 12 point socket and an inch pound torque wrench, probably requiring a 0-20 inch lb range beam type torque wrench. I'm not sure about using a clicker type torque wrench, it may actually be better. A clicker torque wrench would require more patience to use it for measuring torque, because you would have to dial in a bunch of values and test over and over, rather than what the clicker is designed to do (let you turn a nut to set torque). I would probably want to have an inch ounce torque wrench also, so I could measure the valve drag, which I think is measure the average torque required to smoothly move the input shaft through the range, with the over center preload adjustment backed all the way off. Then also use the inch ounce torque wrench to tighten the cartridge to add .5 to 2 inch lbs of drag on the input shaft. The over center preload may require an inch lb torque wrench. I am thinking about inch ounces because I understand that torque wrenches do not give the best accuracy when using them at the low or high ends of their range, and also reading how many index marks .5 to 2 inch lbs looks like on the torque wrench would be challenging because it is probably one little tiny index mark of the full scale. I could be mistaken and the whole job may be doable with a 0-80 inch lb torque wrench. I was kind of hoping somebody thoroughly familiar with doing these settings by the book may read and reply. |
Tags |
gear, power steering |
