#51 | |
Re: Wizit's bagged 60 GMC build V2.0
I also didn't want to be 1K into a front sway bar & haven't seen any pricing yet.
#52 | |
$150 for the bar is about as cheap as your going to get for a quality product. They have a fair selection of arms as well including some blank aluminum bars you could have machined with some detail if you desired. ![]() Capture by Wyatt Lassiter, on Flickr
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901 |
#53 |
Nice work. I am envious of the machine work that you do. Nice to have those tools. Are the machine tools your using from work or you have them at home?
#54 | |
For comparison, Ridetechs sway-bar used on their front C10 C/O app has a rating of 1020# (1.5" OD .250" wall construction). I feel I need a larger bar as my starting spring rate is 750# or I would have to utilize shorter arms. Packaging wise, a larger bar would be better for my app. The only ones I see larger on the Speed Engineering site are the wider 'cup-car' spec bars (37" width). I'll check out Kartek. Thanks for the lead.
#55 |
The majority of the machine work you've seen has been done at my work but I also have a mill and lathe in my home shop. Things like the upper links had all of the cnc work done at my work and anything that can be done manually is done in my home shop.
#56 |
Moderator
![]() ![]() Join Date: Aug 2011
Pretty clean machine work. I thought those rear axle brackets were aluminum for a while. Had me all gerfunkled as how you would attached them.
#57 | |
#58 | |
The search continues.
#59 | |
The 1.5 bars are 300m material. Thats whats driving the massive price increase. Those are typically used on trophy trucks to allow for the missive amount of twist it will see. Whats the application that is causing the required high rate? If its not a very long travel I would think you could go down to a much shorter arm. Ive seen guys running 6" arms pretty easily if the geometry is correct. Good luck on the continued search!
#60 | |
#61 |
I got the upper links last week and had to drill and tap them for the threaded bushings on my manual mill.
![]() ![]() I did some cardboard template work and came up with diff side mounts. Cut them out and got it all tacked together. This rear 4 link has been a long time coming so it felt really good to see it all together! ![]() ![]()
#62 |
![]() ![]() ![]() Join Date: Jan 2018
This is one of those builds where you want to have a removable bed floor to see all the artwork underneath
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#63 |
Well said.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#64 |
![]() Join Date: Jan 2015
just stumbled across this build... this is goin to be one mean truck...lookin forward to it
#65 | ||
#66 |
The swaybar components came in. I built the brackets and mocked everything in place. Im not completely happy with the look yet so it may change. I am going to leave it clamped in place for a bit and see if it grows on me.
![]() ![]() I also started drawing up some billet upper arms for the front suspension. with all the billet on the rear it started to make me unhappy with the look of the front suspension. Im looking at using the cross shaft of the Joes racing arms and bolting on the billet arms. They will utilize a standard c10 bolt in upper ball joint.
#67 |
Finished up a few things on the chassis and set it on the ground so I can start figuring out cab mounts.
#68 |
Beautiful
#69 |
Clean. So clean....
#70 |
Wow, that's super nice
#71 |
DAMN That is Beautiful!
#72 |
Moderator
Yep that'll work. Great job.
#73 |
Spent some time last night working on cab mount design. I ordered some cab mount bushings and as soon as I get those and verify thickness I will cut and build the cab mounts and trial fit the cab. That will allow me to start working on the cowl mounting.
#74 |
I'm just glad to be here!
Truly Awesome!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#75 |
Finished the cab mounts and set the cab on the chassis. Next step will be figuring out the grill mounts.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
