07-02-2004, 10:03 PM | #1 |
Resident Young Old Dude !
Autometer behind the Factory Bezel
After quite a few weeks in running the gauges down and of course the Buying them. (three came off of E-bay so I had to do the Auction Bidding process time) I started doing the install yesterday, and this is where I'm at today... I have some final mounting in the back, and wiring the gauge lights. also also the Turn signals, and high beam indicator.. No problem just time consuming..
I hope to get it in the truck this coming week.. |
07-02-2004, 10:22 PM | #2 |
Wow .... Lookin Good Ron..... Can't Wait To See Em Installed.
:d :d :d :d John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
07-02-2004, 10:29 PM | #3 |
that does look nice! is that two oil pressure gauges? or is the smaller a oil temp gauge? couldn't figure it out, but still looks great
07-02-2004, 10:31 PM | #4 |
Lookin good....
How did your attach them to the back...? How about a wiring guide for them...?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
07-02-2004, 10:53 PM | #5 |
That looks great!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-02-2004, 11:17 PM | #6 |
PROJECT 7DEUCE
Those do look damn nice ...
07-03-2004, 10:10 AM | #7 |
GOOD EYE 7gmc2,, yea it's two oil pressure gauges right now....
I used the 2 oil pressure gauges instead of a water temp, Only because of the Water temp capillary tube... I got tired of trying to keep moving around it and was afraid I may break it bending it so much.. I'll put the water temp where the Big Oil pressure is now.. As far as wiring goes,, They are all Mechanical except the Amps, and Fuel Level.then I just need to combine all of the gauge light wires together. I need to come off the stock dash wiring plug for the headlight high beam indicator light, along with the turn signal indicator lights. But the circuit board for the wiring is self explanatory and very easy to follow where the wires run to, So no problem tracing them to the plug. I'll take some pictures when I tear it apart to re-install the gauges for keeps.. It was very easy to do, Just a Jig saw and tin snips to cut some of the sheetmetal. (of course a cut thumb, and poked finger )The green piece of sheetmetal that is inside the cluster stays in but with some cutting modifications, along with the metal plate that bolts to the rear of the bezel. It was far easier then I had anticipated, Just some trial fitting and contemplating... BUT,,, Good Luck on finding the center 3-3/8" gauge...... |
07-03-2004, 10:26 AM | #8 |
Excelsior, You Fathead.
I was thinking about doing the same thing with my bezel because the gauges are iffy and I don't like the Billet Aluminum look. Along the same lines, the crome edging on the factory bezel is patchy. Does anyone have any ideas on how to make it look good? I was thinking of just painting the whole thing black.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
07-03-2004, 10:31 AM | #9 |
Insert funny comment.
Nice work!
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
07-03-2004, 11:31 AM | #10 |
Designated A-hole!
Looks good.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-03-2004, 04:59 PM | #11 |
Who me?
Man that is beautiful!!! I want one! Please give more info when your done till then I'll be droolin.....
07-03-2004, 06:34 PM | #12 |
Dick,,, go check out your local hobby shop, might find some ideas there, if they sell RC cars even better, might be able to find some cool paints, or maybe even a chrome tape that might work, maybe a light black over the chrome, for a black chrome effect, or just gauges that mount flush with th frony of the bezel, just a few i deas i have looked at,
07-03-2004, 08:19 PM | #13 | |
We have many good vendors here on this site that sell new ones. Try THIS ONE Ask for Shawn. These Bezels are not expensive,And you can't beat the look of a new one... |
07-03-2004, 09:46 PM | #14 |
man tha looks super nice. what size gauges did you use for each. better yet do you still have the part numbers for each one. again that looks really sweet.
07-03-2004, 10:36 PM | #15 | |
MUDDBUGG72, And EVERYONE else..... Thanks for the nice words. The large gauges are just standard Autometer "IN DASH" units, My tach is a 5" INDASH tach, I believe you could use a 5" monster tach, with memory and internal shift light.. ( I'm not positive of that, but the outside dimensions are the same) The center gauge where the factory tach was, Is a 3-3/8" This is the tough one....... They are a 55 series. The oil pressure is a 5505, and the water temp is a 5507. The fuel level was 5514.. The problem is, Autometer has deleted this size from their line up. I bought these two off of ebay they were new in bubble wrap. There are still a couple of White background ones left on the shelves. When they are gone that's it. So if you're thinking of doing this, you'll want to at least get this sized gauge right away.. The 4 lower ones are 2-5/8".. The line up of this size has many different gauge options. You choose.. Last edited by RON WOODGEARD; 03-21-2005 at 08:40 AM. |
07-04-2004, 11:10 AM | #16 |
Called to all the local part stores for the Fuel Level gauge (5514) and no one knows were to get one. Any Ideas? I would rather have one non- matching gauge than a gaping hole if i decide to do this change. If anyone has one, let me know and I will buy it off you.
03-21-2005, 08:48 AM | #17 | |
Also, I have received quite a few emails, and PMs asking about the Pictures being gone... My web hosting site no longer has a photo gallery and in turn I lost most of the install pics, and naturally they don't show up in the F.A.Q. section.. BUT,, I have updated with what I could find of the pictures I still had,, They just are not in order now.... Go Here To see the pics.. Thanks, Ron |
03-21-2005, 09:01 AM | #18 |
I found at black face 3 3/8 inch guage yesterday while surfing a site someone posted over on GD. Its not an autometer but its black and its a clock. Would look good IMO in the middle hole.
http://69.20.111.53/index.asp?PageAc...S&Category=240 |
03-21-2005, 10:15 AM | #19 | |
resident geek
Looks nice!
71 C-10 stepper 88 Moostang T-Top w/ lots of goodies |
